Hey Guys,
Thinking about doing angel eyes to my head lights soon and have been doing a lot of research on how to wire them. A friend told me about t-taps however when I googled them I saw a lot of bad reviews and how they can wear away and loose connection. Just wondering if anyone has had any experience with them and whether I shouldnt be worried about the bad reviews or if I should stay away. I did notice flyryde uses them for his headlights so thats a plus I think? thanks
2010 Tsukuba Red 2.0 Coupe GT |
#2 | ||
Solder and heatshrink is the best (what i do when i wire stuff for headlights). If you use the crimp connectors (disconnects, t-taps etc), i would crimp it and then use electrical tape to wrap the crimp connector to the wire to make sure it doesn't come out.
The only bad thing about crimps is if you use the wrong one for a wrong wire gauge (it's going to be wrong since led components such as angel eyes usually come with very thin wire, 24ga+, whereas the crimps usually are for gauges from 22 and lower)
2010 Hyundai Genesis Coupe 2.0t GT Tsukuba Red |
#3 | ||
www.diodedynamics.com
![]() Join Date: May 2009
Soldering is not necessary at all unless you need to ensure that the voltage and amperage is exact. Sensors, data wires, higher-power electronics, etc.
For LED lights or signal wires for a relay, things that just need low 12v power, it's not needed. T-taps are great, as long as you do it properly. Just make sure they will not be pulled on / stressed and you'll be totally fine. As cowcow said, make sure you're using red (18-22 ga) and crimping them very well. Get a good crimping tool if you're going to do a lot, because normal pliers just don't cut it. You shouldn't be able to pull the wire out of the crimp, no matter how hard you pull. This is almost always the issue when you see people having problems with them.
#5 | ||
Even hyundai uses t taps, like everyone stated, just make sure it is crimped properly and it will be fine, the electrical tape also is not a bad idea
Sponsored by SixSpeedGraphix.com and GCTuner.com! Tuned by SFR! Injen CBE, ARK D/P & T/P, R2C intake, Lightweight Pulleys, Rigid Collar Kit, DD Stage 3 LEDs, 5% tint, Yellow Fogs, Wing Badges, Luxon Grill, System Oil cap, Sixspeed Graphix Sticker package |
#6 | ||
Thanks guys, I dont really have much soldering skills, I was going to practise before I did this but think I might go the T tap route and just make sure I get the right size and crimp them properly
#7 | ||
Can I find t-taps at a local hardware store? or maybe a stereo place?
Any help would be great Thanks
3.8 Karrusel White - 6MT AEM - Ark - Magnaflow - BTRcc - DGR - TWM Legal Disclaimer: Anything that I or anyone else says about my vehicle on this website (www.gencoupe.com or any affiliated or non affiliated sites), pertaining to modifications and/or events, is only to gain acceptance from my/our peers, and does not actually represent anything actually existing on my car or real world experiences, and thus, cannot be held against me in any issue, i.e. warranty claims, that may arise. |
#9 | |||
When the wire is too small for the crimp connector, strip it longer and double it up in the connector before crimping.
2010 Red 2.0L track Quote:
| ATM fuse taps? | titan | Electrical & Wiring 2008-2012 | 23 | 04-26-2013 01:02 PM |
| ATM fuse taps | titan | Interior 2008-2012 | 2 | 10-11-2011 06:44 AM |
| Saab Taps Into the Power of Facebook | AutoGuide.com | AutoGuide.Com News | 0 | 03-11-2011 07:30 AM |
| OnStar taps Google Maps navigation for Chevy Volt | RSS-Autoblog | Autoblog | 0 | 05-17-2010 10:30 PM |
| VIDEO: Production spec Lexus LF-A opens the taps outside the 'Ring | RSS-Autoblog | Autoblog | 0 | 10-08-2009 09:40 AM |
