D1S Replacement - Genesis Forum: GenCoupe Hyundai Genesis Forums
Old 03-16-2012, 11:01 AM   #1
Wide Open Ones
iMissLayups's Avatar
Default D1S Replacement
Just wanted some clear answers, since I've heard different things. Has anyone had success replacing the stock HIDs with Diode Dynamic's 6000k D1S HID bulbs?
I've heard switching them destroys ballasts but was it because of cheap bulbs or should it just not be replaced at all?
Also, how would I go about replacing the ballasts instead of worrying about blowing one? I really want 6000k HID's lol..
Thanks!
By the way, I've used search and read various threads, i just want everyone's opinion in one place and maybe get some from people who have switched it but didn't respond to the other threads.
2011 Karussell White 3.8 Track A/T
Performance
Magnaflow Catback Exhaust | AEM CAI | Eibach Sportlines
Cosmetics
Sarona Grill | Spec-D Headlights | DD 6000k HID | DD Stage 2 LED | LED Foglights | Switchback LED Turn Signals
http://www.facebook.com/layupsphotography/
iMissLayups is offline   Reply With Quote
Old 03-20-2012, 01:45 PM   #2
+1 iv read in a bunch of threads where it was blowing the ballast's but there there were some ppl that didnt have a problem at all...
Cal'sgen is offline   Reply With Quote
Old 03-20-2012, 04:31 PM   #3
Wide Open Ones
Exactly. My LEDs make my headlights look bad.
Performance
Cosmetics
Old 03-21-2012, 06:28 PM   #4
jay88's Avatar
+2 and subscribed
kw track model 6s
Sponsor myself
-SFR TUNE = OMG!!
-k&n intake
-Strk o2 housing catted thru custom 3" tbe with hks muffler
-Cxracing fmic/hks bov
-agp oil cc and breather
-prodigy front lip
-cpe gauge pod with boost, a/f, and volt gauges
-yellow laminx on fogs with 3k hids
-m&s type d grill
-sarona exhaust cover
-superlux tails
-Megan coils
jay88 is offline   Reply With Quote
Old 03-21-2012, 06:30 PM   #5
jay88's Avatar
Im installing my d1s bulbs tomorrow guess we'll see what happens
kw track model 6s
Sponsor myself
-SFR TUNE = OMG!!
-k&n intake
-prodigy front lip
-m&s type d grill
-superlux tails
-Megan coils
Old 03-21-2012, 06:40 PM   #6
tadam!
Jm_Dug's Avatar
ive had DD 6000k HID bulb for aout 9 months without any problems
shipping was very slow but other from that satisfied with product
before i bought the DD bulb i bought cheapo bulbs from ebay and one blew my ballast...
Check out the ONLY canadian vendor: UNIQ PERFORMANCE
2010 Genesis coupe 3.8
M&S Type D grill - E&G front lip - AEM CAI - Ark True Dual exhaust - E&G custom wrapped diffuser- Gram Lights 57 Xtreme 19x9.5 +25 _ 19x10.5 +25- HSD coilovers - custom tails -Hella Supertones horn - Blox knob - tablet gps/media center - added Brembos - M&S side skirts - SF-X CF hood - custom headlight - VIS cf fog surrounds
Jm_Dug is offline   Reply With Quote
Old 03-21-2012, 06:45 PM   #7
jay88's Avatar
Ok perfect. i bought mine from dd as well 6k will see how all goes tomorrow. Jmdug was it just take out old put in new and seal back up?
kw track model 6s
Sponsor myself
-SFR TUNE = OMG!!
-k&n intake
-prodigy front lip
-m&s type d grill
-superlux tails
-Megan coils
Old 03-21-2012, 06:54 PM   #8
tadam!
Jm_Dug's Avatar
much easier when you remove headlights... takes around 1 min (2 bolts, 2 connectors on each sides) and will make the job lot easier
one screw to remove in back of the cover
bulb is a push pin retainer a bit tricky
juste make sure you dont touch the glass on the bulb
no sealing to do... you just twist back the cover, put back screw and reinstall headlight
Old 03-21-2012, 06:57 PM   #9
jay88's Avatar
Thanks man will do and post back to confirm lol
kw track model 6s
Sponsor myself
-SFR TUNE = OMG!!
-k&n intake
-prodigy front lip
-m&s type d grill
-superlux tails
-Megan coils
Old 03-21-2012, 08:04 PM   #10
Wide Open Ones
Can't wait to hear the results!
Performance
Cosmetics
Old 03-21-2012, 08:14 PM   #11
SubtleStyle's Avatar
Jm did you notice a decrease in light with the 6k?
Sent from my ADR6400L using AutoGuide App
2010 IY 3.8 Track
SubtleStyle is offline   Reply With Quote
Old 03-22-2012, 10:48 AM   #12
jay88's Avatar
Alright so install was exactly 1 min on each side. Turned them on both light up and no flickering. Will have to wait until it becomes dark to see final results
kw track model 6s
Sponsor myself
-SFR TUNE = OMG!!
-k&n intake
-prodigy front lip
-m&s type d grill
-superlux tails
-Megan coils
Old 03-22-2012, 10:57 AM   #13
Chris
FlyRyde's Avatar
I will have a conversion to D2S soon guys. That should give a full options of colors, and D2S bulbs are mad cheap! I think the problem with the D1S aftermarket is due to the built in Ignitors pissing off the OEM Ballasts. The D1S to D2S adapters will hopefully be much stronger, since they are the ignitor. If they work, it'll be an alternative. I too have heard waaay too many stories of D1S bulbs dying super early, and taking out ballasts as well. I wish there was an aftermarket D2S ballast that fit the hole on the bottom, but so far, only the Matsushita GenV are even close, and they're way to small diamater. Maybe I'll make an adapter for those for the hardcore guys
@OP, try to remember to post back here if you have problems down the road. Thanks!
FlyRyde is offline   Reply With Quote
Old 03-22-2012, 04:05 PM   #14
jay88's Avatar
So its night time and lights look great. They shine same as before with stock but being that im lowered i have to adjust the lighting level and raise them higher
kw track model 6s
Sponsor myself
-SFR TUNE = OMG!!
-k&n intake
-prodigy front lip
-m&s type d grill
-superlux tails
-Megan coils
Old 03-22-2012, 04:18 PM   #15
Wide Open Ones
That would make things a lot easier!
How much more blue is the 6000k from DD? I was trying to decide between that and 8000k, I want it to match my switchbacks and foglights.
Performance
Cosmetics
Old 03-22-2012, 04:22 PM   #16
jay88's Avatar
Theyre right their with the switchbacks of mine. Maybe the hids can be a bit more blue but a friend has 8k with his switchbacks and they dont really match but 6k is just right
kw track model 6s
Sponsor myself
-SFR TUNE = OMG!!
-k&n intake
-prodigy front lip
-m&s type d grill
-superlux tails
-Megan coils
Old 03-22-2012, 04:30 PM   #17
Wide Open Ones
Nice. I really hope you don't have any problems with them! I'm ordering mine next week.
Performance
Cosmetics
Old 03-22-2012, 04:42 PM   #18
jay88's Avatar
Ill post back if any issues
kw track model 6s
Sponsor myself
-SFR TUNE = OMG!!
-k&n intake
-prodigy front lip
-m&s type d grill
-superlux tails
-Megan coils
Old 03-22-2012, 08:00 PM   #19
pjmtwo's Avatar
I have 8000k DD D1S bulbs as well. The only problem I have is that the bulbs would not turn on when the bulbs were on for a long drive. So if you take a road trip and take a rest room break, the bulbs would not turn on again. Tried contacting DD for past 2 months with numerous pm's and e-mail's, but no response. I guess their customer service department got shut down or something
pjmtwo is offline   Reply With Quote
Old 03-22-2012, 08:12 PM   #20
Has anyone tried the morimoto d1s bulbs from lightwerkz?
2010 IY 3.8 Track
D1S bulbs refuse to turn on pjmtwo Electrical & Wiring 2008-2012 3 02-22-2012 12:46 PM
8000K HID D1S bulbs white night Exterior 0 08-08-2011 02:11 PM
H11b or D1S? AJisdaman General Discussion 3 05-11-2011 06:17 AM
d1s light bulbs? Itsdustinl Exterior 2008-2012 7 11-28-2010 05:45 PM
F/S: OEM 2011 Cadillac Escalade HID Kit (D1S bulbs, ballasts, wiring) I Drive Naked Exterior 9 11-27-2010 04:34 PM
