DIY polyurethane transmission mount - Page 4 - Hyundai Genesis Forum
post #61 of 81 Old 11-08-2012, 12:25 PM
sixty4bitdiablo's Avatar
Quoted: 12 Post(s)
+1. INTERESTED! Transmission is the biggest area that I despise about this car. I have had good luck with diff. mount but would love to see a matching set of engine/tranny/diff mounts at a reasonable price from a reputable dealer.
  • 5% Tints
  • Grimmspeed Phenolic Spacer
  • Throwdown Performance Throttle Body Spacer
  • C-PE Rear Differential Mounts
  • Megan Racing Transmission and Engine Mounts
  • Tein S-Tech Springs
  • TurnInConcepts Short Shifter & Front Shifter Bushings with SS 400g Shift Knob
  • Techna-Fit Stainless Brake & Clutch Lines
  • Motorsports Authority Cat Deletes
  • AEM 320LPH Fuel Pump | OEM FPR Delete + Professional Products FPR | Fuel Return Line
  • Spec Stage 3 Clutch & Single Mass Flywheel
sixty4bitdiablo is offline
post #62 of 81 Old 11-08-2012, 07:03 PM
Was thinking about doing this mod this weekend, till I stumbled upon megan racings tranny mount. What do you guys think? Megan Racing
2013 Tsukuba Red 2.0T R-Spec
Mods:
Forge BOV
BBM lip spoiler
CNT catback
CNT high flow test pipe
Isis down pipe
Corrupt is offline
post #63 of 81 Old 11-08-2012, 07:10 PM
With teeth.
sanengo's Avatar
Is that a new product? Price isn't bad.
Sponsored by: ARK, AEM, +10hp | BTRcc, CMD tuned | 16G
Originally Posted by Pavel_Engines View Post
Show me your engineering degree and I will show you mine, and then we can discuss fastener design
sanengo is offline
post #64 of 81 Old 11-09-2012, 11:41 AM
brianjoy77's Avatar
I found these on there too: Megan Racing
I still may just make my own bracket for the tranny for half the price of the Megan.
2011 2.0T R-Spec
brianjoy77 is offline
post #65 of 81 Old 11-09-2012, 01:24 PM
Jedi Master
cris90's Avatar
WTF!? woo... go megan racing
motor mount is 70A thats super hard...
Fav. JT Quote
cris90 is offline
post #66 of 81 Old 12-04-2012, 06:15 AM
Tyr
Captain Awesomesauce
Tyr's Avatar
Quoted: 13 Post(s)
Those are cheaper but much harder than the CPE mounts. Apparently 70A is automotive tire tread while 50A is a pencil eraser. I think I'd have to get my engine balanced properly before I ran those.
Done:
AEM CAI
Synapse Synchronic DV
WeirTech EVOLVE Al. TBE
PA 91 Stage-1
Dynojet CMD+WB2
Enkei RPF1 18x9.5/10.5
Michelin Pilot Super Sports 265/285
StopTech SS Lines w/ RBF600
Brembo GT Caliper w/ GLoc R8/R6
Saikou Michi DC-3 Catch Cans
OEM GT Strut Bar
Eibach Sway Bar Kit
Solar Gard 20% All Around
Tyr is offline
post #67 of 81 Old 12-13-2012, 04:46 AM
The Lonely Driver
Bigdawg1124's Avatar
How do you get your engine balanced so that you don't feel the NVH caused by engine/tranny mounts?
That is the main reason why I don't want to get the engine mounts and I'm hoping that the tranny mount I got for my birthday (megan racing) doesn't make it too bad.
2012 3.8 M/T BB
IA | Ch. 11 S.7
OBX Headers and DP/TPs, CNT V3 CBE, BTR Tune, Crank Pulley, Maxbore.com TB Bore, TS TB Spacer and W/P Pulley, 3.9 gears, Eibach Sways, Moog Rear Endlinks, Mishimoto Radiator, Megan Racing Engine Mounts, Uniq Rigid Collars, TWM STS, ATQ F&R Bushings, Tenzo Concept 9, 19" x 8.5", 19" x 9.5"
Bigdawg1124 is offline
post #68 of 81 Old 12-13-2012, 07:37 AM
SJ is the man
JewishThunder's Avatar
You have to take the engine apart and get the full rotating assembly balanced.
Joe's milkshake brings all the boys to the yard...
I AM SPECIAL!
JewishThunder is offline
post #69 of 81 Old 05-22-2013, 06:34 AM
3.8 Track Owner
ESBjiujitsu's Avatar
Quoted: 12 Post(s)
Filled PU mounts is something i have done on a few of my past cars and was planning on doing to the gen as well but would also be interested in more aftermarket solutions especially for auto mount on the zf's
ESBjiujitsu is offline
post #70 of 81 Old 11-27-2013, 07:25 PM
rrmartin1's Avatar
brianjoy77,
To be clear, your bracket would bolt around the mount, effectively making it rigid, right?
If your not going to make/sell these brackets anytime soon then can you share the dimensions? You know, a little open-source help for the group. It sounds like you got pretty close. Just a sketch of the pre-bend cut out would help.
Heck, if anyone has a OEM or Meagan mount laying around then can you give me length, width, and bolt spacings and height?
I might be able to get the bracket made and I could post results. I have some 1/8" aluminum sheet that should be strong enough. Are there enough bolt threads left to hold the 1/8" plate?
Robert
2012 2.0T Tsukuba Red
Engine - SAI; Dual Catch Cans; Dress Up Bolts; Redline Heavy MT Fluid;
Interior - Nexus7 Install, Hardmounted Phone Stand
Exterior - Streak Headlights; Rear ARK Wing; Blacked-Out & Sharkfin Removal
Suspension - 2” Lowering Coils
Wheels/Tires - PoweredCoated Wheels; G-MAX 255&275/35ZR19
Electrical - Hardmounted Escort 9500ix & SmartCord; Mr. BrakeSafe Flasher
(I'll try to have pictures of everything in my GenCoup Garage.)
rrmartin1 is offline
post #71 of 81 Old 05-31-2014, 04:16 PM
rrmartin1's Avatar
Filled the mount with epoxy - Now the exhaust is louder?
Why did my exhaust sound get louder after this mod?
I expected more vibration and I got it. I expected more transmission sound (the werrrrr'ing of the gears) and I got that, too. But I don't understand why the exhaust is louder? My drive-train and exhaust are stock.
I used epoxy (4 containers, .85oz each)
Robert
post #72 of 81 Old 05-31-2014, 05:08 PM
Quoted: 12 Post(s)
Just installed a used oem mount yesterday that i bought half a year ago.
Was filled with 50A i believe, but o man. shifting feels so great!
Didn't get as much vibration or noise as i expected. id say its negligible.
EVERYONE should do this.
choboy9242 is offline
post #73 of 81 Old 06-01-2014, 05:53 AM
rrmartin1's Avatar
The epoxy I used is probably around 75D (much harder than what choboy9242 used). That is probably why I have more vibration and that isn't a problem for me.
I estimate that this mod has raised my transmission up about 1/2". Could that have caused an exhaust leak (stock exhaust, never removed)?
Some people have discussed installing a solid mount. Did you get an increase is exhaust noise?
Robert
post #74 of 81 Old 06-03-2014, 02:17 PM
rrmartin1's Avatar
Does anyone here have a solid transmission mount? I had a problem re-installing my rigid mount. To get the cross brace holes to lineup I had to loosen the top bolts. Because I tightened the top bolts last, I couldn't get to them to the ~50 ft-lbs (felt light the original torque). I know its bad but how big a deal is it?
Originally Posted by Jpc647 View Post
I don't mind loud. I just don't like loud that sounds like a problem. Like when I step on the clutch and it "rattles" when going slow.
I have this same rattle at low speeds. I don't mind if it isn't hurting anything.
What I would NOT recommend is taking out all the rubber between that metal and filling the whole mount with delrin or just welding the mount metal one piece. (unless it's a race car and you have solid bushings everywhere else)
Why would you not recommend a solid mount or bracket?
Did anything ever came of all this talk?
Robert
post #75 of 81 Old 02-05-2015, 11:35 AM
Bigp5011's Avatar
I just lost my 2.0t I always wanted to try this. Too late now
Bigp5011 is offline
post #76 of 81 Old 02-05-2015, 12:49 PM
rrmartin1's Avatar
Where? Maybe we can help you find it!
Robert
post #77 of 81 Old 10-25-2016, 07:54 AM
Silver3.8Track's Avatar
Now riding a 2014 3.8 Ultimate!
Silver3.8Track is offline
post #78 of 81 Old 12-26-2016, 11:16 AM
has anyone used a filled oem mount and megan trans mount? Can you comment on any differences between the two? Megan mount seems to be out of stock. Thanks
eR1c is offline
post #79 of 81 Old 01-02-2017, 06:40 PM
Genna108's Avatar
Quoted: 13 Post(s)
Im going to have to go with this idea for the trans and engine mount.
Genna108 is online now
post #80 of 81 Old 02-16-2017, 04:30 AM
Quoted: 16 Post(s)
+1 for this
lets go for a ride spawn
mrsmobbins101 is offline
Polyurethane fog bezels? KrazyKen Exterior 2008-2012 4 12-05-2011 01:01 AM
Top Mount vs Bottom Mount Manifolds Tyr 2.0T Discussion 2008-2012 5 06-27-2011 06:48 AM
FS: MB Luxon Polyurethane Grill Havoc Inc Exterior 11 02-25-2011 11:50 AM
~~I.S.~~ Prodigy front lip (POLYURETHANE) Mike@ImportShark Exterior 6 06-17-2010 09:32 AM
~~ Enough BS! Who wants POLYURETHANE? ~~ Mike@ImportShark Exterior 2008-2012 59 11-02-2009 01:52 PM
