Clear Coating Over Plasti-dipped Rims - Hyundai Genesis Forum
post #1 of 21 Old 11-16-2011, 11:00 AM Thread Starter
jshah500's Avatar
Ok so today I'm plasti-dipping my rims and I want it to stand up to winter's conditions. I have a lot of clear coat from when I painted my calipers so I figured I'll just reuse it. Will spraying this clear coast on the rims still allow me to peel off the plasti-dip at a laster time? Logically, the answer would be yes because the plasti-dip is the only thing touching the rims but I wasn't sure if clear coat would change the dip's properties or anything. I had read about this happening to some poeple on other car forums. I don't know, not a chem major. Thanks
Here's the link to the clear coat:
Amazon.com: Dupli-Color DE1602 Ceramic Universal White Engine Paint - 12 oz.: Automotive Amazon.com: Dupli-Color DE1602 Ceramic Universal White Engine Paint - 12 oz.: Automotive
Amazon (Links)Amazon (Links)
jshah500 is offline
post #2 of 21 Old 11-16-2011, 12:10 PM
GrayGT's Avatar
I used a matte clear and did about 2 coats. I had to peel a wheel and redo it and I had no issues
Sent from my PC36100 using AutoGuide App
GrayGT is offline
post #3 of 21 Old 11-17-2011, 04:32 AM
good to know^ i always thought a clear coat over the plastidip would mess it up.
bknewtype is offline
post #4 of 21 Old 11-18-2011, 04:36 AM
sNaK3's Avatar
Im having this same issue, but instead of clear coat i wanted to paint over the Plasti Dip with a higher quality spray paint...does anyone think it will mess up the peeling process?? i need it all to come off later just in case!!
sNaK3 is offline
post #5 of 21 Old 11-21-2011, 10:46 AM
Which matte clear did you use specifically??
GadgetAddicted is offline
post #6 of 21 Old 11-21-2011, 12:03 PM
GrayGT's Avatar
Think it was a rustoleom brand. It's was right next to the plastidip at menards
GrayGT is offline
post #7 of 21 Old 12-02-2011, 05:42 PM
KDMTurbah's Avatar
look for upol clear coat. its expensive but works hella better than one ur about to use.
2012 BB 2.0T R-SPEC
KDMTurbah is offline
post #8 of 21 Old 12-03-2011, 06:41 AM
j3ss3isgod's Avatar
how did the rims come out with the plasti dip, i wanna do it but am skeptical
how many layers did you put on the rims also
drive fast, take chances.
2011 genesis coupe 3.8 rspec black >:]
*BTRcc custom tune
*injen cold air intake
*injen ses catback
*tbc bypass
-Sarona Design Front Grill
-Sequence Foglight Inserts
j3ss3isgod is offline
post #9 of 21 Old 12-03-2011, 09:42 PM Thread Starter
jshah500's Avatar
KDM, kinda late there but thanks. j3, it came out ok. I did 4 coats and it looks great from >6 feet away. The closer you get, the more see my mistakes of missing certain parts of the rim (inbetween the spokes). But, I'm going to take it off and redo it in april or may. It's a learning experience sorta thing...might as well give it a shot.
jshah500 is offline
post #10 of 21 Old 12-04-2011, 02:39 PM
j3ss3isgod's Avatar
thanks good to know
its more of a matte finish too right?
and have you had any nicks in the dip yet
*BTRcc custom tune
*injen ses catback
*tbc bypass
post #11 of 21 Old 12-04-2011, 02:42 PM Thread Starter
jshah500's Avatar
Yeah, matte finish. 2 days after I did it I was on the highway going 70mph and a HUGE tumbleweed comes out infront of me (I live in NM). I try to avoid it but it ends up hitting my front left corner so a part of the rim got nicked up a little. Other than that, no. Plasti-dip is durable.
jshah500 is offline
post #12 of 21 Old 12-04-2011, 03:13 PM
good luck, hope you don't get bead leaks in the future
zFlaSh is offline
post #13 of 21 Old 12-16-2011, 10:58 PM
JK-DM!
nellyville41's Avatar
Yes, it will mess up the peeling process!! Long story short, car wash rubbed my rim on railing, peeled edge of rim. I'm having a very hard time removing the plastidip/duplicolor combo off the rim. It's breaking off into small pieces and basically has to be chiseled off with a razor blade, thus scratching the original rim in the process. I'm very disappointed.
FYI: I used 2 heavy coats of plastidip, 3 coats of duplicolor, and 2 coats of sealer.
My Current Build Thread
http://www.gencoupe.com/media/104664-nellyville41s-jk-dm-current-build-thread-pic-heavy.html
nellyville41 is offline
post #14 of 21 Old 12-22-2011, 08:52 PM
I reject to reality
ninja3.8's Avatar
thanks for that info. been thinking of doing this myself, but i think ill stick with just plastidip.
BUY MY AUDIO EQUIPMENT HERE
http://www.gencoupe.com/private-classifieds-interior/129126-fs-alpine-pdx4-100-zapco-dc650-drc-remote-control.html
ninja3.8 is offline
post #15 of 21 Old 12-22-2011, 09:05 PM
clintbrandt's Avatar
I don't know your process of removing it, but it will naturally come off in tiny pieces in somewhat cold weather. I would try using a heat gun or even a hair dryer. That's how I got mine off, it came off fairly easily and I had 2 coats of clear coat over mine. But yes, it took little longer with the clear coat, but with the heat gun it wasn't too bad.
clintbrandt is offline
post #16 of 21 Old 01-04-2012, 08:52 AM
FreeStyle Fabrications
FreeStyle's Avatar
you used them in that order right? pastidip, duplicolor, and then sealer? what kind of sealer
the other thing i would have tried was going to a carwash with a good high pressured hot pressure washer, and go to town. id never have tried to use a razor blade on it
Jeremiah
2010 3.8 Genesis Coupe|
15% Tint
Debadged except VIP Rear Badge
Seibon SC CF Hood
LaminX Carbon Taillight Tint
Alpine Audio Install including:
2 12" subs, 3 amps, and trunk lid mounted 6.5"s in a custom fiberglass box
Magnaflow Catback Exhaust
AEM Intake
LaminX Carbon Fog Tint
RMR Grille
RMR Snorkel
RMR Lip
RMR Fog Light Bezels
RMR Skirts
RMR Diffuser
20" Work Varianza T1S. 9.5F +15, 10.5R +10
BC Racing Coilovers
Next? Rotors... Paint?
www.FOTOmotiveSD.com
FreeStyle is offline
post #17 of 21 Old 01-04-2012, 03:46 PM
JK-DM!
I think it was in ok weather. Not too cold. Was around 65 or so degrees when I was trying to remove it. Didn't think to heat it up and try peeling. I'll keep that in mind in case this instance ever comes my way again. LOL.
Yeah, that was the order I went. The sealer was the Duplicolor Clear Coat Sealer. I don't know if the high powered washer would of done anything. It was stuck on there pretty tight.
post #18 of 21 Old 02-01-2012, 09:15 AM
sNaK3's Avatar
Wow thanks. Wish I could of seen this sooner. I used 2 coats of plastidip, a couple of white(then green later on) and some clear coats. I messed up on a rim and it did not peel easily. Between me and a friend we "rubbed it off" Rubbing with your fingers back and forth works extremely well while utilizing a heat gun temporarily before running it and while. But you will get blisters from rubbing. Ask a friend or two to help you peel the rim in the same fashion it helps so much! Also using goobegone wipes with force will thin out the paint/dip mix and make it easier!! Ad the more Plastidip base coat the better.
sNaK3 is offline
post #19 of 21 Old 02-01-2012, 08:18 PM
gennybuff9892's Avatar
plasti dip makes its own clear coat for that its called glossifier. http://www.dipyourcar.com/ has all the tutorials on how to plasti dip anything.
gennybuff9892 is offline
post #20 of 21 Old 02-25-2013, 07:00 AM
HeatherLynn90's Avatar
I bought the plasti-dip wheel kit, which comes with the cans of base coat, the actual color, and a gloss top coat. Doing it today- post pictures after!
HeatherLynn90 is offline
DIY White Plasti-Dip OEM rims... WIP CantFindMeHaha Suspension and Wheels 312 03-20-2014 12:35 PM
Plasti dipped my rear emblem H Threept8GC Exterior 2008-2012 63 06-05-2012 11:35 AM
plasti dipped rims gennybuff9892 Exterior 2008-2012 24 09-22-2011 05:00 PM
Powder Coating Rims * Help please! Genesis2012 Wheels, Tires and Brakes 2008-2012 11 09-01-2011 07:32 AM
finally plasti-dipped the E&G "Bling" grille DPaik Exterior 2008-2012 22 03-21-2011 09:37 AM
