So, I had a head light (LB) go out and I replaced it. But the new bulb isnt light up either. The other side works and the HB and signal works, but no low beam. Any suggestions???
2010 Genesis Coupe 2.0T R-Spec Karussell White ---------------- Mod's Window Tint - 50% Front / 35% Side & Rear SPEC-D Headlights w/DRL's Space Black Sport Front Grille w/Wing Emblem D&D 6000K HID Conversion Kit Ultimate Racing SRI SFR Custom Wing Badge Emblem: Front & Back Injen Hot side/Cold Side Piping (For Sale) MISHIMOTO FMIC - (Waiting to install) Forge BOV BBM Lip Spoiler Magnaflow CBE TSW Chrome Wheels & Falcon Tires (for sale) Stance SC-5 (Coming soon!!) |
#2 | ||
if they are the HID conversion kit you have, it might be the ballast.
2010 Nord Gray Genesis Coupe 2.0T - AEM Intake - DD 4300K HID - DD Led Conversion - 30% Tints - BBM Rear Spoiler - Modified OEM grill - HKS SSQV |
#3 | ||
No, regular h11b bulb. I took the HID's out a while ago.
#5 | ||
Any idea what where it is? I checked the fuse box and didnt see it labeled. Does it just control the LB?
#8 | ||
Cool thanks!!!
#9 | ||
Check these 4 fuses, depending on what side it is. I kept blowing one side, then the other because of a bad ballast. This is where to replace your fuses. don't go higher than the rating. find your short. if there two blow then change out the brown relay in the picture. relays are pricier tho so test to see what the problem is
PROTIP: Do not leave your car outside for millions of years. There will be nothing left. - N20Inferno |
#10 | |||
#11 | ||
well the controller is still the same but its separately protected. this takes two seconds to go check. when you buy new fuses buy 3 or 4. if it keeps shorting I'd talk to your dealer. Shorts like this for no reason should be under warranty.
#12 | |||
Doesn't the fuse box lid say what fuse is what? And yes there is a fuse for both lo and both hi beams.
2010 Red 2.0L track Quote:
#13 | ||
it does. but theres 2 fuses protecting the same light essentially. so I got fixated on the two that werent blown when i had this problem and then i went WELL WTF IS WRONG!? didnt occur to me that there'd be two fuses in series. save this guy a headache. let us know how it goes.
#14 | |||
Three fuses actually. One covers both (20A) and then a 15a for the individual lamps. So if one headlight works the 20a is good for sure.
#15 | ||
That worked, it was one of the 15 amp fuses. Totally blown.
| Mind = Blown | NJGX03X87 | Off-Topic | 49 | 09-02-2011 09:05 AM |
| blown out smoke | curtisb | 2.0T Discussion 2008-2012 | 48 | 08-24-2011 07:36 AM |
| Genesis Coupe - Headlight Armor (Headlight & Fogs) | jameshkim87 | Exterior | 6 | 12-17-2010 02:28 PM |
| !@$FES Blown Fuse Help. | Roirrawa | Interior 2008-2012 | 7 | 01-14-2010 10:37 PM |
