FYI new gen coupe buyers, just spoke to a tech in the know and heard how to turn off traction control completely. when you hit the traction control button, turns down traction control, not all the way off. when you turn the car into the on position without starting it, then turn it off, then start the car... it's off.
just an fyi to ppls that are passionate about the cars. |
Advertisement |
#3 | ||
yea im finding this very unlinkely that this is the case......
Current Car: 2007 NHBP Civic Si 4-door, i/h/e and 75shot of spray part out has begun, car has been assigned to DD duty Coming soon: 240SX with a XXXXDET motor ![]() ![]() |
#6 | ||
Master Member #518
Doesn't matter whether it's true of not. It's good advice. Turn off traction control BEFORE actually starting it up. Get in, get the car to come on to where the dials come on, hit the ESC/traction control switch, start the car, and drive away without the limiting devices in plays. A good practice that I'll be sure to use.
Thanks.
For Sale: Brand New Injen Cold Air Intake for 3.8 V6, never opened, $280picked up, pm me. "...this isnt a tib. the 3.8 will always be a better engine in stock form, and with boltons, and with a turbo/bigger turbo..." 4TGEN "My [blah blah blah] was a beast, but I don't live in the past..." Hank |
#7 | ||
Turn the car off, then to the on position without starting, then on, don't turn off from there. I don't have a source thats referable because it's not supposed to ever be fully off, so it's not documented, I found this from a tech, and its worked when I tried it a few days ago. As is the case on many cars, Toyota, Honda are two that are common, when the system is off, it's not off, it's just turned down. This turns it off fully.
#8 | ||
Banhammer power activate!
How does this work with the push button start? I haven't see/used it yet so I don't know..
- "If you are flammable and have legs, then you are never blocking a fire exit. You can write that down and put a dash in front of it, and put my name at the bottom." Mitch Hedberg |
#9 | ||
don't push the brake, hit the button twice to turn the car 'on' (no foot on the brake and once is accessory, twice is on) then push the brake and hit start again. Our car is a V6 Track, in Nordschleife Gray so with the push button start.
#10 | ||
Master Member #518
Summary of how to turn traction control FULLY off (correct me if I'm wrong):
With key'ed ignition: 1.Turn the key to the 'on' position without starting the car 2. Hit the Traction control button, so that Traction Control is off 3. Start the car, and drive away. 4. If you happen to turn the car all the way off, repeat from step 1 With the keyless iginition: 1. Get in the car with the key in your pocket, or inside the car where it needs to be 2. Without touching anything else (brake, etc), hit the 'Start' button twice to turn the car 'on' but without actually starting the car. 3. Hit the Traction control button, so that Traction Control is off 4. Hit the 'Start' button (with your foot on the brake) to actually Start the car, and drive away. 5. If you happen to turn the car all the way off, repeat from step 1
For Sale: Brand New Injen Cold Air Intake for 3.8 V6, never opened, $280picked up, pm me. "...this isnt a tib. the 3.8 will always be a better engine in stock form, and with boltons, and with a turbo/bigger turbo..." 4TGEN "My [blah blah blah] was a beast, but I don't live in the past..." Hank Last edited by McFly; 03-11-2009 at 09:26 AM.. |
#12 | ||
Master Member #518
Don't thank me, thank Jase, he brought the info to us, I just put into an understandable, step by step, format.
You're welcome, though. This should be a sticky.
#14 | ||
This is pointless. It is now well known that Traction Control is completely off when it says that it is
![]() My father has the same system in his Sonata and trust me when it says it's off; it's offfff Hma Service confirms the same for the Genesis Coupe. |
#15 | ||
Function over Form
Well, as soon as my brother receives his car, I will be trying it both ways. Gives me an excuse to burn up some of his tires.
![]() All the same, thanks jase for the insight. When I hit the traction control button in my bimmer, it's completely off. I went through my 1st set of tires rather quickly proving it. ![]()
If it ain't fast, I'm not happy. ![]() 04' Honda 450R (many mods, real fast) Last edited by Tufast; 03-11-2009 at 12:37 PM.. Reason: spelling |
#16 | |||
#17 | ||
R-
Is it okay to turn it off?
![]() My friend who drives a R35 GTR down here turned his off, and the dealership found out and voided is warranty T_T"
2003 WRB WRX - Sold 2006 Forester XS - Current 2010 GC GT or GTI - In Spring |
#18 | |||
littering and...
#19 | ||
The Wisconsin Madman
This will be very good news if it works! I remember reading a review about it only turning off something like 20% according to the writer of the article and that when Hyundai was drifting the car they had to pull the TCS fuse.
#20 | ||
This is one of those things that I somehow doubt will be done until someone opens the ECU and reads the code... lol
