#21 | |||
el chupacabra
the 1jz in my supra had a hard 1 bar boost cut, didnt matter what turbo was on there, ecu always cut it at 1 bar, of course i was only running .8 bar before i sold the car either way, give it a shot, i'm excited to see. hopefully i'm wrong... |
Advertisement |
#22 | ||
It's a bit late, having to do some production server upgrades at 2:00 am, reading 306 whp thinking on stock turbo almost gave me a heart attack!
50 whp to go, and tell me where I can sign up for the setup!
2010 Genesis Coupe 2.0T GT 6-speed in Nordschleife Gray Mods: PowerAXEL re-flash /w PowerX |
#23 | ||
el chupacabra
that setup will likely easily break that mark, provided the fuel pump and internals can handle it. once the catback is on and the boost is upped to 18-20 psi, it should easily be a ~350whp car on pump gas
#24 | ||
el chupacabra
more importantly, does the car even have 100 miles on it yet?
and by chance, can you post a dyno overlayed on the stock graph? maybe a bit larger also? when it comes to pictures, i think the bigger the better . . . until its too big Last edited by NeverNZ; 04-04-2009 at 09:50 PM.. |
#25 | ||
NOW THATS THE TORQUE CURVE THIS MOTOR DESERVES!
dumb question, I might have overlooked, is this a pretty advanced turbo? Ball bearings... exotic materials for the blades and such?
95 Integra GS-R Basic Bolt-Ons *SOLD* 97 240sx SR20 Swap FPBT28 Turbo, Cams, FMIC, Injectors ect... *SOLD* 01 Honda S2000 Basic Bolt-Ons *Sold* Looking for my next toy, hopefully with BOOST! |
#26 | |||
el chupacabra
also, using exotic materials in turbos, like ceramics, is not always the best thing. It can lead to a very lightweight turbine wheel with a very fast spool, but may be prone to failure more so than a steel turbine wheel |
#27 | |||
Thank you!What the heck are you doing up so late answering my questions! ![]()
#28 | ||
My old FPBT28 turbo was thrust bearing but it was very responsive and I LOVED it, I can't imagine how this thing would drive!
#29 | |||
el chupacabra
actually, i went to a concert tonight, i'm a bit wired. add that to the AWESOME news posted by both Beyond Redline and AMS and i cant even consider sleeping (sorry for the hijack guys) |
#30 | ||
Site Sponsor
![]() Join Date: Feb 2009
100.1 miles when i loaded on the dyno and 102.7 miles when i was done for the night LOL
#31 | |||
Site Sponsor
#32 | |||
el chupacabra
i foresee clutch problems, making that much power with a stock clutch that hasnt broken in yet... are you going to keep that turbo or put the stocker back on? i really thought the GT3076 would spool way later than that also |
#33 | ||
Site Sponsor
We will probably put the stocker back on eventually just to max it out and see what it will make with our bolt ons. I was a little worried about not breaking it in as well, but so far so good. I did log wheel speed vs engine rpm to detect any early slip before i could actually start to feel it, but I have to review it in the morning. Another thing I have going on the dyno, is I am only accelerating approximately 3000lbs of weight (roller/eddy brake) with no wind resistance, so there is less load than an actual 5th gear pull on the highway.
#34 | ||
awesome stuff guys!!
#35 | |||
The guys in Korea are reporting they are NOT getting any clutch slip problems with 350ps with 1.3 bar boost. One of them is suspecting that it might hold up until 400ps.
#36 | ||
GenCoupe.com Dictator
great work guys! keep us up to date as usual!!!
#37 | |||
X2, I can't wait to see what these guys can squeek out of this setup. More boost + Beyond Redline Catback + a little more fine tuning should equate to some really impressive numbers. From what I have been reading this might actually be the highest hp Genesis in the US. Obviously over seas they had a bit of a jump start but I think you guys are catching them. Keep up the hard work guys. I can't believe how quickly you guys are building this car. Definitely a step ahead of everyone else.
2010 Genesis Coupe 2.0T Stock for now. |
#39 | ||
Looking forward to more info today!
#40 | ||
Impressive and if this kit cost under 3K I'm definatly interested and may sway back to buying a 2.0T
18psi is the point when the BOV opens and does a soft boost cut. The clutch slips around 380whp. Which is why everyone in Korea is at 350-360whp. |
