7500 mile check up cost? - Hyundai Genesis Forum
post #1 of 19 Old 12-24-2013, 09:33 AM Thread Starter
falcon26's Avatar
Quoted: 27 Post(s)
I'm bringing in my 2012 Gen Coupe for its 7500 mile check up on Thursday. Any idea what the dealer usually charges for the 7500 mile check up?
Thanks...
falcon26 is offline
post #2 of 19 Old 12-24-2013, 09:41 AM
If they charge anything it would be too much. Check the fluid levels and call it a day.
post #3 of 19 Old 12-24-2013, 09:47 AM
240SX turned GC
s3t0_S13's Avatar
Quoted: 16 Post(s)
if you gotta ask, their going to try and charge you as much as possible....
Competition Clutch
HKS
K
&N
M&S
ABS Dynamic
ARK
AGP
Superlux
Btrcc
PowerAXEL
Magnaflow
s3t0_S13 is offline
post #4 of 19 Old 12-24-2013, 09:53 AM
GenSport KY
Molotov Fun's Avatar
Location: In-between, BFE and You sure do have a pretty mouf.
Quoted: 19 Post(s)
Nothing you cant do.
@ Mitsubishi we did:
Tire rotation and balance
measure tire depth
measure brake pad depth
checking all fluids and top off
oil change
inspect fuel line and fittings
inspect vacuum hoses and Evap lines
inspect air filter
inspect cabin filter
look for leaks.
Hook up to scan tool to check for any codes in the ecu\tcu history
Check for recalls ect.
Send it to our wash bay for a vacuum and wash, in a automatic washer that was like sand paper to your paint. (I always skipped this unless cust. wanted it)
This was @ a cost of about 200$ lol
From Hyundai
Hydrogen and Stupidity, The most common elements in the universe.
Say NO! to Import Shark
https://www.facebook.com/SayNoToImportShark?fref=ts
Molotov Fun is offline
post #5 of 19 Old 12-24-2013, 10:25 AM Thread Starter
falcon26's Avatar
Quoted: 27 Post(s)
So around $200 OK. I don't know crap about maintaing cars so I have choice but to use the dealer 😥😥
falcon26 is offline
post #6 of 19 Old 12-24-2013, 10:29 AM
Really at 7500 miles it's a waste of time IMHO. Check the oil and the radiator (when cold).
post #7 of 19 Old 12-24-2013, 10:30 AM
I assume the oil has been changed?
post #8 of 19 Old 12-24-2013, 10:30 AM
a3l3e9x4's Avatar
All you need at 7500 miles is an oil change, trust us. If anything else goes wrong it will go under warranty at no cost to you.
2013 Monaco White 3.8 Track Auto
a3l3e9x4 is offline
post #9 of 19 Old 12-24-2013, 10:32 AM
GenSport KY
Quoted: 19 Post(s)
Yeah, do a oil change if needed. rotate and balance your tires.
Cost of 50$ or so, from any shop.
Oil change 30$ est.
Rotate & balance 20$ est.
post #10 of 19 Old 12-24-2013, 11:30 AM Thread Starter
falcon26's Avatar
Quoted: 27 Post(s)
OK I'll do that Thanks!
falcon26 is offline
post #11 of 19 Old 12-24-2013, 07:43 PM
B_Warren's Avatar
Do not rotate your tires on a staggered setup, aka what we have.
2013 2.0T Base A/T
Black Noir Pearl
Debadged w/ Wing Emblem
DD Stage 2 License Plate Kit
DD 6000k HID Kit
DD Stage 2 Switchbacks
Injen SRI - Invision
TurboXS RSD-CBE
TurboXS Racepipe
TurboXS RFL BOV
BC Racing Coilovers
B_Warren is offline
post #12 of 19 Old 12-24-2013, 10:22 PM
GenSport KY
Quoted: 19 Post(s)
The OEM tires are not directional. Therefore you rotate drivers side and passenger side with each other.
post #13 of 19 Old 12-25-2013, 10:53 PM
Unless you always use "Top Tier" gas they will want to install fuel system cleaner for about $30.00.
booneyed is offline
post #14 of 19 Old 12-26-2013, 07:21 AM
Not really much point in that is there?
-Lee
Owner of WetShavingProducts.com
Ex Gen Owner. White Pearl 2013 3.8 R-Spec
jdinaz is offline
post #15 of 19 Old 12-26-2013, 08:28 AM
2010 3.8 Std Trans
Wytchdctr's Avatar
If your suspension is 100% perfectly aligned with no problems, probably not. If you have a slight issue that isn't adjustable, like one tire has slightly more camber than the other, and you dislike the bolts, one of the tires might wear just a bit faster in the inside. Flip them side to side and let the other tire deal with that for a bit.
2010 3.8 Manual - "Custom" Intake/Megan AB Exhaust/SPEC Clutch-Flywheel
2003 Elantra - Not Stock
Wytchdctr is offline
post #16 of 19 Old 12-26-2013, 09:00 AM
My right rear tire tends to wear faster than the left. I usually rotate them at 10k.
post #17 of 19 Old 12-26-2013, 11:13 AM Thread Starter
falcon26's Avatar
Quoted: 27 Post(s)
Took it in today it was $99 for the 7500 mile check up....took about 1 hour...
EDIT: When I brought it in my tire pressure light was on. I thought it was just low on air, turns out I had a nail in my rear tire :-( $30 to have it fixed dam it....
falcon26 is offline
post #18 of 19 Old 12-26-2013, 08:09 PM
$30.00 to plug a tire?
booneyed is offline
post #19 of 19 Old 12-27-2013, 06:26 AM
leg68's Avatar
please don't say they charged you 30$ to plug. hope they removed off rim and patched.
leg68 is offline
Check Engine Repairs Cost Most in New Jersey: Study AutoGuide.com AutoGuide.Com News 0 06-11-2013 08:50 AM
FS: Unavi ENB-7500 only $400 jayp6969 Ontario Classifieds 3 01-08-2013 02:34 PM
7500 mile checkup bklyncoupe General Discussion 10 11-11-2010 09:21 AM
Who is going the full 7500 miles between oil changes? CFar General Discussion 9 05-05-2009 06:53 PM
