New details on the 3.3TT Engine - Page 8 - Hyundai Genesis Forum
 69Likes
post #141 of 281 Old 04-07-2015, 08:52 AM
What helps the Corvettes get such good mileage is they slip through the air very well, less drag than most cars on the road.
They also have lots of torque (displacement) at very low rpms, enough to cruise along at 1500-1900 rpm. Add to that the .5 ratio 6th gear and you get good mileage. Finally they weigh less. 3150-3350 lbs IIRC those years)
But back on the Genesis Coupe. Is the 3.8L going to be used in anything else? if not they aren't going to keep making it for one car that sells under 15,000 units a year.
Since the chassis is going to be bigger it's going to have more torque. If it had the same engine it would be slower while getting less mpg's lugging the extra weight around. They aren't going to let that happen.
I could see the 3.3L or the 5.0, or even both. You can buy a turbo diesel or turbo gas VW Jetta for under $22K, so it's not like it's that expensive anymore to make tough, forced induction engines. (don't forget the turbo F150's and sub $25K turbo Mustangs, etc)
The 3.3L Turbo could well be the base and the 5.0 an option. It will be a little more expensive. I could see $31-38K for the 3.3L depending on options. I guess $35-45K for a 5.0 if offered.
Thats my prediction at this time. 3.3L Turbo gets similar mileage we get with a 3.8L now, 18-27) and the 5.0 gets 17-24.
GettingOld likes this.
2013 Genesis Coupe 3.8 R-Spec
Cobra2Genesis is offline
post #142 of 281 Old 04-07-2015, 11:44 AM
Quoted: 237 Post(s)
Originally Posted by flacoupe2.0T View Post
dodge started this deactivation with the 5.7L hemi motor
the new 5.7L block is built by Mercedes
if you are cruising on the hiway,4 cylinders shut down until you give it fuel,then all 8 are back in action.
the only problem I see is if you cruise all the time eventually the 4 cylinders that shut down will eventually have uneven wear compared to the other 4 cylinders and come overhaul time there will be quite a difference in piston size and cylinder wear between all cylinders and pistons
This assumes the same 4 cylinders are shut down. Quite a big assumption, id imagine this was brought up during conception and easily solved for by mixing up which cylinders shut down.
And even if they did, this is a negligible issue. Worst case 4 out of 8 cylinders have MORE compression because during CD, spark and fuel are both cut off, so these cylinders would see less combustion events thusly they would wear at a lesser rate than the other cylinders. Doubtful any loss in power or issues come "overhaul" time would be a result of this non-issue.
2013 Empire State Gray 2.0t Base 6MT
- HKS SSQV
- K&N Drop-In
- Exceladyne CBE
thomas91169 is online now
post #143 of 281 Old 04-07-2015, 01:43 PM
mattcnz's Avatar
Quoted: 13 Post(s)
You really think the 3.3L will go for over $30k? One of the appeals of this car is that it is priced below others like the 370z and BRZ
wutsjdm likes this.
mattcnz is offline
post #144 of 281 Old 04-07-2015, 02:06 PM
GettingOld's Avatar
Quoted: 198 Post(s)
Well I don't see the next gen Z (Z35) going for anything less than $34 base. We have a huge thread on it over at 370z forum. Consensus is base i4, 300hp ish and Mercedes 6 turbo with 400+hp at around $40k (base). So Genny with 400+ with goodies...I'm game for $38 ish.
GettingOld is offline
post #145 of 281 Old 04-07-2015, 04:08 PM
ig @2point0_tj
wutsjdm's Avatar
Quoted: 14 Post(s)
definitely agree. 3.3TT for 33-38k sounds right to me
LV08 likes this.
2013 Genesis Coupe 2.0T Premium
- VIS Carbon Fiber Hood / K2 Trunk
- 19" Vossen CVT
- BC BR Type Coilovers
- CPe FMIC
- ISR Tubular Exhaust Manifold
- Evo VIII TD05 16g
wutsjdm is offline
post #146 of 281 Old 04-07-2015, 05:09 PM Thread Starter
ravenseal's Avatar
Location: A magical place where the sun shines and you can drive year round.
Quoted: 398 Post(s)
Did you not follow anything about the Genesis moniker in the last year? Hyundai has repeatedly stated they're moving the brand up-market.
We're probably looking at a 3.3TT starting at 33 grand or so, placing it to compete with the Q50 and the 428i.
2011 BMW 335is DCT E93 - Stg1
FOR SALE https://www.cars.com/vehicledetail/detail/662718966/overview/
2013 3.8L R-Spec | Magnaflow Exhaust| Track Spoiler | Hankook Ventus V12 evo2 | Rostra Cruise Control 250-1859 |
ravenseal is offline
post #147 of 281 Old 04-08-2015, 11:16 AM
Threept8GC's Avatar
Quoted: 67 Post(s)
While we're on the subject of gas mileage, I just wanted to add that I've been averaging 21.7 mpg all city in my 3.8 according to the trip computer. Don't know how accurate it is but this car can be pretty efficient if you drive it normally.
Threept8GC is offline
post #148 of 281 Old 04-08-2015, 11:26 AM
loubeat's Avatar
loubeat is offline
post #149 of 281 Old 04-08-2015, 11:28 AM
Go Hyundai!
jesse82nc's Avatar
Quoted: 338 Post(s)
My 3.8T averages 21.5 mpg (via my own math during every fill up) with my regular driving, highway with heavy traffic. When I do strictly highway I get about 25 mpg. And when I do hard driving (like at the Dragon), I get about 15-17 mpg.
'14 3.8T 6MT Ultimate, Ibiza Blue
Precision 6266 BB Gen2 Turbo w/ TurboKits.com's Kit running 9 psi + Water/Meth
Too many mods to list, just visit my garage via the link here - http://www.gencoupe.com/garage.php?do=viewvehicle&vehicle_id=7090
Dyno 2/20/15 - 475.8 hp / 437.8 tq SAE
First 3.8 GDI to break 400 hp on the dyno
jesse82nc is offline
post #150 of 281 Old 04-08-2015, 12:18 PM
PAdutch's Avatar
Quoted: 56 Post(s)
Originally Posted by loubeat View Post
I'm surprised to hear 3 engines but wouldn't mind seeing the 2.0t come back.
To stay on topic, sounds like the 3.3 will be a nice engine. 400+hp stock would be awesome. This must have a beefed up drive-train too.
PAdutch is offline
post #151 of 281 Old 04-08-2015, 10:17 PM
Quoted: 18 Post(s)
If Hyundai is seriously looking at making the Coupe a 3 engine choice car they need to look at the way Ford is playing that game right now with the current mustang. New mustang sales are ridiculouly good because they are keeping them pretty affordable with a base starting below $24k all the way to a premium non-convertible a little above $36k ('cause we know hyundai ain't releasing a convertible coupe anytime soon).
Whether they make the NA V6 or new 2.0 the base remains to be seen but the new 3.3L will be the top of the line and they'd be smart to keep it line with what they're competing against.
If people can get a mustang base GT with the monster potential of their 5.0 for a little over $32k then I'd like to imagine Hyundai would be smart enough to keep their upcoming N Peformance Genesis coupe close to that price point instead of some ridiculous starting price point of above $35k... But that's all speculation of course.
2012 Hyundai Genesis 2.0T R-Spec
Sold the car - BUY MY PARTS! For Sale thread below
http://www.gencoupe.com/private-classifieds-engine/429634-2012-2-0t-part-out-back-stock-feeler.html
Bevo Lotti is offline
post #152 of 281 Old 04-09-2015, 02:12 AM
GettingOld's Avatar
Quoted: 198 Post(s)
From the article about the 3.3....
"When Hyundai Motor America’s CEO was interviewed a few days ago during the New York AutoShow he said: “This all-new engine would arrive on the Genesis sedan in 2017 or 2018 and have power in the ballpark of the company’s 420-hp, 5.0-liter Tau V-8 but weigh far less.”
Coincidentally our source mention this engine will be ready for production in late 2017."
HELL YES!!!
'14 3.8 Black/Tan GT-current
'13 Volvo S60 T5-current
'04 Honda Accord EX-beater
'13 370Z Sport-sold
'05 350Z Touring 6mt-sold
'92 300ZX TT-sold
'82 280ZX Turbo-clutch fell out
'79 260Z-destroyed
post #153 of 281 Old 04-09-2015, 08:40 AM
andbudzi's Avatar
Quoted: 270 Post(s)
Originally Posted by leesrt View Post
Here's the embarrassing truth.
2015 Corvette 19mpg city 30mpg hwy
2015 Gen Coupe 3.8 16mpg city 25mpg hwy
All due to gearing, it is running about 1,800rpms on a highway.
Swap track rear dif. Into automatic genesis and you will be getting over 30 mpg on the highway...that is if you do not care about acceleration.
andbudzi is offline
post #154 of 281 Old 04-09-2015, 08:42 AM
Go Hyundai!
jesse82nc's Avatar
Quoted: 338 Post(s)
Originally Posted by andbudzi View Post
All due to gearing, running 1,800 on a highway.
Swap track rear dif. Into automatic genesis and you will be getting over 30 mpf on the highway.
The corvette has almost always had 2 overdrive gears (5th and 6th, or 3 gears - 5th, 6th, and 7th in the new ones) in the manual, where the gen only has 1 (6th).
2014 Chevrolet Corvette 2.66 1.78 1.30 1.00 0.74 0.50 0.42
post #155 of 281 Old 04-09-2015, 08:58 AM
andbudzi's Avatar
Quoted: 270 Post(s)
Wrong class dude. Mustang is beneath genesis.
Genesis will be competiting with 3 series and infinity Q60 coupe. As long as it cost slightly less then infinity then it will be a win...better car for less money.
andbudzi is offline
post #156 of 281 Old 04-09-2015, 09:02 AM
Mature Speeder
leesrt's Avatar
Quoted: 105 Post(s)
1. That doesn't explain why its also better in the city
2. I have the track dif with auto and it does not get 30mpg. About 26mpg cruising at 80mph
leesrt is offline
post #157 of 281 Old 04-09-2015, 09:08 AM
andbudzi's Avatar
Quoted: 270 Post(s)
1. Upshifting points lower due to more torque.
2. Drive 65.
andbudzi is offline
post #158 of 281 Old 04-09-2015, 09:09 AM
Mature Speeder
leesrt's Avatar
Quoted: 105 Post(s)
Correct, if you want to compare prices with GM match it with the ATS-V coupe. That's their luxary sport coupe. The ATS-V will have a little more HP but it also starts at $61k.
leesrt is offline
post #159 of 281 Old 04-09-2015, 09:13 AM
Mature Speeder
leesrt's Avatar
Quoted: 105 Post(s)
2. Drive 65.
Great points. So basically I can have over 200 less HP and have to drive 5mph below the speed limit to come close in MPG.
leesrt is offline
post #160 of 281 Old 04-09-2015, 09:22 AM
Quoted: 18 Post(s)
No dude, in terms of build quality, reliability, resale and power the mustang is not beneath the genesis.
I haven't read a comparison test between the genesis coupe and 3 series or q60 coupe. They are always compared to a mustang, golf, brz, etc, not a luxary coupe.
If hyundai wants to fantasize about being in the same class as infinity then let them but the only thing close to that is the sedan, not the coupe.
The coupe was and is supposed to be a fun and affordable "sports" car. With the way Ford has been going about the mustang as of late Hyundai could learn a thing or two from them.
Volkswagen Details New Diesel Engine AutoGuide.com AutoGuide.Com News 0 11-12-2014 07:20 AM
Volkswagen Details New Diesel Engine AutoGuide.com AutoGuide.Com News 0 11-11-2014 12:10 PM
Ferrari Details New Turbo-V6 F1 Engine in Video AutoGuide.com AutoGuide.Com News 0 12-30-2013 12:10 PM
2.0T Engine Details - stock bottom end? SeanPlunk 2.0T Discussion 2008-2012 14 02-13-2009 04:08 PM
