gencoupe.com gencoupe.com
Go Back   GenCoupe.com Forums - Your Hyundai Genesis Coupe Community > Hyundai Genesis Coupe Forums > General Discussion
Old 09-10-2008, 08:27 PM   #21
fsr
tiburonV6 for now!!!!
fsr's Avatar
even a tiburon v6 is faster than those numbers look:
so is no way those numbers can be real if they real then the gen coupe will be a total dissappoinment
2007 Hyundai Tiburon GT
The Quickest Cars of 2007: Less Than $20,000
VEHICLE TYPE: front-engine, front-wheel-drive, 4-passenger, 3-door coupe
BASE PRICE: $19,995
ENGINE TYPE: DOHC 24-valve V-6, aluminum block and heads, port fuel injection
Displacement: 162 cu in, 2657cc
Power (SAE net): 172 bhp @ 6000 rpm
Torque (SAE net): 181 lb-ft @ 3800 rpm
TRANSMISSION: 5-speed manual
DIMENSIONS: Wheelbase: 99.6 in
Length: 173.0 in
Width: 69.3 in
Height: 52.4 in
Curb weight: 3114 lb
C/D TEST RESULTS:
Zero to 60 mph: 7.6 sec
Zero to 100 mph: 20.9 sec
Zero to 120 mph: 37.1 sec
Street start, 5-60 mph: 7.7 sec
Standing ¼-mile: 15.7 sec @ 88 mph
Top speed (drag limited): 136 mph
Braking, 70-0 mph: 163 ft
Roadholding, 200-ft-dia skidpad: 0.84 g
FUEL ECONOMY: EPA city/highway driving: 19/27 mpg
fsr is offline   Reply With Quote
Old 09-11-2008, 01:59 AM   #22
G is for GenCoupe
justin_24's Avatar
What he said^^^
justin_24 is offline   Reply With Quote
Old 09-18-2008, 10:02 AM   #23
Originally Posted by SUB-GEN View Post
I beleive its all lies. A lexus is250 is RWD/3500lbs/204hp@6500/185tq@4500 rpm and it gets to the 60 in 7.2-7.6 seconds. The genesis has better performance than the is250,RWD/3440lbs/223hp@6000/217tq@2500 should equal a .5 second better time.
You are forgetting gearing. My car gets to 60 in 3.4 seconds, faster than a Porsche 911 GT2, and yet the GT2 clocks the quarter in 11.7, as opposed to my 11.9.
Point is, the IS250 is probably geared a bit differently than the Genesis Coupe.
rarson is offline   Reply With Quote
Old 09-18-2008, 10:09 AM   #24
Sound Man
ItalynStylion's Avatar
That's why BMW 330's were always quick; the rear end gears were always short.
ItalynStylion is offline   Reply With Quote
Old 09-18-2008, 10:37 AM   #25
FlesHBoX's Avatar
True, but 3+ seconds is a lot to lose to gearing, unless it's geared like a tree. This is especially true when you take into consideration that I don't think Hyundai has used gearing THAT slow in anything, at least recently. And 2, this car is aimed at tuners and enthusiasts, gearing like that would be a huge case of suicide... And 3... Hyundai has been saying since the first spy shots forced them to say anything at all that this will do the 0-60 in 6.5 or less.
It is a lot more likely that the numbers quoted are innaccurate, at least by a little bit
..: J e s s e :..
Easy like Hyundai morning.
Originally Posted by logitec View Post
when i see flesh has made a comment i usually scroll through to read what he said due to the fact I dont think hes been wrong yet...
FlesHBoX is online now   Reply With Quote
