US Tech Specs Released - Genesis Forum: GenCoupe Hyundai Genesis Forums
Old 10-30-2008, 03:46 PM   #1
Default US Tech Specs Released
Thoughts??
HYUNDAI RELEASES ADDITIONAL ENGINEERING AND FEATURE INFORMATION FOR THE ALL-NEW
2010 HYUNDAI GENESIS COUPE
Genesis Coupe Delivers an Estimated 30 MPG
FOUNTAIN VALLEY, Calif., Oct. 30, 2008 – Hyundai released additional engineering
and feature information for the all-new 2010 Genesis Coupe today. The Genesis
Coupe, and its rear-wheel drive platform-mate the Genesis sedan will make their
Specialty Equipment Market Association (SEMA) show debuts next week. "One of the
program targets for the Genesis engineering team was world-class weight
efficiency," said John Krafcik, vice president, Product Development and
Strategic Planning, Hyundai Motor America. "When you look at the size and
content of both Genesis models, you’ll find we lead all our competitors in
weight efficiency. We also target leadership in power-to-weight ratio. We think
that’s just smart strategy in today’s world. It pays huge dividends in both
performance and fuel economy, and that’s especially important in the segments in
which these cars compete."
Both Genesis Coupe and sedan are rich in ultra-high-strength steel, leading to
world-class body rigidity. The Genesis sedan is 10-12 percent stiffer in
torsion than Lexus and Mercedes-Benz competitors, yet it is lighter than these
benchmark sedans, and offers more interior room. At just 3,303 pounds, the
Genesis Coupe 2.0T is hundreds of pounds lighter than all of its IRS-equipped
rear-wheel-drive competitors, with body-bending rigidity 24 percent higher than
BMW E46 M3.
This focus on weight efficiency pays dividends across the board. The Genesis
sedan owes its ability to deliver both strong performance (0-60 mph in just 5.7
seconds) and excellent fuel economy (25 mpg EPA highway rating) in great part
due to its impressive weight efficiency. Similarly, the Genesis Coupe 2.0T sets
a new benchmark for front-engine, rear-wheel-drive gasoline fuel efficiency with
a remarkable 30 mpg estimated EPA highway rating, because of its weight-
efficient platform and its efficient 2.0-liter, low-pressure, turbocharged four-
cylinder engine.
Last edited by Mr.K; 10-30-2008 at 04:02 PM. Reason: Adding Press Release for easy long reading ;)
jbbrann is offline   Reply With Quote
Old 10-30-2008, 04:01 PM   #2
Mr.K's Avatar
"While some turbochargers sacrifice smooth drivability with high operating boost pressures in the 20 psi range, Genesis Coupe uses a refined, low-boost calibration for smoothness and efficiency," said Derek Joyce, Genesis Coupe product manager. "We could have opted solely for big performance numbers, but our focus for the 2.0T was a more balanced package."
GENESIS COUPE PRODUCT HIGHLIGHTS
With the start of U.S. market production now just a few months away, Hyundai Motor America is releasing model configuration and color choices for the 2010 Hyundai Genesis Coupe.
"Genesis sedan has set a new benchmark for the $35,000-$40,000 premium sedan, and we think Genesis Coupe will do the same in the sport coupe segment," Krafcik said. "From our 30-mpg 2.0T with its low-pressure intercooled 4-cylinder turbo, to the 3.8 Track model with an estimated 310-hp and Brembo braking system, Genesis Coupe offers a wide range of powertrain and performance choices for driving enthusiasts of all stripes."
There are seven basic Genesis Coupe configurations:
- 2.0T
- 2.0T Premium
- 2.0T Track (6-speed manual transmission only)
- 2.0T R-Spec (late availability, 6-speed manual transmission only)
- 3.8
- 3.8 Grand Touring
- 3.8 Track
GENESIS COUPE 2.0T: A MORE EFFICIENT TAKE ON THE REAR-WHEEL DRIVE SPORT COUPE
Standard equipment includes:
- 2.0-liter, low-pressure, turbocharged, intercooled 4-cylinder engine with dual continuously variable valve timing delivering an estimated 210-hp (regular), estimated 220 hp (premium), an estimated 223 ft-lbs of torque (at just 2,000 rpm), an estimated 30 mpg EPA highway rating and an estimated top speed of 137 mph
- M6VR1 6-speed manual transmission (Optional: A5SR1 5-speed electronic automatic transmission with lockup torque converter and steering wheel-mounted paddle-shift Shiftronic controls)
- 18-inch Euroflange alloy wheels with staggered Bridgestone Potenza RE92A tires (P225/45VR18 front, P245/45VR18 rear)
- Electronic Stability Control with ABS, Electronic Brake-Force Distribution and Brake Assist
- 12.6-inch ventilated front rotors with 60mm single piston floating caliper
- 12.4-inch solid rear rotors with 43mm single piston floating caliper
- Sport-tuned MacPherson strut dual-link front suspension and five-link rear independent suspension, 24mm front stabilizer bar, 19mm rear stabilizer bar
- Strut brace
- Quick-ratio hydraulic steering (2.7 turns lock-to-lock)
- Tire Pressure Monitoring System
- Front, side, side air curtain air bags
- Active front head restraints
- Driver’s lumbar support
- Black-out front lower fascia
- Trip computer
- Air conditioning
- Satin silver and chrome interior accents
- Keyless entry system
- Leather-wrapped steering wheel and shift knob
- Power windows (one-touch up and down), door locks and mirrors
- AM/FM/XM/CD audio system with six speakers
- USB/iPod/Aux jack connectivity
- Steering wheel audio controls
- Cruise control
- Projector beam headlamps with auto light control
- Integrated Bluetooth including steering wheel controls
- Temporary spare with steel wheel (T135/90D17)
The 2.0T Premium model adds or substitutes:
- Power driver seat
- 360-watt AM/FM/XM/CD-changer Infinity premium audio system with 10 speakers including DVC subwoofer, eight-channel external amplifier, and diversity antenna
- Smart Key with push-button start
- Electrochromic mirror with HomeLink and compass
- Sunroof
- Navigation system (mid-year availability)
The factory-tuned 2.0T Track model builds from the 2.0T Premium, adding/substituting:
- 19-inch Euroflange gunmetal finish alloy wheels with staggered high-performance summer-compound Bridgestone Potenza RE050A tires (P225/40YR19 front, P245/40YR19 rear)
- Unique Brembo braking system with 13.4-inch ventilated front rotors, 42mm four-piston fixed front calipers (red), 13.0-inch ventilated rear rotors, 32mm+28mm four-piston fixed rear calipers (red)
- Unique track-tuned suspension, higher-rate coil springs, higher-control shock absorbers, 25mm front stabilizer bar, 22mm rear stabilizer bar, strut brace
- Torsen-type limited-slip differential
- Black leather bolster seats with high-friction red cloth insert
- Aluminum pedals
- Aero windshield wipers
- Rear spoiler
- Xenon HID headlamps
- Fog lamps
- Lightweight temporary spare with aluminum wheel (T135/80D18)
- Note: Automatic transmission not available with 2.0T Track
Later in the model year, a tuner-focused performance model, R-Spec, will arrive at Hyundai dealerships. Genesis Coupe R-Spec is meant to be the ultimate upgradeable, affordable, turbocharged rear-wheel drive performance platform. R-Spec equipment includes:
- 2.0-liter low-pressure turbocharged intercooled four-cylinder engine with dual continuously variable valve timing delivering an estimated 210-hp (regular), estimated 220-hp (premium), an estimated 30 mpg EPA highway rating and an estimated top speed of 137 mph
- 6-speed manual transmission
- Brembo braking system with 13.4-inch ventilated front rotors, 42mm four-piston fixed front calipers (red), 13.0-inch ventilated rear rotors, 32mm+28mm four-piston fixed rear calipers (red)
- Track model suspension tuning (higher-rate coil springs, higher-control shock absorbers, 25mm front stabilizer bar, 22mm rear stabilizer bar, strut brace)
- Air conditioning
- Note: Automatic transmission not available with R-Spec
GENESIS 3.8: 310 HORSEPOWER AND STANDARD LEATHER INTERIOR – A NEW BENCHMARK FOR PERFORMANCE AND REFINEMENT IN ITS CLASS
Standard equipment includes 2.0T equipment, and adds or substitutes:
- 3.8L DOHC V6 engine with dual continuously variable valve timing delivering an estimated 306-hp (regular), 310-hp (premium), and a top speed of 149 mph
- M6VR2 6-speed manual transmission (Optional: ZF 6HP19 6-speed electronic automatic with lockup torque converter and steering wheel-mounted paddle-shift Shiftronic controls)
- Black leather seats
- Fully automatic temperature control
- Premium door sill plates
- Chrome front fascia accents
In addition to 3.8 equipment, the 3.8 Grand Touring adds or substitutes:
- Unique brown leather seat interior environment
- Power driver seat
- Heated driver and passenger seat
- Heated mirrors with outside turn signal indicators
- Backup warning system
- Sunroof
The factory-tuned 3.8 Track model deletes backup warning system and chrome front fascia accents from the Grand Touring model, and adds or substitutes:
- Aluminum pedals
- Rear spoiler
- Fog lamps
Genesis Coupe will be available in nine exterior colors:
- Karussell White
- Bathurst Black
- Silverstone
- Nordschleife Gray
- Acqua Minerale Blue
- Tsukuba Red
- Mirabeau Blue
- Lime Rock Green
- Interlagos Yellow
Genesis Coupe features four different interior themes:
- Black environment, premium black cloth seats (2.0T, 2.0T Premium, R-Spec)
- Black environment, black leather-bolstered seats with high-friction red cloth insert (2.0T Track)
- Black environment, black leather seats (3.8, 3.8 Track)
- Black environment, saddle brown leather seats (3.8 Grand Touring)
Mr.K is offline   Reply With Quote
Old 10-30-2008, 04:04 PM   #3
G is for GenCoupe
justin_24's Avatar
SWEEEEET. So 4 pistons front and back. 30MPG!!! Awesome! Hell even 25MPG for the V6 is pretty incredible for 310hp. Navigation! Yes, please! Better weight to hp ratio than all other in it's class... well, those they listed. I'm pretty psyched. Just wish they would have put price tags on all the various models available.
justin_24 is offline   Reply With Quote
Old 10-30-2008, 04:04 PM   #4
Token Metro Guy
brandon1987's Avatar
Hmm, well I know what model I will be getting, cost permitting...Genesis Coupe 3.8GT in either Karussell White or Nordschleife Gray...that is as long as they don't change the packaging again before it gets to Canada.
--CurrentCar--
(Canadian Spec)
Carbon Filter Removed - 7000K High Beams/DRLs - 20% Tint - M&S Type D Grille - Black Vinyl Roof Overlay - Carbon Wrapped Console - BBM Lip Spoiler
--Previous Cars--
2005 Acura RSX Premium
2000 BMW 323i
1988 Toyota Supra Turbo
brandon1987 is offline   Reply With Quote
Old 10-30-2008, 04:14 PM   #5
Galbi's Avatar
Whats the difference btwn the 2.0T track and 2.0 R-SPEC model? Is it suppose to be lighter?
Galbi is offline   Reply With Quote
Old 10-30-2008, 04:22 PM   #6
Token Metro Guy
They didn't explain it very well, but I think that the R-Spec is the same as the Track but minus the luxury items that the Track pack adds inside the car.
--CurrentCar--
(Canadian Spec)
--Previous Cars--
2000 BMW 323i
Old 10-30-2008, 04:28 PM   #7
Paddle-shifter! Sweet ...
aung2004 is offline   Reply With Quote
Old 10-30-2008, 04:39 PM   #8
wow, finally, speechless, i like the 3.8gt , mmm, no track for me i think..
Raven is offline   Reply With Quote
Old 10-30-2008, 04:40 PM   #9
Does the base 2.0T come with those alloy wheels in the pic above? I like those spokes.
Old 10-30-2008, 04:45 PM   #10
SUB-GEN's Avatar
I hate that you cant get automatic with 2.0t track.
SUB-GEN is offline   Reply With Quote
Old 10-30-2008, 04:45 PM   #11
Token Metro Guy
Aung, no those are the upgraded 19" wheels those come on the track and R-spec models.
--CurrentCar--
(Canadian Spec)
--Previous Cars--
2000 BMW 323i
Old 10-30-2008, 05:05 PM   #12
ER101160's Avatar
finally some good news...still waiting for those $$$
anyone want to predict . . . ???
- 2.0T 20K ?
- 2.0T Premium 22 K ?
- 2.0T Track 24 K ?
- 2.0T R-Spec - 3.8 26K ?
- 3.8 Grand Touring 25K ?
- 3.8 Track 29 K ?
that will decide for me I4 / V6 (premium or grand touring)
ER101160 is offline   Reply With Quote
Old 10-30-2008, 05:14 PM   #13
Token Metro Guy
I am going to venture a guess of:
2.0T - $20,000
2.0T Premium - $22,000
2.0T Track - $24,000
2.0T R-Spec - $25,000
3.8 - $27,000
3.8 GT - $28,500
3.8 Track - $30,500
--CurrentCar--
(Canadian Spec)
--Previous Cars--
2000 BMW 323i
Old 10-30-2008, 05:21 PM   #14
that's not good.
i like those wheels and i want paddle-shifters. i hope 19" wheels can be opt separately. i've never seen spokes on 18". anyone has a link?
Old 10-30-2008, 05:26 PM   #15
2.0T - $20,000
3.8 - $27,000
3.8 GT - $28,500
3.8 Track - $30,500
my wild guess:
2.0T - $19,000
2.0T Premium - $20,500
2.0T Track - $23,000
2.0T R-Spec - $23,500
3.8 - $24,000
3.8 GT - $25,500
3.8 Track - $27,000
Old 10-30-2008, 05:30 PM   #16
SUB-GEN's Avatar
I love it. Now i can have fun with my auto.
Old 10-30-2008, 05:35 PM   #17
Token Metro Guy
Here are the 18" wheels:
--CurrentCar--
(Canadian Spec)
--Previous Cars--
2000 BMW 323i
Old 10-30-2008, 05:42 PM   #18
SUB-GEN's Avatar
2.0t=20k/2.0tp=22k/2.0tt=25.5k.............3.8v6=23.5k or 24k/3.8GT 25.5k/3.8track=29k.
Old 10-30-2008, 05:43 PM   #19
2.0T- 19k
2.0T prem- 22k
2.0T track-24k
2.0t R spec-21k
3.8-24k
3.8 prem-26k
3.8 track-28k
R-spec has NOTHING but two front seats and the track upgrades
theironmonk is offline   Reply With Quote
Old 10-30-2008, 05:49 PM   #20
Galbi's Avatar
Originally Posted by theironmonk View Post
2.0T- 19k
2.0T prem- 22k
2.0T track-24k
2.0t R spec-21k
3.8-24k
3.8 prem-26k
3.8 track-28k
Hopefully they take out some of the sound proofing materials from the body, aluminum hood (if it isnt already so), thinner glass windows, smaller battery, no spare tire, thinner carpets and no backseat. That should cut roughly 200 pounds right there.
Genesis Forum: GenCoupe Hyundai Genesis Forums > Hyundai Genesis Coupe Forums > General Discussion
