NEED HELP check engine light - Page 2 - Hyundai Genesis Forum
post #21 of 35 Old 04-04-2011, 05:17 AM Thread Starter
daniel360's Avatar
ok just got back from dealer and those where the exact codes.... is there anyone in south florida who has a set of 3.8 track wheels that they are not using so i can test out the theory that it may be the new wheels? i had enkeis on before and never had a problem so i doubt it but hopefully someone can help me.
daniel360 is offline
post #22 of 35 Old 04-04-2011, 05:22 AM Thread Starter
daniel360's Avatar
need help asap!!!! does anyone have a set of track wheels they are not using that i may use, i have gone to the dealer ship 3 times already for a faulty brake switch and the last time they said its cuz of the wheels but it did this before with the stock only i sold them... please if anyone can help 305-763-2996 stacey or 786-203-8404 PLEASE HELP
post #23 of 35 Old 04-04-2011, 06:36 AM
Miss Thread Derailer
Lauren's Avatar
I'm sorry I can't help with the wheels
But if the brake switch failed with the stock tires, the oddly sized A/M tires may have triggered the switch to malfunction again..
Were your Enkeis the same size as your current ones?
2010 Genesis 2.0T MT Nordschleife Grey
Originally Posted by pwned88 View Post
A llama Lauren? really? spitters are quitters
Lauren is offline
post #24 of 35 Old 04-04-2011, 07:05 AM Thread Starter
daniel360's Avatar
ok may have a solution i spoke to vossen direct and a near performance shop looks like the dealer i got the wheels sent me the wrong size tires which is causing the tcs to go off and after that happens to many times it will trigger the CEL so they are being kind enough to switch out the tires for me and we will see if it all goes well. i will keep everyone posted so incase you guys run into any of this *knock on wood that u dont* and this was the first thing i mentioned when it happened and the dealer said no that it couldnt be that and know looks like it maybe.
post #25 of 35 Old 04-04-2011, 09:47 AM
Quoted: 260 Post(s)
brake switch doesn't have to do with wheels. Its the switch that is connected to the brake pedal.
Only issue you would have with the wheels, if it WAS the wheels, would be TCS going off and/or the TPMS lights going off.
Go to a different dealer, still under warranty. Complaint to hyundai consumer affairs about previous dealer.
post #26 of 35 Old 04-05-2011, 09:38 AM
interrex's Avatar
He should have checked his diameter size of the tire he put on. It is not the dealer fault if you change the stock wheels out and not put the right diameter back on. This makes since now. throws the speedometer off to . That is why he was showing a fault for the brakes. The revolution did not match the speedometer. He would have to have it recalibrated for the new tire size.
interrex is offline
post #27 of 35 Old 04-05-2011, 10:12 AM
Quoted: 260 Post(s)
Its not diameter its over all tire tread diameter "ratio" from fronts to rears.
I am running 17" wheels with smaller than stock overall diameter and have no issue. These are my winter wheels and got 17" because it was the largest size rims that would fit the largest studded tires that they have.
17" are the smallest size wheels that you can run on this car, and even then, only a few actually clear the calipers.
If you run square on the wheels instead of staggered you get an issue with the TCS going off at about 55+ mph.
No one (AFAIK) hasn't had and issue with the brake switch caused by any issues with the wheels and I've been here a while.
post #28 of 35 Old 04-05-2011, 10:26 AM
All the Hyundai DTCs are on Hyundai Service Website
post #29 of 35 Old 04-05-2011, 10:29 AM
Brake > Electronic Stability Control
• C1101 Battery Voltage High
• C1102 Battery Voltage Low
• C1112 Sensor source voltage
• C1200 Wheel Speed Sensor Front-LH Open/Short
• C1201 Wheel Speed Sensor Front-LH Range / Performance / Intermittent
• C1202 Wheel Speed Sensor Front-LH Invalid/no Signal
• C1203 Wheel Speed Sensor Front-RH Open/Short
• C1204 Wheel Speed Sensor Front-RH Range / Performance / Intermittent
• C1205 Wheel Speed Sensor Front-RH Invalid/no Signal
• C1206 Wheel Speed Sensor Rear-LH Open/Short
• C1207 Wheel Speed Sensor Rear-LH Range / Performance / Intermittent
• C1208 Wheel Speed Sensor Rear-LH Invalid/no Signal
• C1209 Wheel Speed Sensor Rear-RH Open/Short
• C1210 Wheel Speed Sensor Rear-RH Range / Performance / Intermittent
• C1211 Wheel Speed Sensor Rear-RH Invalid/no Signal
• C1235 Primary Pressure Sensor-Electrical
• C1237 Primary Pressure Sensor-Signal
• C1259 Steering Angle Sensor – Electrical Malfunction
• C1260 Steering Angle Sensor Circuit-Signal
• C1282 Yaw Rate & Lateral G Sensor-Electrical
• C1283 Yaw Rate & Lateral G Sensor-Signal
• C1503 TCS/ESC(ESP) Switch error
• C1513 Brake switch error
• C1604 ECU Hardware Error
• C1605 CAN Hardware error
• C1611 CAN Time-out ECM
• C1612 CAN Time-out TCM
• C1613 CAN Wrong Message
• C1616 CAN Bus off
• C1647 CAN Hardware Error - Sensor Channel
• C2112 Valve Relay Error
• C2126 Vacuum Pump Relay Drive Pin Open/Short
• C2227 Excessive Temperature Of Brake Disc
• C2231 Vacuum Pump System Fail
• C2380 ABS/TCS/ESC(ESP) valve error
• C2402 Motor Failure
post #30 of 35 Old 04-05-2011, 10:42 AM
Quoted: 260 Post(s)
need codes from OP.
Wait our cars have a g sensor?
EDIT: could be a parking brake error too
To OP, ask for them to show you the part that was replaced after work is done, so you know that they actually did the work instead of just wiping the codes.
And there is a multi-model TBS for the brake switch. From what everybody had an issue with on this is that they couldn't start the car because they had a trim with the smart key. So, I assume that they wouldn't be able to see a CEL.
post #31 of 35 Old 04-05-2011, 10:52 AM
LakerLand
Lower it's Avatar
so im guessing you might need 245/30/20 and 275/30/30.
look around the forum there are a couple members running 20's with none of this bull$hit
Lower it is offline
post #32 of 35 Old 04-05-2011, 11:27 AM
Quoted: 260 Post(s)
~Five Axis Wheels Revealed!
post #33 of 35 Old 04-05-2011, 11:28 AM
There is the YAW sensor behind the center dash/console trim.
post #34 of 35 Old 04-06-2011, 06:03 PM Thread Starter
daniel360's Avatar
ok so i got the rear tires replaced they are now 285/30/20 which diameter is 26.73 the stock diamter from the 245/40/19 is 26.71 which is closer than the 26.49 that i had on the rear. well the light still tripped so all i can think it is that the fronts are the problem now. Going to get them changed tomm. going with 255/30/20 in the front which is really close to factory diameter of 26.08 and the current diameter is 26.75 the new diamter will be 26.02. please cross your fingers for me....lol
post #35 of 35 Old 04-07-2011, 09:47 AM Thread Starter
daniel360's Avatar
ok change front tires to 245/30/20 problem fixed finally!!!! i wanted 255/30/20 but they didnt have any around town. so hopefully no one runs into this... at least my mistake is everyone else knowledge
Help with Check Engine Light (CEL) codes JayKyung 2.0T Discussion 2008-2012 15 10-01-2015 02:27 PM
check engine light Medsport 2.0T Discussion 2008-2012 18 12-18-2012 03:59 AM
o2 Check Engine Light questions. TMAN1985 2.0T Discussion 2008-2012 26 01-03-2011 08:41 AM
Check engine light? Abstract General Discussion 2 10-04-2009 10:19 AM
check engine light..... doots 2.0T Discussion 2008-2012 42 07-31-2009 07:28 PM
