for the love of god, any new rev hang solutions? - Hyundai Genesis Forum
 2Likes
post #1 of 31 Old 05-15-2017, 12:18 AM Thread Starter
Daktah Pepah's Avatar
Quoted: 42 Post(s)
i got an old 86 300zx a few months ago and now even though its beat to hell with a grindy tranny and has 1/2 the power it has become my daily driver and the wife drives the genesis now. the sole reason being that it does not rev hang and does not have a rev down delay (slow rpm drop) which leads to a blissful driving experience with quick and brainless shifting not having to pay attention to how long the engine feels like hanging (and the digital dash and t tops are awesome too). i have a sfr 1.5 on the genesis and while it absolutely improved the power output it did zilch for rev hang. im assuming the rev down is from the weight of the engine rotating mass including the boat anchor dmf since it slows down just as slow if i cut the car off while its coming down, but rev hang is known to be software controlled. is there some way, any way at all, to fix this god awful rev hanging? now that ive been spoiled by how a car should act, i literally cant drive the genesis without a scowl on my face every time i try to shift and the engine just chills at 3000 rpm for 2 seconds forcing me to either wait an eternity to shift or just do it anyway and give myself whiplash from the rpm difference. i would really really like to enjoy driving my $28000 car as much as my $1500 car.
2014 Hyundai Genesis Coupe
R-Spec | 2.0L Turbo | Casablanca White | 6 Speed Manual
Mods
BPV to BOV | Interior LEDs | R2C Short Ram Intake | Wing Badges | ISIS Short Throw Shifter | HID Headlights | ISIS O2+DP+CNT v3 | Deck Lid Spoiler | Enthuspec Stainless Brake+Clutch Lines | Prosport EVO Boost+Oil Temp+Wideband
Daktah Pepah is online now
post #2 of 31 Old 05-15-2017, 02:22 AM
StrangeLiform's Avatar
Quoted: 74 Post(s)
There's only so much software can do to fight physics. Besides, your SFR 1.5 tune should be mitigating the software side of the rev hang problem for the most part. The stock GenCoupe clutch setup is just mechanically flawed, primarily in the flywheel. Get rid of the DMF and your Genesis will feel a lot better. Your 300ZX feels so great because all it has is a good old-fashioned chunk of steel bolted to the end of the drive-shaft instead of some multi-piece monstrosity that's all packed full of springs and rubber and garbage:
Rip out the DMF and drop in ACT's single-piece XACT flywheel. No amount of software re-calibration will make as big a difference to your shift quality.
See? Look how much better that is!
Excess drivetrain movement can also add to the sensation of rev hang. Firmer transmission or even engine mounts will help with that. Swapping to ACDelco 10-4014 transmission oil would put the cherry on top by speeding up and smoothing out synchro engagement.
Good luck, happy tuning!
TR6Quebec likes this.
StrangeLiform is offline
post #3 of 31 Old 05-15-2017, 09:37 AM Thread Starter
Quoted: 42 Post(s)
It hangs just as much as without the tune, I drove them side by side after I got the ECU in the mail. It hangs the exact same amount in gear and in neutral, if it was that much of an inertial problem wouldn't it be much less in neutral with 2/3 of the drivetrain disconnected?
post #4 of 31 Old 05-15-2017, 11:58 AM
NCGiant's Avatar
Quoted: 43 Post(s)
I have SFR 1.5 and a SMF, still hangs as much as ever.
2013 Gen Coupe 2.0t R-Spec
SFR 1.5/NGK 2309
Depo Racing O2
ARK Down/Test/GRiP
K&N Typhoon
Megan Trans Mount
ATQ Shifter/Bushings
Subframe Collars
NCGiant is online now
post #5 of 31 Old 05-15-2017, 12:30 PM
Does the BK2 still have the rev hang hose?
post #6 of 31 Old 05-15-2017, 04:38 PM Thread Starter
Quoted: 42 Post(s)
That's about what I expected unfortunately
Wasn't that proven to be flase?
post #7 of 31 Old 05-16-2017, 05:17 AM
Quoted: 42 Post(s)
my 2014 rev hangs. it sucks. i wonder if that little throttle box would help. the sprint throttle booster.
if the ecu is controlling an idle air control valve as well as the throttle plate, it could make a solution complicated.
johnzm is offline
post #8 of 31 Old 05-16-2017, 07:43 AM
Korean Asswhoopin
Thumb5's Avatar
Quoted: 103 Post(s)
Haltech will fix it. jussayin
2010 Grey Hyundai Genesis Coupe 2.0T Track - Beyond Redline - Haltech and BW EFR 7063 - 385 whp and 345 wtq - Crappy gas
2016 VW Tiguan S Daily
Thumb5 is offline
post #9 of 31 Old 05-16-2017, 12:27 PM
balbert908's Avatar
I have 2013 track ATM. I installed the Sprint booster and really made a difference with the rev hang.
Sent from my LG-H901 using Tapatalk
balbert908 is offline
post #10 of 31 Old 05-16-2017, 01:27 PM
it worked for me.
post #11 of 31 Old 05-16-2017, 02:01 PM
NCGiant's Avatar
Quoted: 43 Post(s)
I thought it was computer controlled to lessen blow-by emissions? If the TB closes too fast the pressure in the engine raises and you get more blow-by since more oil vaporizes. This has been a standard on most new cars for emissions reasons, and even more prevalent on forced induction cars.
SFR 1.5/NGK 2309
Depo Racing O2
ARK Down/Test/GRiP
K&N Typhoon
Megan Trans Mount
Subframe Collars
post #12 of 31 Old 05-16-2017, 04:08 PM Thread Starter
Quoted: 42 Post(s)
for a measly $1500 and it cant even control the ac properly.
never heard of it. ill have to look it up. is it expensive?
it worked for me.
ill bite. can you show me which hose you mean?
yes exactly. however even with a tune that is supposed to eliminate rev hang, it still rev hangs and i really want to get to the bottom of it already because it 100% ruins the driving experience. as ncgiant said he has a single mass flywheel and the same tune as me and still gets rev hang.
Mods
post #13 of 31 Old 05-16-2017, 04:15 PM
balbert908's Avatar
Search Sprint booster v3 for genesis coupe on Google. Mine was $289. One bolt to remove accelerator pedal for the mod averse (like myself). I have only this and a CAI. Works for me. No plans for any other mods.
post #14 of 31 Old 05-16-2017, 05:09 PM
Quoted: 42 Post(s)
until i can pass emissions with haltech i cannot have it. ya also AC. this is my daily my "racecar" gets all the toys (emissions exempt)
johnzm is offline
post #15 of 31 Old 05-17-2017, 05:10 AM
This rev hang issue. Is it a hit and miss problem with the genesis coupe? My 2010 3.8 has never had this problem.
Genesis10000 is offline
post #16 of 31 Old 05-17-2017, 04:24 PM
Triumph TR6 1974
TR6Quebec's Avatar
Anybody else having tried this Sprint booster v3 ? Seems too fantastic to beleive......!
Robert
Triumph TR6, 1974 (Mimosa - OD)
Genesis Coupe 2.0T - Tsakuba - Premium / 6M - 2014
TR6Quebec is offline
post #17 of 31 Old 05-17-2017, 06:09 PM
I ordered the cheaper TROS one the other day and should get it by the weekend.
post #18 of 31 Old 05-17-2017, 06:21 PM
Quoted: 76 Post(s)
Ive had my Sprint booster V3 installed for about 2 months after reading this thread. Totaly worth every cent. Search for the You tube video on it, it will give you a better idea of what its actualy doing.
lvdukerider is offline
post #19 of 31 Old 05-17-2017, 07:44 PM
Triumph TR6 1974
TR6Quebec's Avatar
TROS.....Can you be more explicit? What is this system?
Robert
post #20 of 31 Old 05-18-2017, 04:15 AM
Electronic Throttle Accelerator_Shenzhen TROS Technology Co., Ltd
https://www.aliexpress.com/store/pro...763594136.html
Rev Hang Squanchy 2.0T Discussion 2013 and up 22 08-15-2014 05:02 PM
Rev Hang fonque 2.0T Discussion 2008-2012 7 04-14-2014 09:53 AM
Rev hang port? Whitewashed 2.0T Discussion 2013 and up 4 08-11-2013 01:29 PM
Rev hang gmal Engine 3 05-10-2010 05:01 PM
Should the Rev-Hang be a recall? 3hhh 2.0T Discussion 2008-2012 10 02-18-2010 06:44 AM
