Traction Control off FOR GOOD? - Hyundai Genesis Forum
post #1 of 20 Old 10-05-2011, 05:20 PM Thread Starter
sobe3yourself's Avatar
I've looked at other threads regarding the traction control, but cannot seem to find an answer to this.
My question is if there is a way to turn the TC off and keep it off. It turns back on whenever the car turns on. Any way around this?
sobe3yourself is offline
post #2 of 20 Old 10-05-2011, 05:29 PM
Uses Search Button
Msteve121's Avatar
I believe anything that permanently disables your traction control will also disable your ABS.
Msteve121 is offline
post #3 of 20 Old 10-05-2011, 06:11 PM
Quoted: 287 Post(s)
this
there's a module that basically "presses" the button when the car starts.
and IIRC there is a way to disable it.....
I think you put the car in acc mode ( not starting the engine) and holding the tcs button for like 30 sec. then start the car.
I personally haven't tried this, because I never get the OEM flash to update the ecu. So IDK.
post #4 of 20 Old 10-05-2011, 07:26 PM
You can get a module that will put the ESC in the mode it was in when the car was last shut off.
post #5 of 20 Old 10-05-2011, 10:00 PM
Take 'em Fei!
WildBill's Avatar
Quoted: 50 Post(s)
over/under time wise before OP comes back posting about fubaring the car due to TCS being off?
Senior Member of the Genesis Coupe High Mileage Club
2010 Hyundai Genesis Coupe 3.8L V6 Track M/T in Mirabeau Blue (Eva) - Retired
Bought - 25 miles, Retired - 145,000 miles, Total Miles - 145,000 miles
2012 Hyundai Genesis Coupe 3.8L V6 Track M/T in Interlagos Yellow (Fei) - Active
Bought - 22,000 miles, Currently - 83,000 miles, Total Miles - 61,000 miles
Total Miles in a Genesis Coupe - 206,000 miles
WildBill is offline
post #6 of 20 Old 10-05-2011, 10:19 PM
SJ is the man
JewishThunder's Avatar
Weekend tops.
Joe's milkshake brings all the boys to the yard...
I AM SPECIAL!
JewishThunder is offline
post #7 of 20 Old 10-05-2011, 10:20 PM
Threept8GC's Avatar
Quoted: 67 Post(s)
rip out your tc button
Threept8GC is offline
post #8 of 20 Old 10-05-2011, 10:32 PM
I've been driving for over 40 years. This is the first car I've had with the Electronic Stability Control. Some how I've managed to drive without it. The only reason I drive with it now is I'm too lazy to think about turning it off every time.
post #9 of 20 Old 10-06-2011, 03:50 AM
Dave C's Avatar
You know, I keep seeing this "too much trouble pushing the button" problem. If your driving on the street makes me wonder if your too lazy to use your turn signal or turn on your headlights or not bother to look before changing lanes.
Yea sometimes the TC bugs me too but I'm getting used to it. I've been driving over 50 years and learned a long time ago things can and do improve. I'll push the button off sometimes when appropriate.
At least it's not like the airbags going off in the camaro when you do a little drifting. See autoblog.
I'd go on but you either get it or you don't.
GenSport Carolina is like a fine wine,
it gets better with age.
Hellbender, Faster than a speeding ticket.
"Dragon" Tuned by SFR 2012
Dragonslayer
Solo Spring 2010
GenSport Fall Run 2010 (inaugural), 2011, 2012
GenSport Spring Run 2011, 2012
2010 Nord 3.8 Track Auto ZF
35% tint
Wing Badges all around
B&M Trans Cooler
Michelin Pilot Sport Plus
Wolo hi/lo horn
EBC "yellow" pads
Dave C is offline
post #10 of 20 Old 10-06-2011, 03:53 AM
Experienced drivers don't need ESC because they know what it takes to need it and avoid that situation.
post #11 of 20 Old 10-06-2011, 07:22 AM
Cobra Jet's Avatar
more info if you care to read:
http://www.gencoupe.com/electrical-w...esc-100-a.html
[B]- Phil
2016 Mustang Fastback Premium EB/PP, 1994 Cobra coupe #0013, 2011 Genesis Coupe (TRADED IN, bye, bye!)
Cobra Jet is offline
post #12 of 20 Old 10-06-2011, 08:38 AM
future 14 2.0t rspec
only1db's Avatar
pull the fuse. dont need ABS either....if you modulate your foot...you can stop quicker without ABS.
just trolling till i get my 14 2.0t rspec.
only1db is offline
post #13 of 20 Old 02-16-2017, 09:10 AM
I'm posting this since I've been looking all over the internet for a solution. I've found it so I'm sharing it.
First, I have a Genesis 2016 coupe 3.8 gt. Second, I do not know if it works for other years, models, flavours...
There are 2 "stages" of control on my car. There's stability control and there's traction control.
Here it is: on the lower left of the steering wheel, there's the button. Press it and you will disable the stability control. Press it again and you will enable it. Press and hold for 3-4 seconds and you will disable both - the stability and traction control. You get a confirmation every time in the display hud.
Have fun.
145545 is offline
post #14 of 20 Old 02-16-2017, 09:17 AM
ScottAtlanta82's Avatar
Quoted: 43 Post(s)
Have fun.
Just a slight clarification.... A single press turns off TCS, press and hold disables ESC. However, without a tune, it's always on to a degree...
ScottAtlanta82 is offline
post #15 of 20 Old 02-16-2017, 03:15 PM
Quoted: 133 Post(s)
there was somebody selling a cheap module over here to do the trick
personaly i used a digistump with a relay ...but the option on this forum was cheaper if i remember
here
ECS auto-off device "programmable"
genspec13 is offline
post #16 of 20 Old 02-16-2017, 05:24 PM
lol
Makes me feel like I'm a crazy person... For years, I've driven cars that did not have any driving aid at all. I know the feel... However if there's some sort of "control" still on, it's not enough to prevent full 360 burns on dry tarmac over and over again. I'll take a few pictures to show you. Hell, I'll shoot a video. I'm sure it's gonna help the ones who have my year and model. Cheers!
145545 is offline
post #17 of 20 Old 02-16-2017, 07:14 PM
Quoted: 43 Post(s)
lol
LOL, congratulations, we're all very proud of you! Now go do some research... There's more to the system than just that.
Oh btw, I have your year and model... And your search skills need work since this revelation of yours is in the owner's manual... Oh, and the 6 yr old thread you revived predates the BK2... Smdh...
</thread>
post #18 of 20 Old 02-17-2017, 04:11 AM
My apologies.
145545 is offline
post #19 of 20 Old 02-17-2017, 05:29 AM
BeepBoop's Avatar
Quoted: 29 Post(s)
</thread>
No need to come off condescending. Just point them in the direction of "some research" material and move on.
For anyone else interested in abs/esc removal, removing the abs block will drop the vss over canbus so be prepared to have an alternative gauge or dash available for speed. Racecapture is a great inexpensive alternative for gps speed/data logging.
BeepBoop is offline
post #20 of 20 Old 02-17-2017, 06:33 PM
Quoted: 43 Post(s)
Be a dick to me, I'm a dick back to you... And I was to him. So, it's all good :-)
traction control wtf Kahij Wheels, Tires and Brakes 2008-2012 26 09-21-2010 09:46 AM
Traction Control round3 3.8 V6 Discussion 2008-2012 16 01-22-2010 11:30 PM
Who uses the traction control hkerekes Suspension 2008-2012 23 10-22-2009 12:59 PM
Traction control off = no traction. hkerekes Suspension 2008-2012 20 06-04-2009 02:01 PM
Traction Control? ajc General Discussion 14 01-28-2009 07:39 AM
