91 octane vs 87 fuel - Hyundai Genesis Forum
post #1 of 46 Old 12-29-2011, 09:31 AM Thread Starter
mewang's Avatar
Hi guys just curious if anyone has tried the 91 octane fuel with better results than standard 87 octane. I have a 3.8L 2010 Track with an Ark Exhaust and CAI Injen. Just sitting at the gas station fueling up yesterday I always wondered about this question and whether or not it's worth adding 20 cents to gas prices.
I'm pretty sure this question has been asked before but I've tried doing the search and could not find any threads. If you can direct me to the thread that'll be great.
2010 3.8l Track RED
Ark Exhaust
Injen CAI
mewang is offline
post #2 of 46 Old 12-29-2011, 10:12 AM
i think u do get better performance. i saw it in the 2013 thread.
ppl said u get 210 bhp with 87, while u get around 220 with 91?
idk someone confirm.
cywy415 is offline
post #3 of 46 Old 12-29-2011, 10:23 AM
Wants to go back to Cali
SoullessSin's Avatar
You probably won't tell any difference between performance of 87/91. I personally been running 93 ever since I bought my car. I also had SFR tune my car to 93 when I got it flashed. You'll see people around this forum saying this or that but "f" it, if it's 20 cents more, then why not?
Also there's a ton of threads like these
"My coupe is my sanity"
2011 Nord Gray 3.8 Track
Megan Racing Transmission Mount-LED Angel Eye-Modified 2nd Cats-SFR Rigid Collar-System Upgrade Headers-Vega Type 1-TSW-BC Racing-Grimmspeed Phenolic Spacer-NST Pulleys-Ralco STS-SFR 1.5 Refrash-7ism Race CBE-"Coupe GT" Rear Badge-Blox Racing 490 Knob-GC Tuner Carbon Rear Diffuser-Injen CAI
SoullessSin is offline
post #4 of 46 Old 12-29-2011, 10:25 AM
geneslide's Avatar
The fuel rating only makes a difference if you r engine would miraculously detect the octane, retune to adjust timing, fuel trim and possibly boost pressure to increase the pressure (compression) in the combustion chamber/cylinder. The octane rating basically let's you know how much you can squeeze the fuel before detonation, but will not cause any difference in performance unless 87 causes detonation and 91I doesn't which isn't in the case of our stock cars.
2012 KW 2.0T R-Spec
R.I.P. SoCalChino ~ You will be missed at the meets and forever remembered as a passionate and revered community member. God Bless
geneslide is offline
post #5 of 46 Old 12-29-2011, 10:28 AM
geneslide's Avatar
For the cars who have had their ecu reflashed/tuned with higher boost then 91 would be needed.
2012 KW 2.0T R-Spec
post #6 of 46 Old 12-29-2011, 10:40 AM
use search before starting new thread.
/thread
Subversion is offline
post #7 of 46 Old 12-29-2011, 10:41 AM Thread Starter
mewang's Avatar
Thanks for the responses. I actually found the other thread by googling it not using this search option but anyway they say that since they modded their cars like mine with the Ark Exhaust and Injen CAI 91-93, it could possibly show an improvement.
I'll give it a shot today and see how it feels. I've been driving on 87 ever since I've owned the vehicle and before the mods so I will sure be able to tell if there is a difference.
2010 3.8l Track RED
Ark Exhaust
Injen CAI
mewang is offline
post #8 of 46 Old 12-29-2011, 10:51 AM
i'm on one
hydroponik's Avatar
I just started using 91 octane for about a month and I haven't noticed any improvement in gas mileage or performance.
2011 Bathurst Black 3.8 Track
hydroponik is offline
post #9 of 46 Old 12-29-2011, 10:53 AM
Same with me. That's why Im back to 87.
nobb is offline
post #10 of 46 Old 12-29-2011, 10:58 AM
geneslide's Avatar
I will reiterate my point. A CAI and exhaust isn't going to be affected by octane because its not changing the overall cylinder pressure. When your cylinder pressure is increased during the compression cycle above stock then you would need a higher octane if you experience detonation. If you do not experience detonation you wont benefit from spending the extra money except having to carry a lighter wallet.
2012 KW 2.0T R-Spec
post #11 of 46 Old 12-29-2011, 11:00 AM
Jedi Master
cris90's Avatar
it's already been dyno proven 93 offers more power, and i went from 87 to 93 and i noticed a difference. it takes about 2 fill ups first but there is a substantial difference. I noticed a difference
Fav. JT Quote
cris90 is offline
post #12 of 46 Old 12-29-2011, 11:20 AM
Advenio Pariter
TsukubaRed_PA's Avatar
Quoted: 361 Post(s)
My mileage went up. The ECU DOES detect higher and lower octane from the knock sensor and adjusts the timing advance accordingly. Give it a tankful or more to adjust. My Stealth from 20 years ago did this! Hyundai advertises 223 HP with premium fuel, but most of their advertising is for regular fuel so as not to scare off potential customers. I use mid grade most of the time and I get better mileage. I think the alcohol raises the octane rating a bit too. In the hot summer months I often put 91 / 93 in. My tail pipes are cleaner and the engine does run better. I went back and forth to confirm better mileage and I now stick with higher octane as it more than pays for itself.
A lot of threads on this very subject. It has been beaten to death.
2011 Base 2.0T, 5AT
Trunk Lip Spoiler
Fog Lights
Uniq Rigid Collars
JEGS Oil Separator - Turbo
Dynamat Hoodliner
Warranty: New Tails
2013 Elantra GT, 6AT (hers)
-- previous rides --
Salsa Red 2004 Vibe GT 6MT
TsukubaRed_PA is offline
post #13 of 46 Old 12-30-2011, 07:46 AM
Quoted: 32 Post(s)
those of u saying theres more power and better efficiency, prove it please. esp those throwing out hp numbers...
2012 3.8 Track
LOUISSSSS is offline
post #14 of 46 Old 12-30-2011, 07:48 AM
Zosyn who?
cleangencoupe's Avatar
i get better mileage
cleangencoupe is offline
post #15 of 46 Old 12-30-2011, 08:06 AM
The computer in the car "learns" if you are using better fuel. It will advance the timing to a predetermined max until it sees knock. More timing = more power, to a degree.
Juice is offline
post #16 of 46 Old 12-30-2011, 08:24 AM
Gymkhana's Avatar
As juice says... YES the ECU is designed to accept regular but it prefers premium. Manufacturer says so, that should be enough...
But there's more; many regions have ethanol in fuels at various percentages between up to %15 ethanol has high octane rating but contains much less energy per volume vs gas. Basically it's like watered down gas... (watered down with GMO corn fermented and distilled at huge environmental cost, to "save the environment..")
ethanol displaces oil and "cleans" your cylinder walls of it's protective film. Kills engines...
Around here it says right on the pump "may contain up to %10 ethanol" Some vendors know we don't like ethanol so they don't put any in their 91 octane; you'll see a sign 87 = up to 10% 89 up to 5% and 91 = no ethanol.
if at all possible, avoid ethanol.
My car folds cats
Gymkhana is offline
post #17 of 46 Old 12-30-2011, 08:31 AM
e85 is great I'm not sure what you're smoking, lol
If possible I'd like to run my car on e100.
Juice is offline
post #18 of 46 Old 12-30-2011, 08:42 AM
Gymkhana's Avatar
Lots of things. None of which arw GMO...
E85 has very high octane therefore when you tune for it yields great power but you need a hell of a lot more of it to make that power than you would equally rated race fuel.
Its cost isn't really lower and it's social/environmental repercussions are just retarded...
My car folds cats
Gymkhana is offline
post #19 of 46 Old 12-30-2011, 09:21 AM
슈퍼 쿠페 ^_^
Snoopy0812's Avatar
Quoted: 89 Post(s)
2.0t guys need to stop responding to a 3.8s question. Unless you own both engines dont reply like you know what you're talking about.
Snoopy0812 is offline
post #20 of 46 Old 12-30-2011, 09:23 AM
Gymkhana's Avatar
My response is universal
My car folds cats
Gymkhana is offline
Any advantage to using higher octane fuel in stock 2.0T? coupefan 2.0T Discussion 2008-2012 25 04-25-2012 11:25 AM
Oil and Octane CG-Coupe 3.8 V6 Discussion 2008-2012 20 10-29-2011 01:50 PM
Fords Octane Academy Series Coming To FUEL TV AutoGuide.com AutoGuide.Com News 0 09-26-2011 04:10 PM
91 octane gas stevie 2.0T Discussion 2008-2012 4 10-04-2010 03:02 PM
