oil pressure gauge install help?? - Page 2 - Hyundai Genesis Forum
 3Likes
post #21 of 34 Old 12-13-2016, 02:12 PM
MZ777's Avatar
Quoted: 142 Post(s)
Well, I liked the T idea for the pressure sensor and I was going to drill and tap at that blank spot on the top for the temperature sensor. I am currently using a sandwich plate adapter... Wanting to get rid of it...
MZ777 is offline
post #22 of 34 Old 12-13-2016, 02:26 PM
That adapter is what I have. You can put the OE bstp oil pressure light sender on one port and a npt sender on the other. Fits good, easy to install.
post #23 of 34 Old 12-13-2016, 04:49 PM
MZ777's Avatar
Quoted: 142 Post(s)
I need two ports and the adapter provides only 1
Sent from my ZTE A2017U using Tapatalk
MZ777 is offline
post #24 of 34 Old 12-14-2016, 06:26 AM
Two ports for what? I though the temp sender was going in the drilled and tapped hole?
post #25 of 34 Old 12-14-2016, 09:58 AM
MZ777's Avatar
Quoted: 142 Post(s)
So, this adapter connects to the OE turbo oil feed port? The OEM pressure sensor is bigger in size, so I assume it stay untouched?
MZ777 is offline
post #26 of 34 Old 12-14-2016, 10:03 AM
No it goes where the OE sender is, the npt sender will go in the middle and the OE sender will go on the end.
OE sender is 1/8" x 28 BSTP, my electric sender is 1/8" x 27 npt.
MZ777 likes this.
post #27 of 34 Old 12-16-2016, 11:24 AM
MZ777's Avatar
Quoted: 142 Post(s)
Seems legit. How much did you pay for the adapter? I see some for about $20, some for less.
MZ777 is offline
post #28 of 34 Old 12-16-2016, 11:27 AM
It's $20 shipped on ebay.
MZ777 likes this.
post #29 of 34 Old 12-16-2016, 11:28 AM
MZ777's Avatar
Quoted: 142 Post(s)
How long does it last so far?
MZ777 is offline
post #30 of 34 Old 12-16-2016, 11:32 AM
I got it in April. I don't see it failing like a brass pipe thread.
post #31 of 34 Old 01-10-2017, 06:41 AM
GenCoupeBoricua's Avatar
I was doing an install on a friends BK2 2.0. He already had the OEM oil pressure sender in the hole there, I removed it because we were doing a guage swap to AEM. Is it used for anything else besides the guage?
Anyways when I tried to thread the AEM oil pressure sender it did not want to thread in at all. Are they different sizes?
I know on my BK1 2.0 I didn't have this issue.
GenCoupeBoricua is offline
post #32 of 34 Old 01-10-2017, 07:46 AM
Gen Coupe do not have NPT threads on the sender it is 1/8" BSTP. You can force it in like you did on the BK1 but you are cross threading the aluminum when you do. Better to get a steel BSTP x NPT x BSTP if you want to also use the OE sender. Don't get brass for the adapter. I've broke two before going to the steel.
post #33 of 34 Old 01-10-2017, 10:45 AM
This makes sense now. Well now I need to fix my buddies mounted sensor. Probably best if I leave it as is. I also found a remote mount line to help make it install in a easier location: https://www.amsperformance.com/cart/...Unit-Line.html
But the right was would be to get an adapter for the BSTP to NPT. Got it.
post #34 of 34 Old 01-10-2017, 10:48 AM
Post 20 in this thread has what you need.
Has any1 performed an Oil Temperature Gauge Install? revcity 2.0T Discussion 2008-2012 42 06-29-2013 04:00 AM
Oil pressure sensor install RayLio 3.8 V6 Discussion 2008-2012 30 05-22-2012 02:01 AM
Oil Temp vs Pressure Gauge USMC Matt 0231 2.0T Discussion 2008-2012 10 05-10-2012 08:07 AM
FS Glowshift Black 7 Color Oil Pressure Gauge w/ Sandwich Adapter cowcow Interior 8 04-20-2012 06:44 AM
oil pressure gauge shadowcoupe 2.0T Discussion 2008-2012 0 06-20-2010 07:40 AM
