oil pressure gauge install help?? - Hyundai Genesis Forum
 3Likes
post #1 of 34 Old 06-24-2012, 10:12 AM Thread Starter
JMitch's Avatar
can someone please give me a parts list ( T connector size or not at all? extra hoses? etc...) and walk through for installing a oil pressure gauge on a 3.8? i have a GLOWSHIFT ELECTRICAL BAR OIL PRESSURE GAUGE and the frog eye pod from importshark.
JMitch is offline
post #2 of 34 Old 06-24-2012, 08:16 PM
CrownRoyal79's Avatar
First find the oil pressure sensor, probably on the oil filter housing. Then get the VDO oil/temp/pressure fitting. It threads perfectly into the housing. Then you will just run your wires then install your sensors and your done.
Legal Disclaimer: Anything that I or anyone else says about my vehicle on this website (www.gencoupe.com or any affiliated or non affiliated sites), pertaining to modifications and/or events, is only to gain acceptance from my/our peers, and does not actually represent anything actually existing on my car or real world experiences, and thus, cannot be held against me in any issue, i.e. warranty claims, that may arise.
CrownRoyal79 is offline
post #3 of 34 Old 06-24-2012, 08:47 PM
슈퍼 쿠페 ^_^
Snoopy0812's Avatar
Quoted: 89 Post(s)
Snoopy0812 is offline
post #4 of 34 Old 06-25-2012, 06:01 AM
Originally Posted by Snoopy0812 View Post
This one? BRASS T FITTING ADAPTER FOR VDO OR AUTOMETER OIL TEMPERATURE AND OIL PRESSURE SENDING UNITS
I'm looking for a cheap non-permanent way to add my temp sensor.
Thats the very one! Mine has been in for over 2 weeks now and no issues. wrapped it in some thread tape and bam!! It is a tight fit thread so go slow you'll know when to stop.
post #5 of 34 Old 06-25-2012, 06:02 AM
Most senders are 1/8" NPT threads. You need to look at where you are going to tap in to see what kind of room you have.
There is no easy way to get coolant temperature other than OBDII. Oil temp is even harder.
That being said an oil filter port adapter is best for temp and pressure. For the coolant on the 2L I drilled and tapped the rear coolant pipe near the OEM temp sender. This was easy to do and did not require draining the coolant. You can easily plug it if you do not want to keep the sender there.
post #6 of 34 Old 06-25-2012, 06:04 AM
There is no easy way to get coolant temperature other than OBDII.? Oil temp is even harder.
Not sure where he asked about the coolant temp. There is PLENTY of room to use that fitting and both your factory and aftermarket sensor. I will take pictures when I get the car back stupid dealership. And I test fitted it before install and it worked fine.
post #7 of 34 Old 06-25-2012, 06:44 AM
I didn't know what sender Snoop was talking about so I just threw in both of them.
post #8 of 34 Old 07-09-2012, 11:22 AM
Here is the fitting I was talking about,
Installed with plenty of room.
post #9 of 34 Old 07-09-2012, 12:08 PM Thread Starter
JMitch's Avatar
I just bought the T fitting and a male end and i am going to try this tomorrow when i do my oil change. where exactly is the sensor?
Im asking because i read other threads and saw someone said it was hard to find and even harder to work with.
JMitch is offline
post #10 of 34 Old 07-09-2012, 01:12 PM
The Factory oil pressure sensor is screwed into the oil filter housing. You can't miss it, and no offense, but if people are having trouble finding the sensor, then they should not be working their car. The sensor comes out really easy I suggest an adjustable wrench to remove it.
The factory sensor is to the left in the picture and the autometer is to the right.
Just remeber it is going to be a "tight fit thread" Its going to go in very snug, don't over tighten the fitting as you may strip out the threads and not know it. I marked my fitting by drawing a line matching where the threads stopped showing wear so I didn't go too far.
post #11 of 34 Old 07-09-2012, 01:26 PM Thread Starter
JMitch's Avatar
this is my first oil change with my gen so i havnt been under there except to install the exhaust and intake and in the past ive used a sandwich adapter. but anyway heres the post i read were the guy said it was a pain to get to and no working room......just so u see where im getting this from.
Oil pressure sensor install
JMitch is offline
post #12 of 34 Old 07-09-2012, 01:42 PM
Trust me its not anyone near complicated that thread has made it!! Also as one other person pointed out and I saw immediatly!! He was referencing his power steering pump! :wtf:
Trust me when you goto change your oil you will see where the oil filter is, the sensor just above screwed into the housing where your oil filter is, is the factory oil pressure sensor.
I suggest going to the general section and down loading the 2.0 manual its free and will help you with your oil change as well.The picture you see I uploaded is what your going to see.
post #13 of 34 Old 09-25-2012, 10:16 AM
I have a 2.0 and the autometer mechanical oil pressure gauge. The fitting that came with it is much different. Anyone know if it would just go to the same location, or would I need this t fitting?
kesslersGen is offline
post #14 of 34 Old 09-25-2012, 10:26 AM
The OEM fitting is metric.
EDIT: Actually using my super duper Parker thread gauge identification kit it looks like a tapered 1/8" - 28 BSPT. Definitely is not an 1/8"-27 NPT thread.
post #15 of 34 Old 09-26-2012, 11:05 AM
If you are some what handy the 2L oil filter adapter comes off the block easily and the gasket is reusable. On top of the adapter you can see a flat cast in boss that's at ~45* angle that could be drilled and tapped for whatever. It's on the filter out side of the flow so it would be after any adapter plates and just above the OEM sensor.
post #16 of 34 Old 03-01-2013, 12:51 PM
The canadian aka 손영웅
Teamtos's Avatar
on my 2010 track here how i install my oil pressure..I used a BRASS T FITTING ADAPTER FOR VDO
You donít WORK!
You donít EAT!
You donít GRIND!
You donít SHINE!
Teamtos is offline
post #17 of 34 Old 12-10-2016, 08:44 PM
MZ777's Avatar
Quoted: 142 Post(s)
exactly what I wanna do, but don't want to reuse the gasket. Do you happen to have a part # for it?
MZ777 is offline
post #18 of 34 Old 12-11-2016, 05:38 AM
Originally Posted by mz777 View Post
exactly what i wanna do, but don't want to reuse the gasket. Do you happen to have a part # for it?
215242c200
MZ777 likes this.
post #19 of 34 Old 12-13-2016, 01:47 PM
MZ777's Avatar
Quoted: 142 Post(s)
These people are money hungry... The part is $13.25, $8.95 is USPS shipping and $5 handling fee because the order is less than $25. Really hate to deal with businesses like that. Are there any other places that sell something like this?
MZ777 is offline
post #20 of 34 Old 12-13-2016, 02:09 PM
I've had two brass nipples crack on me at the oil pressure sender port. Get a steel one.
Search for "1/8" BSPT Oil Pressure Sensor Tee to NPT Adapter Turbo Supply Feed Line Gauge T" on ebay
Has any1 performed an Oil Temperature Gauge Install? revcity 2.0T Discussion 2008-2012 42 06-29-2013 04:00 AM
Oil pressure sensor install RayLio 3.8 V6 Discussion 2008-2012 30 05-22-2012 02:01 AM
Oil Temp vs Pressure Gauge USMC Matt 0231 2.0T Discussion 2008-2012 10 05-10-2012 08:07 AM
FS Glowshift Black 7 Color Oil Pressure Gauge w/ Sandwich Adapter cowcow Interior 8 04-20-2012 06:44 AM
oil pressure gauge shadowcoupe 2.0T Discussion 2008-2012 0 06-20-2010 07:40 AM
