Yet another Nexus 7 Tablet Install * lots of documentation and pics* - Page 2 - Hyundai Genesis Forum
 8Likes
post #21 of 542 Old 08-27-2013, 12:56 AM
Great job! Thanks for the detailed write up! I plan to do this soon.
HailGC is offline
post #22 of 542 Old 08-27-2013, 05:19 PM
2012 3.8 Track ZF-6-SPD
Metal's Avatar
Do you plan on drilling a small hole in your ac vent to cool the tablet?
Engine
- UR Light Weight Pulley
- R2C SRI/P2R Spacer+Gasket
- Maxbore Bored TB+CC
- GS Spacer/PnP+CC Manifold
- AEM V2 Meth Kit
- BTR Custom Meth Tune
- Mishimoto Oil Cooler
- Boostec CF Front Lip
- NRG Canard
- M&S Side Splitter
- ViS CF Rear Diffuser
- ARK C-FX CF Grill
- ViS CF Fog Bezel
Chassis
- VOLK TE37SL/Hankook
- R1/StopTech/SS Lines/Dot 4
- PSM Pro Coilover
- Luxon Strut Bar
- UR 4pt Rear Strut Bar
- SFR Rigid Collar Kit
Metal is offline
post #23 of 542 Old 08-28-2013, 04:04 AM Thread Starter
that guy
kepone's Avatar
Quoted: 82 Post(s)
No, I have no plans to ever drill into my AC, ever. I saw another guy did that and I wondered what the f*cking point was. I know that there is some worry about certain li-pol batteries overheating and catching fire, but why exactly would it overheat when you're in the car, engine running, and the AC is blowing or windows are open? The only worry about the distant, remote possibility of a li-pol battery overheating is when the car is off, windows closed, direct sunlight hitting the car, interior over 130 degrees, etc.. So if the only issues are when the car is OFF, what's the point of drilling holes in your AC system? Exactly none.
On another topic though, has anyone ever thought of using a 12v-AC inverter to power the Nexus instead of the 12v-usb thing? That would allow you to use the actual wall plug in nexus charger , which would definitely always keep it charging faster than you need.
The Powergen charger is a piece of crap, and does not charge the nexus worth a damn. I already ordered a different 12v-usb adapter. Definitely DON"T GET THE SHITTY POWERGEN.
This is what I am thinking of trying next, maybe not this specific one, but along these lines
'12 2.0T 6SP - ???whp
USRT Genesis II 1200cc
Tuned by Dardan Tuning
Grimmspeed Ported Intake Mani
Haltech
GarageLine STS
CC Stage 2 kit
Saikou Michi Catch Cans
Whiteline FSB
Bilstein B8
Progress Springs
#KHARTUNERZ
#ITSNEVERFINISHED
kepone is offline
post #24 of 542 Old 08-28-2013, 09:10 AM Thread Starter
that guy
kepone's Avatar
Quoted: 82 Post(s)
Amazon (Links)Amazon (Links)
It was $28 including 1 day shipping using Amazon Prime
I think this will be perfect. I get wall outlet full speed charging.
Haltech
GarageLine STS
CC Stage 2 kit
Whiteline FSB
Bilstein B8
Progress Springs
#KHARTUNERZ
#ITSNEVERFINISHED
kepone is offline
post #25 of 542 Old 08-28-2013, 09:18 AM Thread Starter
that guy
kepone's Avatar
Quoted: 82 Post(s)
Oh before you guys ask- the reason I chose that specific one ( i just checked out about 100 different ones on amazon ). It's small, has no internal cooling fan, barely gets warm, operates silently, and only provides the power I need ( 30 watts max ) so there's no real risk of popping fuses or anything burning out. I think this will definitely work very well!
Haltech
GarageLine STS
CC Stage 2 kit
Whiteline FSB
Bilstein B8
Progress Springs
#KHARTUNERZ
#ITSNEVERFINISHED
kepone is offline
post #26 of 542 Old 08-28-2013, 11:16 AM
Metal's Avatar
I remember a guy mentioning he used a power investor in the nexus 7 installed thread.
Engine
- AEM V2 Meth Kit
- NRG Canard
- M&S Side Splitter
- ARK C-FX CF Grill
- ViS CF Fog Bezel
Chassis
- PSM Pro Coilover
- Luxon Strut Bar
Metal is offline
post #27 of 542 Old 08-28-2013, 12:38 PM
losses control easily
Unstablementaly's Avatar
The USB charger I bought was an Enercel 4.2amp model. Dual USB charging @2.1amps each port. My plan on it was to break it apart, solder in 2 leads to the power pick ups for the cig adapter and hard wire back to a dedicated 12v source with inline fuse. This way your tablet is always getting juice whether the car is on or not. It can be hidden away behind the control bezel and secured to something with zip ties so not to bounce around and be annoying. Of course, you'll have to find a different method for Tasker or Automate to send the tablet to sleep mode and shut down any running apps.
2013 Monaco White 2.0T Premium
Watching you two type back and forth in your broken ass english is like watching two deaf old people try to have a conversation in different rooms.
PSM Coil overs
Niche Targa 19x8.5+25F/19x10+25R
Sumitoma HTR ZIII 245/35F 275/35R
Gutted hood vents
CP-E Catback Exhaust w/black chrome tips
Unstablementaly is offline
post #28 of 542 Old 08-28-2013, 11:10 PM
segagenesis's Avatar
excellent write up, cant wait to get try this myself. One question i have tho, down the road if i decide to go back to stock, will the factory bezel fit? or is it going to be all messed up because of the cutting that had to be done to get the new bezel to fit?
segagenesis is offline
post #29 of 542 Old 08-29-2013, 04:39 AM Thread Starter
that guy
kepone's Avatar
Quoted: 82 Post(s)
The factory bezel might actually still fit, you do have to cut off the lower two mounting tabs, but the two on the side are still there. The top part will go back no problem, the front part should still be able to be held on by two clips.
Haltech
GarageLine STS
CC Stage 2 kit
Whiteline FSB
Bilstein B8
Progress Springs
#KHARTUNERZ
#ITSNEVERFINISHED
kepone is offline
post #30 of 542 Old 08-29-2013, 06:00 AM
'11 3.8 Silverstone
rogkum's Avatar
Nice write up man. I'm using a power inverter with my Acer A100 at the moment, no probs. I plan to use it with my Nexus 7 FHD too once it comes in. Technically using an inverter is a little inefficient, because you're converting dc to ac then back dc again. It works well though so I guess it's not a big deal.
rogkum is offline
post #31 of 542 Old 08-29-2013, 06:51 AM Thread Starter
that guy
kepone's Avatar
Quoted: 82 Post(s)
So I decided to pull the tablet out of the car last night, and unlock and root it.
I used Wugs Toolkit to do the unlock and root. You can get it here:
[Toolkit] Wug's Nexus Root Toolkit v1.7.2 [Updated 08/26/13] - xda-developers
Pretty easy process but it took a while.
ProTip: If you use Windows 8, use the RAW Driver option when you do the USB driver setup.
The downside is that rooting and unlocking wiped my device, and I have to start all over again with the configuration..
The second downside is that once you're rooted, an Over the Air update will wipe out your root and put you back to an un-rooted status.
The upside is that the rooting, as far as my particular install goes, is that it opens up new options in AutomateIt, such as the ability to set macros for airplane mode and gps radio on/off, among other things.
Also, if you select the "custom recovery" option, it will disable OTA updates and you don't ever have to worry about losing your root.
The app itself is pretty easy to use, not quite iOS jailbreak easy, but not brain busting either. It took me under an hour to figure it all out and get it done the first time through
So I have now added the rules:
Power disconnected- disable gps
Power connected- enable gps
I tried setting Airplane Mode with the rules, since it shows up in AutomateIt now, but it didn't seem like it was working, so I went back to setting individual rules for each wireless radio. If I could get that airplane mode rule working properly, you could really simplify the rules, down to about 6 total.
I think my AC inverter will be delivered today!
Haltech
GarageLine STS
CC Stage 2 kit
Whiteline FSB
Bilstein B8
Progress Springs
#KHARTUNERZ
#ITSNEVERFINISHED
kepone is offline
post #32 of 542 Old 08-29-2013, 02:55 PM
Metal's Avatar
What are your thoughts on this charger.
http://www.scosche.com/chargers/powe...ia-920-charger
Also I didn't find the "Kensington ground loop isolator" but a "Kensington noise reducing aux cable" instead on amazon. It looks exactly the same but costs $15?
How many feet would you say your Kensington was short by.
Engine
- AEM V2 Meth Kit
- NRG Canard
- M&S Side Splitter
- ARK C-FX CF Grill
- ViS CF Fog Bezel
Chassis
- PSM Pro Coilover
- Luxon Strut Bar
Metal is offline
post #33 of 542 Old 08-29-2013, 10:36 PM
Cece's Daddy
ShaverZBT's Avatar
Kepone, Can't thank you enough for the shopping list. Bought all on Amazon it will be here tomorrow. I have a Magellan installed now, so this will be a great upgrade.
ShaverZBT
SOLD
2012 Genesis Coupe 200T
Bathurst Black | Wing Emblems | K&N Drop-in | Niche Targa M130 19" Rims
Nexus 7 2nd Gen Tablet | iPod Nano 8GB | Tint 15R/20F
ShaverZBT is offline
post #34 of 542 Old 08-30-2013, 03:26 AM Thread Starter
that guy
kepone's Avatar
Quoted: 82 Post(s)
The Duracell mini inverter unit seems to work well so far, fits well in the area below the shifter panel also. I'm sending back the powergen and the iflash 12v-usb chargers.
Metal, go the inverter route. Let me have a few more days to test it ( up to a week maybe ), but it seems to be the best option. That schosche you posted is the third one I had considered, but then I decided to chance it and go with the inverter.
The Kensington noise reducing aux cable is the correct one, it's really a ground loop isolator just with a different name. You can really buy any ground loop isolator, they all work exactly the same. I just picked the Kensington because it's small, and the cable is tangle free and fabric braided so it's easy to route it. It was definitely too short by at least 3 feet.
Haltech
GarageLine STS
CC Stage 2 kit
Whiteline FSB
Bilstein B8
Progress Springs
#KHARTUNERZ
#ITSNEVERFINISHED
kepone is offline
post #35 of 542 Old 08-30-2013, 01:25 PM
Metal's Avatar
I don't have the home adapter so my best choice would be to buy a car adapter instead if buying the inverter and home adapter. I was able to find a seller on eBay for the original dual USB charger from scosche that everyone uses.
Engine
- AEM V2 Meth Kit
- NRG Canard
- M&S Side Splitter
- ARK C-FX CF Grill
- ViS CF Fog Bezel
Chassis
- PSM Pro Coilover
- Luxon Strut Bar
Metal is offline
post #36 of 542 Old 09-01-2013, 11:04 AM
mgsalvad's Avatar
i wouldn't bother will these giant adapters.
just buy a 12v usb cigarette lighter that's 2.1 amps and blam you'll never get your battery dying again
-=MARK=-
"LGHTSABR"
| Chrome Wing Emblems | Varrstoen ES2.2.2 Matte Black | M&S Type D Front Grille | VIS AMS CF Hood | DD Stage 2 LED's | Grimmspeed Front Plate Relocate | Custom CP-E CBE + GT Custom downpipe | Synapse BOV | Depo Racing FMIC Kit | In-dash tablet | AEM CAI | Black Housing Headlights | Carbon Creations Duraflex Front Lip | SFR Custom Tune | Aerocatch Hood Pins | Fiamm "El Grande" Horns | Blue Footwell LED's | Sequence Spec-1 Side Skirts | Ixion Rear Diffuser
mgsalvad is offline
post #37 of 542 Old 09-01-2013, 11:16 AM
mgsalvad's Avatar
btw the home adapter it comes with is only 1.35amps compared to the cigarette ones you can get which are 2.1amps (aka quick chargers)
-=MARK=-
"LGHTSABR"
mgsalvad is offline
post #38 of 542 Old 09-01-2013, 12:00 PM
Timbit Biter
Torsen's Avatar
Quoted: 68 Post(s)
Any way to do this install on a car that has the factory navigation? Yeah, I didn't think so...
2016 Ford Mustang GT PP
2011 Hyundai Genesis Sedan 4.6 (daily driver)
2007 BMW M5 *sold*
2011 Ford Taurus SHO (twin turbo) - Livernois Stage 4 Tune *sold*
2013 3.8 Track 8AT *sold*
Torsen is offline
post #39 of 542 Old 09-01-2013, 05:37 PM
J-ShaZzle's Avatar
Quoted: 36 Post(s)
Yes. I know Gary (dbigboi) has it done. You loose access to your hazard button and the air bag light gets tucked in behind the console as well. The hazard button could be extended and located somewhere else. I don't think anyone has done this yet though. I would imagine that using the blank button under the TSC would be the cleanest solution but your still without the airbag light.
Silverstone 3.8L A/T Base
SFR | DIODEDYNAMICS | GCTUNER | MISHIMOTO | BTRCC
Owner of Hyundais since 2002.
J-ShaZzle is online now
post #40 of 542 Old 09-01-2013, 05:57 PM
Metal's Avatar
I'll post pics when I get my parts in.
Engine
- AEM V2 Meth Kit
- NRG Canard
- M&S Side Splitter
- ARK C-FX CF Grill
- ViS CF Fog Bezel
Chassis
- PSM Pro Coilover
- Luxon Strut Bar
Metal is offline
Google nexus 7 tablet install necco24 Interior 2008-2012 844 01-10-2017 09:46 AM
Nexus 7 tablet install polishprince Electrical & Wiring 2008-2012 13 04-03-2014 04:27 PM
Nexus 7 Tablet Install Power Button? Titan69@UNIQ Performance Electrical & Wiring 2008-2012 4 07-27-2013 09:40 PM
nexus 7 tablet set up drop of ice Ontario 21 07-05-2013 01:10 PM
PRW FMIC Kit install *lots of pics* 2012-Rspec 2.0T Discussion 2008-2012 27 08-30-2012 02:01 PM
