Yet another Nexus 7 Tablet Install * lots of documentation and pics* - Page 8 - Hyundai Genesis Forum
 8Likes
post #141 of 542 Old 10-09-2013, 10:18 AM
sry guys havent been on in a few...a few ppl PM'd me for the plexi bezel but it is already sold.. sry, however go to home depot, costs a few buck for a small piece of plexi, use double sided tape to attach the metal bracket you want ot replace to the piece of plexi and cut the plexi out to shape..easy as pie...
Red 2010 Genesis Coupe 2.0t Track
GO:
3" Custom Intake~2.5" Custom Hard Pipes and FMIC~ CPE 3" catless DP~CPE 3" Catback~DW 550cc injectors~PA Reflash w/ Beyond Redline stage 2+ tune~HKS SSQV~RRM CF A-pillar pod~AEM boost gauge~AEM wideband
SHOW:
Prodigy front lip~Sequence side skirts~Sequence fog inserts~Sequence GT spoiler~black out tails~Sarona grill~Seibon SC CF Hood~Eibach Pro-Kit~Full Rebadge~
python6586 is offline
post #142 of 542 Old 10-09-2013, 10:43 AM
Severed member
sd_davis's Avatar
^Money!
- PRW FMIC & Piping kit
- CP-E differential mounts
- K&N Typhoon SRI; Forge BOV
sd_davis is offline
post #143 of 542 Old 10-09-2013, 10:49 AM Thread Starter
that guy
kepone's Avatar
Quoted: 82 Post(s)
I would actually not recommend doing that, unless you know how to cut plexi. It splinters/shatters very easily. You need mad dremel skills if you want to do that by hand. When I was into car audio stuff a lifetime ago, I could never get plexi cut right without damaging it, and I am a dremel ninja. I highly recommend taking it to a shop with the equipment necessary to do the job properly the first time. If you have no plexi cutting experience, you will go through many , many sheets of plexi before you get it right.
'12 2.0T 6SP - ???whp
USRT Genesis II 1200cc
Tuned by Dardan Tuning
Grimmspeed Ported Intake Mani
Haltech
GarageLine STS
ACT Fidanza Clutch/FW
Saikou Michi Catch Cans
Whiteline FSB
Bilstein B8
Progress Springs
#KHARTUNERZ
#ITSNEVERFINISHED
kepone is offline
post #144 of 542 Old 10-09-2013, 01:28 PM
Originally Posted by kepone View Post
You could use any 3.5mm audio cable, but the ground loop isolator cable will eliminate any noise that might pop up ( alternator whine, etc ). Try it and let us know if it works without introducing any noise into the audio.
I already have with my uNavi and I had no problem but I will probably buy a right angle ground loop isolator cable for this just in case.
I have not tried any GPS app on my N7 yet, how are you guys checking the satellites locking or not? Is it within the GPS app itself?
Finally, to the OP: have you decided to stick with the duracell inverter as that is working best?
zFlaSh is offline
post #145 of 542 Old 10-09-2013, 03:22 PM Thread Starter
that guy
kepone's Avatar
Quoted: 82 Post(s)
Yes for me, the duracell inverter has worked the best. My nexus battery has not died since I installed it. Nothing seems to charge the N7 faster than the combination of 4G+GPS will drain it though.
Haltech
GarageLine STS
Whiteline FSB
Bilstein B8
Progress Springs
#KHARTUNERZ
#ITSNEVERFINISHED
kepone is offline
post #146 of 542 Old 10-09-2013, 04:27 PM
mgsalvad's Avatar
interesting update for you all experiencing battery problems.
me and my friend bought 90degree usb cables from ebay. we had nothing but issues where it says it charging but the % never goes up. i then tried the original usb cable that the nexus 7 came with and BAM! 100% never gone down. interesting how a thin usb cable can do that compared to the chick oem cable
lower "gauge"? maybe it can't transfer the juice at max efficiency?
-=MARK=-
"LGHTSABR"
| Chrome Wing Emblems | Varrstoen ES2.2.2 Matte Black | M&S Type D Front Grille | VIS AMS CF Hood | DD Stage 2 LED's | Grimmspeed Front Plate Relocate | Custom CP-E CBE + GT Custom downpipe | Synapse BOV | Depo Racing FMIC Kit | In-dash tablet | AEM CAI | Black Housing Headlights | Carbon Creations Duraflex Front Lip | SFR Custom Tune | Aerocatch Hood Pins | Fiamm "El Grande" Horns | Blue Footwell LED's | Sequence Spec-1 Side Skirts | Ixion Rear Diffuser
mgsalvad is offline
post #147 of 542 Old 10-10-2013, 04:29 AM
rodemax's Avatar
Originally Posted by Mathiasv91 View Post
Some people flip their tablet clockwise some counter clock wise. How is yours installed? If you have de tablet in portrait mode, do you go clockwise or counter clockwise?
Power cable out the left side, power button down works much better for me.
3.8L Base Model in Bathurst Black
rodemax is offline
post #148 of 542 Old 10-16-2013, 03:13 PM
AutocroSSer's Avatar
Replacing my (2 years old) Galaxy Tab 7.0 Plus Type-B install this weekend with a N7 install.
Most of the issues/complications/etc I'm seeing here are trying to "hack around" to make it happy with a fixed install. Better : just install a ROM INTENDED for Fixed Installs.
USB ROM for Nexus 7
Also installing with a 12V industrial powered USB Hub, "Fast Charging" enabled, automatic Cell phone data USB tether/charge (when I plug my cellphone into the USB hub), external small USB HD (mounted Read Only so no accidental USB disconnect = data corruption worries) with ALL of my music on it (well over 100GB), and external USB DAC Sound card (which is loads better sound quality than what comes out of the N7 headphone jack, Turtle Beach Micro II, $25ish).
Already have the ELM327 from the current tablet install, and if I run into GPS issues I'll just use the 10Hz external bluetooth GPS (that I already have for datalogging while autocrossing...this tablet will also be used for that using custom software called SoloStorm intended for datalogging while racing) mounted under the dash and USB powered.
Ed Runnion -- San Jose CA
2012 Hyundai Genesis Coupe R-Spec, 3.8L V6, Daily Driver and Autocross Toy
1996 Chevy Impala SS, not stock (engine, manual trans swap, suspension, etc etc etc)
2006 GMC Sierra 2500 HD, Duramax/Allison, Tow Rig, not stock either
AutocroSSer is offline
post #149 of 542 Old 10-16-2013, 04:39 PM
Severed member
sd_davis's Avatar
USB ROM for Nexus 7
Good info, albeit in some horrific runon sentences! :P
Seriously though, love the rom! Put up some pics when you are done.
Have you found a backup camera solution with that setup yet?
sd_davis is offline
post #150 of 542 Old 10-16-2013, 04:47 PM
Did you end up keeping the POWERGEN charger or replace it with something else?? I personally recommend getting a power inverter from autozone or walmart and plug in the nexus charger itself. This way, you won't need the ground loop and you won't hear that whining noise. But anyways lol. nice write up, very detailed
fastnite is offline
post #151 of 542 Old 10-16-2013, 05:01 PM
Sorry : engineer, not liberal arts major
In Theory you can use any USB video capture card that this ROM would recognize and then just pipe in the backup camera of your choice to it. It is "on the list" (and I already have a backup camera to try with it), but honestly not very high on the list.
post #152 of 542 Old 10-16-2013, 06:58 PM
Severed member
sd_davis's Avatar
Haha! Ditto; civil engineering; UF. Now a linux engineer... Which field are you in?
Ill wait then, as the backup camera is one of my favorite mods. Good luck and ill keep watching...
sd_davis is offline
post #153 of 542 Old 10-17-2013, 04:09 AM
The Dutch Guy
received tablet today, installing all saturday .
Mathiasv91 is offline
post #154 of 542 Old 10-17-2013, 09:12 AM Thread Starter
that guy
kepone's Avatar
Quoted: 82 Post(s)
No, I got rid of the POWERGEN charger, the Duracell mini inverter has been working the best for me so far
Haltech
GarageLine STS
Whiteline FSB
Bilstein B8
Progress Springs
#KHARTUNERZ
#ITSNEVERFINISHED
kepone is offline
post #155 of 542 Old 10-17-2013, 12:07 PM
OP, you mentioned about relocating the cigarette plug to the side of your shifter? can you post a pic of that please?
pbear is offline
post #156 of 542 Old 10-21-2013, 06:40 AM
The Dutch Guy
Install complete will post pics later!
post #157 of 542 Old 10-23-2013, 03:44 AM Thread Starter
that guy
kepone's Avatar
Quoted: 82 Post(s)
I relocated it to the side of the base of the shifter ( below the plastic panel and shift boot ). The duracell inverter is plugged into it, and it's laying to the left side of the bottom of the shifter, zip tied into place. You have to use the cigarette lighter to power the tablet, so it can't be mounted anywhere in the cabin. No pictures are really necessary here. There's nothing to really show lol.
Haltech
GarageLine STS
Whiteline FSB
Bilstein B8
Progress Springs
#KHARTUNERZ
#ITSNEVERFINISHED
kepone is offline
post #158 of 542 Old 10-25-2013, 04:15 PM
This looks like a sick mod!!! Gunna try this out. Anyone try this with the 2013 model nexus 7?
jyabor91 is offline
post #159 of 542 Old 10-30-2013, 06:16 PM
KidHanzo's Avatar
Kepone, you're my hero.
KidHanzo is offline
post #160 of 542 Old 10-31-2013, 04:18 AM Thread Starter
that guy
kepone's Avatar
Quoted: 82 Post(s)
It should work just fine with a 2013 model. I might upgrade mine to a 2013 model next year, in hopes of improved battery life while using cellular data lol.
Haltech
GarageLine STS
Whiteline FSB
Bilstein B8
Progress Springs
#KHARTUNERZ
#ITSNEVERFINISHED
kepone is offline
Google nexus 7 tablet install necco24 Interior 2008-2012 844 01-10-2017 09:46 AM
Nexus 7 tablet install polishprince Electrical & Wiring 2008-2012 13 04-03-2014 04:27 PM
Nexus 7 Tablet Install Power Button? Titan69@UNIQ Performance Electrical & Wiring 2008-2012 4 07-27-2013 09:40 PM
nexus 7 tablet set up drop of ice Ontario 21 07-05-2013 01:10 PM
PRW FMIC Kit install *lots of pics* 2012-Rspec 2.0T Discussion 2008-2012 27 08-30-2012 02:01 PM
