samsung galaxy tablet in car questions? - Genesis Forum: GenCoupe Hyundai Genesis Forums
Old 02-18-2012, 04:59 AM   #1
Siclanevo's Avatar
Default samsung galaxy tablet in car questions?
is anyone running a samsung galaxy tablet in thier genesis? I am debating on swapping my aftermarket headunit back to stock and just running a tablet, but I can't decide between the acer or the samsung. On paper the samsung looks better but can the samsung operate the normal home screens sideways instead of up and down. The reason I ask is because it will be installed sideways in the coupe. I have owned a couple samsung and android powered devices and the home screens are only orientated up and down and will not change if you turn the phone sideways. is this diferent with the updated systems?
Also what other accesories do you reccomend? obviously power cord, and audio out. I tried searching but could not find what I was looking for. Help, tips, or a DIY would be awesome. Also where is the best deal on the lcd relocate and the type b bezel?
R-Spec 2.0T slightly modded
LB Design & Performance
Siclanevo is offline   Reply With Quote
Old 02-18-2012, 05:30 AM   #2
ipimpslpmstngs
ipimpslpmstngs's Avatar
Why not do both? I did and I like it. I'm running the evo 4g view from sprint, and at the bottom portion under the head unit I did a custom gauge pod. I have the rspec so I don't have push button :-)
435whp/356wtq
TurboXs GT Series Turbo Kit W/
Forced Performance GT3076 76HTA Turbocharger
TurboXs Tuned 23PSI
Stock Block
ipimpslpmstngs is offline   Reply With Quote
Old 02-18-2012, 05:35 AM   #3
ipimpslpmstngs
Yeah get a tablet from Verizon,sprint,at&t. you get data, Bluetooth for torque app, GPS, and you can run Pandora radio,play music files, or whatever. I even made a external button to turn it off!
435whp/356wtq
TurboXs Tuned 23PSI
Stock Block
Old 02-18-2012, 05:37 AM   #4
ipimpslpmstngs
I forgot that if you keep aftermarket head unit you can run 3.5mm Jack to RCA splutter and plug it in the back of your headunit for sound!
435whp/356wtq
TurboXs Tuned 23PSI
Stock Block
Old 02-18-2012, 06:01 AM   #5
Doom Machine
ByByCavalier's Avatar
How ironic, I woke up this morning thinking the same thing, "will a Galaxy Tab fit and work?" lol!
I hear what your saying about the menus only being oriented "portrait" style, I don't think they can be adjusted to run "landscape".
I was wondering if there was a way to use a task manager (automator app of some kind) to automatically turn a tablet on/off when you turn the car on/off. I forget if the powered USB in the car is still powered when the car is off, or if it stays on. Anyways, just thinking out loud.
ByByCavalier is online now   Reply With Quote
Old 02-18-2012, 06:01 AM   #6
Siclanevo's Avatar
honestly looking for a straight tablet with wifi. I dont really need the 3g or 4g. If I want I can run it off my phone though. I'm looking specifically at the acer and the samsung galaxy 7.0 tabs. you can set them up to turn off when there is no powe cord charging (igntion on/off with cig lighter) so no external button.
I want to run the stock headunit, bc my headunit and a tablet together to me is overkill. Another reason for a wifi tablet is no extra bill a month. I can just use my phone to do everything the tablets do its just super small screen. My phone has almost better equipment then the acer tablet.
Old 02-18-2012, 06:03 AM   #7
Siclanevo's Avatar
the landscape issue is the only thing holding me back from the samsung right now unless I can get confirmation that the homescreens can be laid out in landscape style..... I was going to pick it up on the way home if I get some better info. I may also just go and play with one for a bit too.
Old 02-18-2012, 06:42 AM   #8
Doom Machine
Got it! Use the app "Go Launcher Ex" for Android. It lets you customize everything, and lets you switch from portrait to landscape mode in the home screen.
Old 02-18-2012, 06:54 AM   #9
how do u get that useless blue screen off?
and, where can you get a bezel to custom fit one of the android tablets? i'd just love to run torque and play some music from it.
also, is the tablet easily removable so i can take home to sync and remove to prevent theft?
2012 3.8 Track AT
LOUISSSSS is offline   Reply With Quote
Old 02-18-2012, 07:03 AM   #10
Doom Machine
I was going to say something but then i realized you must have NAVI right? For non NAVI owners, they usually relocate the blue screen to the spot in front of the shifter. That way you can still see your HVAC and all those other controls.
Not sure about owners with NAVI though.
Old 02-18-2012, 07:31 AM   #11
Siclanevo's Avatar
I will check out the app and possibly have my tablet soon! Thanks for the info!
Old 02-18-2012, 07:57 AM   #12
Doom Machine
If you do get this project going, keep us updated. Might try this in my coupe this summer.
Old 02-18-2012, 09:01 AM   #13
Photogineer
R4VEN's Avatar
Go with the Acer. After a LOT of tweaking..mine works exactly the way I want it to. The only exception is the autodimming once I got a car starter.
W: momentsmedia.ca
FB: facebook.com/momentsmedia
R4VEN is offline   Reply With Quote
Old 02-18-2012, 08:33 PM   #14
ipimpslpmstngs
A couple of apps to look into are orientation control and power manager. Check em out! Also use a fuse tap (add a circuit) and hook it up to either 10amp fog light fuse (constant power)
435whp/356wtq
TurboXs Tuned 23PSI
Stock Block
Old 02-18-2012, 08:39 PM   #15
Photogineer
R4VEN's Avatar
Wouldnt that drain nthe batt?
W: momentsmedia.ca
Old 02-19-2012, 09:43 AM   #16
Siclanevo's Avatar
To the people using dash command or torque what bluetooth adapter are you using and would you reccomend it? Trying to start gathering parts for my install now!
Old 02-19-2012, 05:19 PM   #17
Amazon.com: Bluetooth ELM 327 Diagnostics USB Cable: Camera & Photo Amazon.com: Bluetooth ELM 327 Diagnostics USB Cable: Camera & Photo
Amazon (Links)Amazon (Links)
this is the exact bt adapter that i am using. it works 100% fine with the free torque app and the paid version
2012 3.8 Track AT
Old 02-19-2012, 07:45 PM   #18
ipimpslpmstngs
The amount of power it takes to charge a tablet is no more than a phone. There's not really enough power drawn to cause an issue unless your battery is on its way out. I found that if your tablet is on a switched power source the tablet will be dead when you get in your car the next day needing to be turned on after it has shut down due to tablet battery drain. A button like the one I made is a must because you would have to pull the tablet out every time it dies to turn it on and if you have it on constant power you have to be able to turn the screen on/off and have a shutdown/startup button. there is no app to my knowledge that will turn the tablet on or off with a activated power source thus requiring a custom button.
435whp/356wtq
TurboXs Tuned 23PSI
Stock Block
Old 02-19-2012, 07:49 PM   #19
Retay's Avatar
Originally Posted by LOUISSSSS View Post
Amazon.com: Bluetooth ELM 327 Diagnostics USB Cable: Camera & Photo this is the exact bt adapter that i am using. it works 100% fine with the free torque app and the paid version
how responsive is that one? like does it lag?
SLide your HEart out
Retay is offline   Reply With Quote
Old 02-19-2012, 08:12 PM   #20
ipimpslpmstngs
I actually called plx the maker of the kiwi Bluetooth adapter and they said that there is not much of a difference that its more of the tablet speed. Even if you have the fastest tablet it still will have response lag.
435whp/356wtq
TurboXs Tuned 23PSI
Stock Block
samsung galaxy tab 10.1 .. what do you guys think with the link? YounGen Off-Topic 1 06-17-2011 02:19 PM
(T-Mobile) Samsung Galaxy Tab 16GB RSpec-Coupe Non-Car Related 4 03-30-2011 06:12 PM
Samsung Galaxy Tab RudyH Off-Topic 4 09-02-2010 06:14 PM
Samsung Galaxy S Galbi Off-Topic 16 06-06-2010 11:56 AM
