#41 | |||
Zosyn who?
thanks for the input! im not a big sound guy. i just want a little more bass thats all. Something simple like this. I already have the amp and sub from previous cars. ill just stop by ghetto walmart and look for this. |
#42 | ||
Vroom Vroom Party Starter
OR like I said the first time, any stereo shop will have them for under $20 if you dont want to go to walmart. Close to a Best Buy? They have them for $17, audio express? Custom Sounds? Ultimate Electronics? Tweeter? Reliable Audio? SoundWavez?
Daily: Twin Turbo SHO Taurus. AWD, Black on Black Airaid Intake, Tint, Viper 2 way Remote Start Hertz HSK165XL Comps, Audison Amp 2 10inch Sundown Subs, Kicker IX Amp Sold: 2010 White 2.0T R-Spec Haltech, 19t Best Dyno: 320whp/384wtq Toy: 2007 Kawasaki ZX-14 Best Dyno Pull: 228whp 135wtq Currently torn down and getting a built motor 300whp or bust Near St Louis? Join our group. https://www.facebook.com/groups/215112971924325/ |
#45 | ||
another advantage with the AC L2CI.
buy one of those and hook it to a fuse that is only on when the key is on. dont use more than a 10A fuse for the remote wire.
2013 2.0T 8-Speed Shoreline Drive Blue
#50 | ||
Ok. Is your amp powering up? Should be a power-on light on it somewhere. Which amp is it? To be clear, you have 0 sound, or you have very low sound? As in, are the woofers making any noise at all?
#53 | ||
You need to hook Left + and Right + to the + of your factory speaker, and Left - and right - to the - of your factory speaker.
#55 | ||
I bought the exact same sub as you and will be installing it on Friday....Couple noob questions...
Why did you go with a spacer for the sub? How did you secure the spacer to the actual car? If you used screws, what kind of screws did you use? What kind of screws did you use to secure your amp? I'm thinking of doing the exact same thing you did with my rockford. Any help would be great! Thanks |
#56 | |||
the amp is mounted with 10-32 screws 2" long you can get them at any hardwear store
KDM spec JDM parts |
#57 | ||
Track:
Also you tapped off the sub for the LOC? I assume you drilled holes in the shelf to feed the sub wires through? I know if looks clean but why, you could of just wired to the amp next to it? Also, like I said a bad idea to have an amp upside down, unless it is spec'ed for it, some brands allow multi positions, I would double check with RF on that one. If it is not rated for it, I would get some L brackets and some MDF cover with black vinyl or carpet build a shelf under the rear deck and put the amp upright, you get short L brackets to make it close to the shelf. Last edited by focalgencoupe; 05-08-2012 at 07:58 AM. |
#58 | |||
The Rockford amp can be mounted however you want instruction manual states it can be inverted/ upside down Have had this for close to a month and no problems. No over heating it all runs like a champ
#59 | |||
| 2 Alpine 10' Type R installed (pics) | Gen CP 21 | Interior 2008-2012 | 70 | 02-01-2013 11:03 AM |
| WTT Alpine type R 12in. | ninja3.8 | Interior | 0 | 12-13-2011 11:44 PM |
| (2)Rockford P2 10s and Rockford 450.2 Amp FS - Calgary | cowen604 | Other | 0 | 06-18-2010 04:09 PM |
| Selling Alpine Type R Subwoofers | aLi12302 | Interior | 3 | 05-09-2010 04:10 PM |
| Dual 10" Alpine R subs in bassworx box | goopnpv | Interior | 0 | 12-24-2009 05:54 AM |
