crappy oem shifter knob?? - Genesis Forum: GenCoupe Hyundai Genesis Forums
Old 06-07-2012, 12:10 PM   #1
Default crappy oem shifter knob??
hey all,
my shifter plastic piece on my 2013 gen coupe manual recently broke (i think). Now everytime i shift down the thing keeps popping off. Doesnt look like anything broke off? Anyone else having this issue?
[Solved]
Instead of taking the car to the dealer, I ended fixing the problem. Its really simply and I even made a DIY..
Im conviced the screw that held everything together fell loose from engine rattle over time (2 weeks for me).
First, remove the pleather boot by gently pressing all sides of and lifting up. The boot is held by two plastic clips on each side. If that doesn't work, try working on a side, pressing and lifting each side up.
Heres a better look at the clips..
Next, remove the shifter by rotating counter clockwise. Before actually removing the shifter knob from the shifter, please read next step!
The reason I had this problem is the screw came loose. Therefore the screw will fall out of the plastic cylinder and in your console if not careful. I placed a towel inside my console so that if the screw fell out, I dont have to go digging around for it..
Here is the screw in question. It seems it was previously loctited, however it still came loose.
The screw will eventually go through the threaded hole here.. PLace 2-3 drops of loctite in the hole and place the piece back on the knob
The next step is to just simply place the screw back in the bottom of the boot and tighten using a phillips screwdriver.
Then install in reverse order..
Hope this helps anyone that needs it this was initially a huge annoyance for me..
y4ck0 is online now   Reply With Quote
Old 06-07-2012, 03:03 PM   #2
JWreck's Avatar
Hard to tell with Mr. blurry cam there. But props for still having your paper mats in your car...
2013 3.8 GT A/T | Gran Premio Gray
6000k HID | LED Stage 2 Fogs | Full Interior LED Conversion
K&N Drop In Filter
JWreck is offline   Reply With Quote
Old 06-07-2012, 03:10 PM   #3
BloopBloop's Avatar
How hard are you shifting!? LOL jk.
2013 3.8 Track M/T
BloopBloop is online now   Reply With Quote
Old 06-07-2012, 03:16 PM   #4
xGuMB1x's Avatar
Holy ****! Take it easy with the shifting bro! Lol.. Take that sucker to Hyundai and see if thy can replace it.
2013 Genesis Coupe 2.0T
xGuMB1x is offline   Reply With Quote
Old 06-07-2012, 03:18 PM   #5
BloopBloop's Avatar
Originally Posted by xGuMB1x View Post
Holy ****! Take it easy with the shifting bro! Lol.. That's that sucker to Hyundai and see if thy can replace it.
"So uh...I was driving home and I was granny shifting to break-in the car...and this happened. Fix it or I'm gonna complain to HMA! /rage"
2013 3.8 Track M/T
Old 06-07-2012, 03:23 PM   #6
If you pull the boot down off the shifter and unscrew the knob, there should be a screw inside the knob you can tighten back on that plastic part...The same thing happend on my Forte Koup and I was like, HUH??
GenJeoldan is offline   Reply With Quote
Old 06-07-2012, 03:23 PM   #7
K.C
DaT_AzN_GuY
K.C's Avatar
Im sure your dealer will replace it.
K.C is offline   Reply With Quote
Old 06-07-2012, 03:26 PM   #8
Mine is doing the same thing. If I don't grab the lower metal piece, the plastic piece comes off with very little effort. It happened to my wife the first time, and she does drive like granny. I am taking it back to the dealer next week, hopefully they will fix it easy enough.
Sent from my DROID RAZR using AutoGuide.Com Free App
khold is offline   Reply With Quote
Old 06-07-2012, 04:33 PM   #9
RspecPremio's Avatar
happened to me too, just took everything off and put some loctite on the screw. haven't had a problem since, but if it happens again I'm going to the dealer
2013 2.0t Rspec
Gran Premio Gray
SFR Custom
274hp 296tq (el paso tx)
RspecPremio is online now   Reply With Quote
Old 06-08-2012, 04:46 AM   #10
heh,, the car is only 2 weeks old!
i dont think my shifting was the issue. most likely the engine vibrations jarring something loose or cheap craftsmanship
thats exactly my issue.
theres a threaded slot on the plastic piece, and the screw is flush with the plastic spacer on the shifter itself, therefore i dont konw how that screw was ever holding the plastic piece.
Old 06-08-2012, 02:53 PM   #11
SuperDave's Avatar
I've had the same thing happen to mine. Moddiction is sending me the fix I need for that issue.
I have to say, I like the pics of removing the shift boot, since I'll need to do that when I get my short throw shifter in. It's a simple procedure, but one I'll know how to avoid jacking up now that I've seen how it's put together.
SuperDave is offline   Reply With Quote
Old 06-09-2012, 11:25 AM   #12
2013 2.0T RSpec
tt0ne's Avatar
double post.
tt0ne is offline   Reply With Quote
Old 06-09-2012, 11:26 AM   #13
2013 2.0T RSpec
tt0ne's Avatar
I have posted about shifter problems in other threads - and never could get the rattle to go away... I'm originally from Canada and grew up playing hockey and finally got so sick of the rattle that I went and purchased red hockey tape and did my shifter up like it was the butt end of a hockey stick and you know what?
I ****ing love it despite how welfare it looks. The extra weight feels great and real sports tape has a good feel to it. Hell, I should market it. "HOCKEY KNOB" - "WHEN SHIFTING IS MORE IMPORTANT THAN LOOKING COOL... Well.. Such as it is." ;-)
BUT... bottom line - the shifter that comes with my Rspec was low quality and shaped like a bent banana dick.
TT0ne
PS: To the original poster - thanks for the great pics - I've made sure to bookmark this threat since you know at some point - it will need to be referred to! :-)
Old 06-13-2012, 09:11 AM   #14
GenoboliC's Avatar
If you don't mind sharing what you used to get inside the crevice to press all the sides and snap out the clips? Or did you just shove your finger between and pull inwards until it snapped out.
GenoboliC is offline   Reply With Quote
Old 06-13-2012, 10:04 AM   #15
honestly i just used my hands. i squeezed all sides slightly then lifted up. the square is plastic so it does give. but be sure not to squeeze to hard.
if that doesnt work for you, try doing one side at a time.
Old 06-13-2012, 11:45 AM   #16
GenoboliC's Avatar
Will do, Thanks.
I'm planning to change the pleather boot with one from TWM and a new shift knob. So will post pics of this also.
Old 06-13-2012, 07:38 PM   #17
radioman's Avatar
I cant seem to get the boot off... I might just be scared of breaking something.
EDIT: OK managed to get the boot off by flicking the clips off as if the leather wasn't there.
MAKE SURE YOU DON'T DROP THE SCREW WHEN YOU TAKE THE KNOB OFF.
I had to fish for it and I didn't have a flash light handy but I managed to get it.
Screwed the plastic park on and gave the knob a full revolution more then it was set to previously and now it doesn't move and the top is securely placed. Easy fix no need for warranty work.
2008 Ford Ranger Sport - Traded
2011 Ford Fusion SE - Traded
2013 Genesis Coupe 2.0T R-Spec
radioman is online now   Reply With Quote
Old 06-19-2012, 01:44 PM   #18
my shift nob broke today too..looks like its not properly glued or just cheap quality material.
2013gencoupe is offline   Reply With Quote
Old 06-19-2012, 02:01 PM   #19
GenoboliC's Avatar
Its not broken, they jus didnt include the screw that tightens the top piece on. Unclip the boot from the knob, unscrew the shift knob and get a little screw that fits inside threaded hole of the piece that fell off. Screw it to the shift knob, and screw the whole thing back on the shifter.
OR go to the dealer, but that might take a while.
Old 06-19-2012, 03:30 PM   #20
Fought to Live
hmcclung's Avatar
Yesterday I fixed my rattle and the top piece from seperating by simply unscrewing the shift knob. I did not have to remove the boot at all, and the screw was completely off of mine, so I put on some loctite and screwed it back in. Like magic, the rattle is gone! And it took 3 minutes 14 seconds to complete.
2012 2.0T Premium Monaco White auto *sold
2013 2.0T RSPEC Beckett's Black
To Each His Own:
15% Tint
Forge Atmo BOV
GCP Intake
ISIS CBE w/ mid & test pipes
Tein S springs w/ Eibach 20mm spacers
Kicker speakers, amp, and L3
DD H7 HID conversion 6K w/ relay harness
hmcclung is offline   Reply With Quote
WTB Auto Shifter knob kglow Texas 7 03-01-2012 05:41 AM
FS: Torque Solution Short Shifter+knob hvp014 Interior 12 02-01-2012 05:02 AM
Do you want a new SHIFTER KNOB? a/t & m/t Triviumfan5 Interior 2008-2012 4 08-21-2011 08:03 AM
How do you remove shifter knob?? Monte22 Interior 2008-2012 28 07-10-2011 04:20 AM
New shifter knob twm review sscouture Product reviews 14 11-08-2010 08:15 AM
