Mirrortap Radar Detector Power Cable Install? - Hyundai Genesis Forum
post #1 of 28 Old 10-31-2012, 06:27 PM Thread Starter
inertiamonster's Avatar
Quoted: 583 Post(s)
Has anyone installed a Mirrortap power cable on a 2013 Coupe with the Blue Link/Home Link mirror? It looks like it'd be easy since the wiring harness is easy to access, but I want to be sure there aren't any issues with using it, and of course I need to know which wires on the harness to connect to.
2013 3.8 Track Pearl White
inertiamonster is online now
post #2 of 28 Old 10-31-2012, 08:19 PM
focalgencoupe's Avatar
Quoted: 240 Post(s)
You might want to get a multi meter and back probe the connector, to see which has power, ideally use one with the ignition key on. Unless you can get a wiring diagram.
focalgencoupe is offline
post #3 of 28 Old 11-01-2012, 01:39 AM
13_gc_pb's Avatar
Don't remember the pins, but I can tell you its no problem, been hooked up since April without a problem.
2013 Parabolica Blue 2.0T Premium
Front Fogs
VIP K Front Emblem
Debadged Rear
M&S Carat Lip Spoiler
TSW Max Hyper Silver - Black lugs
19x9+20 19x10.5+25 245/35R19 275/35R19 Hankook
K&N drop in filter, all ya need...
13_gc_pb is offline
post #4 of 28 Old 11-01-2012, 10:55 AM
Quoted: 240 Post(s)
Is this the mirror you have?
post #5 of 28 Old 11-01-2012, 11:22 AM
2012 3.8 Track ZF-6-SPD
Metal's Avatar
I tried the mirror tap cable. It was to thick of pins and I couldn't get it in the plug. I ended up wasting an hour trying to get it in. Broke the pins trying then tried to splice them in with no luck. Waste of $25 for me. Ended up buying an Escort harness and had it professionally installed.
Engine
- UR Light Weight Pulley
- R2C SRI/P2R Spacer+Gasket
- Maxbore Bored TB+CC
- GS Spacer/PnP+CC Manifold
- AEM V2 Meth Kit
- BTR Custom Meth Tune
- Mishimoto Oil Cooler
- Boostec CF Front Lip
- NRG Canard
- M&S Side Splitter
- ViS CF Rear Diffuser
- ARK C-FX CF Grill
- ViS CF Fog Bezel
Chassis
- VOLK TE37SL/Hankook
- R1/StopTech/SS Lines/Dot 4
- PSM Pro Coilover
- Luxon Strut Bar
- UR 4pt Rear Strut Bar
- SFR Rigid Collar Kit
Metal is offline
post #6 of 28 Old 11-01-2012, 11:24 AM Thread Starter
Quoted: 583 Post(s)
That's good news, which cable and bracket did you order exactly? And any chance you could peak at the wiring for me?
No, mine has three buttons on the left (including Blue Link and SOS), a big power button in the middle, and three Home Link buttons on the right. And I seem to remember there were more wires in the harness too.
post #7 of 28 Old 11-01-2012, 11:27 AM Thread Starter
Quoted: 583 Post(s)
Hmm, do you remember which pin thickness you ordered?
post #8 of 28 Old 11-01-2012, 11:54 AM
Quoted: 240 Post(s)
I tried looking online and that mirror was the one posted.
Just Take a multi meter set it to 12v and turn on the key probe it to see what has power. Some mirror taps have thinner pins, on ebay there are a few different brands. Or just test the one you have to see if the pin will fit.
Or get a hard wire kit to the fuse box super simple install.
post #9 of 28 Old 11-01-2012, 02:41 PM
Newbie Modder
ScottChu's Avatar
I had to force mine in because the tap was thicker as mentioned above, but I haven't had any problems since I've installed it.
I'm a 2011, but I doubt there's much difference.
2011 Nordschleife Gray 3.8 Track MT
I like cars.
I take pictures of them.
You can see them at www.scottchu.com
"Simplicity is the ultimate sophistication." | da Vinci
ScottChu is offline
post #10 of 28 Old 11-01-2012, 03:12 PM
13_gc_pb's Avatar
Bought this on ebay, he makes a ton different brands obviously.
Whistler Cobra Radar Stealth Mirror Direct Wire Cord | eBay
I have the same mirror you have, got the pinouts here:
https://www.hyundaitechinfo.com/
account is free
Front Fogs
VIP K Front Emblem
Debadged Rear
13_gc_pb is offline
post #11 of 28 Old 11-01-2012, 03:48 PM
bucks's Avatar
I have a valentine one mounted under my mirror. I just lowered the interior light housing and tapped into a hot wire while key on. Was very easy.
2013 3.8 Grand Touring A/T (Grand Premo Gray)
SFR Custom Tune
CBE Magnaflow
Ark H Pipe
Custom SRI
Pedalbox
15% Tint
BBM Spoiler
DDMTuning 6000K
Valentine One
bucks is offline
post #12 of 28 Old 11-01-2012, 06:54 PM Thread Starter
Quoted: 583 Post(s)
account is free
Thanks, I tried creating an account on that site when I found the other thread you posted asking about the same wiring question, but that site is ridiculously buggy, can't even sign up, all I get is errors. If you have the diagram still can you send me a link to it?
post #13 of 28 Old 11-01-2012, 06:55 PM Thread Starter
Quoted: 583 Post(s)
Good to know that is also an option, thanks!
post #14 of 28 Old 11-01-2012, 07:22 PM
Genny13's Avatar
Pics please
Genny13 is offline
post #15 of 28 Old 11-01-2012, 07:27 PM Thread Starter
Quoted: 583 Post(s)
Originally Posted by Genny13 View Post
Pics please
I second that actually.
post #16 of 28 Old 11-01-2012, 07:46 PM
Parabolica Blue 2.0T :)
lmaobus's Avatar
I have tapped into my homelink mirror. Just tap into the pink (positive) and black (negative) wire.
You want to use R02 as a guide.
lmaobus is offline
post #17 of 28 Old 11-02-2012, 04:00 AM Thread Starter
Quoted: 583 Post(s)
Thanks!
post #18 of 28 Old 11-02-2012, 06:16 AM
Jedi Master
cris90's Avatar
seams like a good idea... why doesn't some1 local to the manufactor contact them and offer for fitment.
Fav. JT Quote
cris90 is offline
post #19 of 28 Old 11-02-2012, 07:26 AM
Quoted: 240 Post(s)
How did you lower the housing?
post #20 of 28 Old 11-08-2012, 04:24 AM
although personally i advise against tapping into wires. It will probably work if done right, regardless I just wouldn't risk cutting into the wire. check out.
The Problem with Wire-Tap Connectors Bareass Choppers Motorcycle Tech Pages
I just bought a dash camera, and will install it using a fuse tap. Cooper Bussmann/ATM fuse tap converts one into two fusible circuits - 10 Amps maximum on added circuit (BP-HHH-RP) | | AutoZone.com
Not only its cleaner and splicing is not needed, its also safer with the added fuse protection.
y4ck0 is offline
HOW TO: Stealth Radar Detector Install w/ Pics HAILSTORM Interior 24 10-03-2013 10:16 PM
radar detector 2013gencoupe General Discussion 72 05-16-2013 08:34 PM
Radar Detector install help? llbadll Interior 2008-2012 5 04-21-2012 04:22 PM
fs. radar detector phs17 Other 2 05-31-2011 12:51 PM
power supply for a radar detector jvsantosmd Interior 2008-2012 2 12-30-2009 03:12 PM
