gencoupe.com gencoupe.com
Go Back   GenCoupe.com Forums - Your Hyundai Genesis Coupe Community > Other > Off-Topic
Old 04-11-2009, 10:37 AM   #1
O, not zero. ;)
N2OInferno's Avatar
Default How to effectively use search
If someone wants to sticky this or put it somewhere else more important, by all means do so.
I read in a topic earlier about how a user was having an issue searching for oil change, so I figured I'd make this thread to help inform the masses about some rules when using a search engine. I am not trying to come across as condescending. Knowledge is power, and the better you can search the more efficient you'll make yourself! The truth is, quite honestly, that most poeple don't know how to properly search. Using the search engine might help them and often does, but they're not getting the best results for what they want. These rules I'm going to mention can be applied to Google, Altavista, Yahoo, or just about any enigne. Anyway, on with the post!!
If you search oil change, it does come up with the error stating that:
Originally Posted by vBulletin Message
The search term you specified (oil) is under the minimum word length (4) and therefore will not be found. Please make this term longer.
If this term contains a wildcard, please make this term more specific.
But.. I CAN search for oil change. You need to use proper syntax. Don't type the words oil and change, type in "oil change" using the quotes. It searches for that particular string as opposed for searching for just the words "oil" and "change." The first search, if allowed, could bring up a topic that has nothing to do with oil changes but has those words randomly inserted in it.
So let's put this to use! I want 22 inch wheels on my Genesis Coupe ().
22 won't take if I type that into the search engine alone, but I need answers and if I start a new thread everyone will laugh at me and I'll get flamed and doomed to be a noob forever. I want my answers, but I'm not quite prepared to be laughed at by having 22s, so I'm open to 17s, 18s, or 19s. What do I do?
Search: wheels "22 inch" "17 inch" "18 inch" "19 inch"
And your results are
1. Sorry - no matches. Please try some different terms.
NOTHING! (at the time of this writing!)
edit: after this was posted, doing this specific search will pull up this thread.
This time, our search was too specific, and there is no thread that mentions 22 inch wheels and also mentions 17 inch, 18 inch, and 19 inch wheels.
At this point, you can be more vague, and if that doesn't work make a new thread. If someone gives you issues, tell them you did a thorough search, and if they can't get over themselves then they must think the internet is srs bizness.
Couple other things I'd like to mention here that may or may not work on vBulletin but work in other search engines:
+ forces a word to be found in the search. If I Google livestock +cows, every search will be related to livestock, and have the word "cows" in it.
- filters a word from a search. If I google livestock -cows, every search will be related to livestock, and will NOT mention the word "cows" in it.
This is an intensive overview of Google's seach operands. Google Search syntax dissected - Night Dreaming (by Sudar)
It's a great site for anyone that wants to get a bit more efficient in their searching when out on the internet.
That's all.
Mitch Hedberg
N2OInferno is offline   Reply With Quote
Old 04-11-2009, 11:02 AM   #2
Kai
Kai's Avatar
This deserves a sticky A++
Originally Posted by FlesHBoX View Post
haha I'm perfect man! I nevr mess up!!!
Hahn: The red EVOs yours.
Sean: What do you mean?
Hahn: You represent me now. What you think I let you roll in a Hyundai?
Kai is offline   Reply With Quote
Old 04-11-2009, 11:22 AM   #3
Kai
Kai's Avatar
lol..
had to do it, took me 2 seconds
Old 04-11-2009, 03:52 PM   #4
O, not zero. ;)
N2OInferno's Avatar
haha.. that's actually a good idea. Never even thought about it, but yeah it'll pull up this thread now when you search for that.. gonna go edit the first post.
Mitch Hedberg
Old 04-11-2009, 05:07 PM   #5
Ms. Warranty Voider
kristin's Avatar
That is just dumb.
vBulletin needs to hire a usability team.. one should not need instructions to do something as simple as search
twitter.com/kristn
facebook.com/kristn
kristin is offline   Reply With Quote
Old 04-11-2009, 10:44 PM   #6
O, not zero. ;)
N2OInferno's Avatar
Working in the computer industry (or did, lol), I get that a lot when people don't know how to use something. So I'll answer the same way. No. It's not dumb, really. Computers are dumb machines. They can't do anything on their own without prompt. Therefore, they are only as knowledgeable as the person operating them. If the user doesn't know the correct syntax, the computer doesn't know how to handle the situation in a precise manner. If you didn't know how use the ignition to start a car, it wouldn't know how to start.
It's not vBulletin.. ALL search engines perform this way. When people know how to search correctly it makes life a lot easier. It's a good thing vBulletin has filters IMO. Look what happens when I search for "the" at Google.
Originally Posted by Google
Results 1 - 10 of about 14,220,000,000 for the. (0.07 seconds)
Sooo.. People can continue saying it's dumb and do nothing.. Or they can learn to properly use the software.
Mitch Hedberg
Old 04-13-2009, 11:45 AM   #7
FlesHBoX's Avatar
I will interject that there are search engines that would not "have this problem" and they all suck for any real searching. Lotus Notes comes to mind, the search engine is literally like being punished!
The problem with allowing so few characters is that your search becomes so ambiguous that the hits returned are pretty much useless. It would be like asking for 1/3 of the posts on the site, only without any organization, only ordered by the post date.
There are Natural language search engines, most of which really suck badly. Our Knowledge Base system where I work uses a natural language search engine and it is almost impossible to find some of the articles because those who wrote them have no clue how to write for the engine.
I happen to be intimately familiar with that one, as I am a reviewer for our knowledge base, after it was discovered that I was the best author in our group, lol. Unfortunately, that means that I no longer write articles
..: J e s s e :..
Easy like Hyundai morning.
Originally Posted by logitec View Post
when i see flesh has made a comment i usually scroll through to read what he said due to the fact I dont think hes been wrong yet...
FlesHBoX is offline   Reply With Quote
Old 04-13-2009, 02:31 PM   #8
O, not zero. ;)
N2OInferno's Avatar
Annnnnnnd you forgot a period before your smiley. I WIN AGAIN!
Mitch Hedberg
Old 04-13-2009, 03:06 PM   #9
FlesHBoX's Avatar
The smiley IS my period
..: J e s s e :..
Old 02-14-2010, 04:09 PM   #10
yupuhhuh2 is offline   Reply With Quote
