Canadian Touring Car - Team Updates + Car Build - Page 5 - Genesis Forum: GenCoupe Hyundai Genesis Forums
Old 04-13-2011, 01:47 PM   #81
CrookedH's Avatar
Originally Posted by ben.... View Post
How did I just find this? Thanks for sharing all this great info!
X2. Not sure how I missed this thread for so long...
OP: Awesome build!! If you guys can't get good power out of the ATP turbos, check out Beyond Redlines upgraded stock turbo. There are numerous people making 300+whp and 300+ft/lbs. It'll hit 20psi just before 3000rpm no problem, about 15psi by 2500, I've seen up to 25.X psi by 3500rpm. It won't hold much more than ~20psi at 7000rpm though. I've never seen intake temps more than 40* above ambient, even in 95* weather.
  • Detailed title of item
  • Asking price
  • Actual Photos of the item
CrookedH is offline   Reply With Quote
Old 04-13-2011, 05:24 PM   #82
I'm curious why you guys went with the GT28s vs. the GT3071R? I was under the impression that it spools just about as fast as the 28s?
Why did you decide to go with the cable throttle body? Was it the haltec or just for better response?
What is the suspension setup?
That intercooler is pretty tiny, I would think a larger one would help quite a bit?
PS. Can we get some more recent photos?
Tsukuba Red 2010 2.0t r-spec
260 whp / 280 wtq
ben.... is offline   Reply With Quote
Old 04-17-2011, 01:00 PM   #83
Torque Junky
Tony20tGen's Avatar
Can u go into some detail about the hal tech install, r u using the can features
Darton Sleeves
Manley pistons
Manley Rods
custom Intake manifold
1680cc FIC injectors
2 walboro 400 intank fuel pump
Return fuel system
compound turbo kit
4inch dp
GT4202 and ct2 6062 comp Turbos
CP-E 45 motor mounts
TurboXS RSD exhaust
Mishimoto radiator
SpEC 3+ clutch kit
Haltech PnP Standalone ECM
http://www.youtube.com/user/tonypta46
Tony20tGen is offline   Reply With Quote
Old 04-17-2011, 01:20 PM   #84
So many questions!
The car is not using any of the factory electronics. All of the chassis wiring and engine wiring was done custom (by us) to professional race standard (often labeled "mil-spec"). We are using CAN communication to the AIM MXL dash, and we have the intake cam control working, but not the exhaust cam control.
The Sport 1000 does not support DBW so we switched to cable throttles, which works well since we were using cable throttles last year with the 3.8L engines anyways.
The suspension is also anything from stock:
Front suspension:
-Custom tie rods with bump steer correction
-Front lower control arm modified to use a spherical rod end on the chassis side
-Eibach sway bars with custom bar links
-Front TC rods changed to radius rods with rod ends
Rear suspension:
-Custom machined monoball housings to replace the two bushings in the knuckle
-Custom aluminum subframe bushings
-Custom camber arms, with the frame rails notched to allow the use of a straight camber arm
-Custom toe arms
-Rod ends with tube nuts welded on traction and front lower arm (to allow the arm to be adjustable, and to remove the stock bushing)
-Spring perch modified to convert the bushing to a rod end as well.
-Eibach rear sway bar with custom links
I will get some pictures of the suspension for you guys.
The dampers we are using are Penske triple adjustable remote reservoir, with the front struts custom built by Anze engineering. Current spring rates are 800F/800R, with the rear spring mounted on the damper rather than the OE location.
If you guys are interested in some suspension products and organize a group buy we can certainly put something together. The links are not that expensive. The dampers are.
Sasha Anis | Genesis Racing Canadian Touring Car Hyundai Genesis
2012 Canadian Touring Car Champions
SG-Motorsport.com
SGSash is offline   Reply With Quote
Old 04-17-2011, 04:37 PM   #85
^ Yes!!! Very interested in learning more about your suspension setup and a potential group buy. Let's see pics!
260 whp / 280 wtq
Old 04-20-2011, 05:46 AM   #86
Resident Critic
Tweak's Avatar
Sasha I was considering giving PRS in Niagra a call with some calcs for a double adjustable street/track set.
I still need to get onto Asselins scales among other things. I would have done it this coming weekend if he wasn't out racing those clown cars (Legends).
Good call on getting rid of the sloppy bushings though, they're brutal.
Current:
2010 Genesis Coupe 3.8GT 6MT
Previous:
2003 G35 Coupe Track Package 6MT
1991 Sr20det powered Hardbody Pickup 5MT
1989 s13 Drift Car 5MT
Tweak is offline   Reply With Quote
Old 04-26-2011, 07:44 PM   #87
Always-sidewayz's Avatar
also very interested in the suspension, cant wait for the pics
Always-sidewayz is offline   Reply With Quote
Old 05-07-2011, 09:00 AM   #88
Just tested the new car at Mosport and things went rather well! Both cars are within 2 tenths, and are on pace with last year. Looking forward to our first race in two weeks!
More detailed suspension pictures will come in the future
Bigger intercoolers!
My home
SG-Motorsport.com
Old 05-07-2011, 09:18 AM   #89
Sexy....
260 whp / 280 wtq
Old 05-09-2011, 07:56 AM   #90
Site Sponsor
BrandonGS's Avatar
Message me for a price quote!
Email & Paypal: Sales@BethesdaPerformance.com
BrandonGS is online now   Reply With Quote
Old 05-09-2011, 05:11 PM   #91
Doom Machine
ByByCavalier's Avatar
lol, I love the frankencoupe! So very nice!
Project Blue Block underway...
ByByCavalier is online now   Reply With Quote
Old 06-06-2011, 07:37 AM   #92
Thanks guys!
I apologize for the lack of updates, we've been too busy working on these things. We just got back from our second race weekend and it was one of the wildest races I've had. We've been dealing with power steering failures on the #14 car, while the #86 (new car) has been 100% reliable and ripping AWESOME.
The power steering failed on me in practice on Friday, so I was forced to qualifying with any practice on this new track. I was still able to qualify 3rd and bob was 4th. We were really excited to be doing so well.
I ended up winning the first race, and bob came 2nd It wasn't without excitement though. There was some really good racing going on, not only at the front but throughout the entire field. This was the first time Bob and myself were on the podium together, so that felt awesome.
In the second race I got taken out in the first corner, the entire right side of the car is now mangled. SOMEHOW the suspension didn't get hit hard enough to really mess it up. I was able to drive back to 3rd, and bob finished 1st. My suspension finally let go and on the last couple laps I went back to last. It was really sad - but I made it more exciting by doing a few donuts which I was then fined for and put on probation. Oops!
Read the full story at the SG blog, there are more pictures there as well. I'm editing a video now of the second race - from the start, everyone flying past me and making positions back up. It's quite an exciting run I think you're going to like it
Read the Full Story HERE
SG-Motorsport.com
Old 06-06-2011, 11:58 AM   #93
RudyH's Avatar
Originally Posted by SGSash View Post
CONGRATS!
Genesis Coupe domination, quite proud!
RudyH is offline   Reply With Quote
Old 06-06-2011, 06:02 PM   #94
Awesome, congrats. Looking forward to the video!
260 whp / 280 wtq
Old 06-06-2011, 11:27 PM   #95
(aka El Stig)
WillRacer1JZ's Avatar
Congratz!!!!!!
WillRacer1JZ is offline   Reply With Quote
Old 06-07-2011, 02:14 AM   #96
Resident Critic
Tweak's Avatar
Nice job Sasha!
We missed you at CSCS... the time attack wasn't as exciting without the fastest lap battle in Unlimited.
Well deserved though!
Current:
Previous:
Old 06-10-2011, 11:07 AM   #97
Thanks guys!
Bob, I won't be able to make it to the next CSCS but the Gen Coupes should be there and Bob may even run one. I will be at the last event for sure with my Z and with any luck I'll improve my time from last year!
SG-Motorsport.com
Old 06-10-2011, 02:50 PM   #98
merc_rmw's Avatar
I had no idea this existed! So cool to see Coupes running in the race!
Super stock!
merc_rmw is offline   Reply With Quote
Old 06-12-2011, 06:06 PM   #99
Here's some footage from the weekend, you'll want to watch it!
SG-Motorsport.com
Old 06-13-2011, 02:02 AM   #100
Resident Critic
Tweak's Avatar
Thanks guys!
Awesome dude,
Congrats on the sucess at Mirabel!
Current:
Previous:
jaycees build updates (long) jaycee Media 130 02-05-2013 10:47 AM
Team Need for Speed racing team adds Time Attack 1,100-HP Scion TC RSS-Autoblog Autoblog 7 08-30-2011 03:51 PM
Mosport This Weekend - BE THERE! ALMS, Canadian Touring Car SGSash Professional Motorsports 10 09-08-2010 03:19 PM
Triumph updates 2011 Sprint GT with emphasis on touring over sport RSS-Autoblog Autoblog 0 05-21-2010 07:10 AM
ARK PERFORMANCE INC: Offical Build Thread : GENESIS COUPE 3.8 TRACK BUILD ARK Performance Media 21 04-23-2010 09:28 AM
