RMR - Technical Questions? - Page 2 - Genesis Forum: GenCoupe Hyundai Genesis Forums
Old 11-15-2011, 03:25 PM   #21
Not in the face!
jaov2k's Avatar
is there a list of the harnesses which the vehicle uses for the various electronics in the engine compartment?
Basically, I want to reroute (lengthen) some of the wiring so there's more "wiggle" room in there, but instead of splicing in longer sections of wire I would just like to make a whole new run with the appropriate connectors at the end.
Also, where can I get these things? Are they like off the shelf?
Any help would be greatly appreciated.
2011 | 3.8L | Track | A/T | Karussell White
| PowerAXEL Reflash | R2C SRI | DD Stage 3 LED Kit - White |
Info@JAOV2K.com
JAOV2K, Inc. Consulting Services
(708) JAO-V2K0 (526-8250)
jaov2k is offline
Old 11-15-2011, 06:29 PM   #22
2.0TGT's Avatar
Originally Posted by Eric RMR View Post
We ran 235's up front and 265's rear.
sorry to be a pain....
do you have complete tire size?
2.0TGT is online now
Old 11-15-2011, 07:26 PM   #23
Robert RMR's Avatar
Hyundai is pretty good about technical info. You can sign up for their service site at Hyundai Service Website. They have complete wiring schematics to work from.
We get harnesses complete from Hyundai, and from what I can tell they are not cheap. Connectors are not sold individually.
Believe me, a plug kit with all the ends to do what you want to do would make life a lot easier.
Robert RMR is offline
Old 11-15-2011, 07:45 PM   #24
Not in the face!
jaov2k's Avatar
Originally Posted by Robert RMR View Post
...Connectors are not sold individually.
grrr. Thanks for responding.
Info@JAOV2K.com
jaov2k is offline
Old 11-15-2011, 08:23 PM   #25
Robert RMR's Avatar
Originally Posted by Badcompany235 View Post
how did you compensate for the geometry change with your lowering package? all of your current racing campaigns appear to require quick steering feedback and maximum suspension effort. things that seem/feel lost when lowering with springs and coils due to the reduction in dynamic travel. however your cars still appear lowered and appear to roll at a predictable angle (pikes peak special not included).
also are your v6 mounts going to be produced. rumor was that the custom mounts pushed the engine back nearly 2 inches. for serious track coupes with no interior this would be a desirable product.
when are we gonna see some GT class action from RMR? is Rhys your only driver or are you putting more ppl in more seats?
I assume you are talking about the drift car... Without saying too much we work within the rules to get the car as low as possible without losing suspension travel. The added bodywork also helps the car appear lower. If you're talking about a different car, let me know.
As for the mounts, we have no plans to offer them for the V6. Our car runs a dry sump (which is for sale), and you would likely run into a clearance issue running the stock oil pan with those mounts.
I too would love to see us compete in sports car racing! Rhys is our only full-time driver, however this past season we had Marcus Dodd and Robbie Maddison in GRC and Rod at Pikes Peak as part-time drivers.
Old 11-23-2011, 01:06 PM   #26
Can you please post a link to the BH Rspec swap into the BK so we can read about it?
Thanks guys, love your work
hyundai drifter is offline
Old 11-27-2011, 10:02 AM   #27
Not in the face!
jaov2k's Avatar
who does your metal fab work? is it all in house or do you have a preferred vendor, and if I needed some work done, welding, casting, etc. is this something you can quote me?
Info@JAOV2K.com
jaov2k is offline
Old 11-28-2011, 09:27 AM   #28
Robert RMR's Avatar
We do nearly all of the fabrication and prep in-house. Occasionally, we will send work out to local shops in the area.
Our shop is capable of welding and machining, and we have prepared customer cars in the past. We do not have a casting facility, so we would send that work out.
Please feel free to PM me what kind of work you are looking for or contact the shop directly and we'd be happy to quote you.
Old 11-28-2011, 03:55 PM   #29
Not in the face!
jaov2k's Avatar
ok I got another question:
What's the intake valve diameter on the 3.8L?
I reeeeeally don't want to take the heads off....
....my poor car.....
Info@JAOV2K.com
jaov2k is offline
Old 11-30-2011, 08:47 AM   #30
Not in the face!
jaov2k's Avatar
So I decided to look into this and it seems like I will be able to roll out a product. I just need to determine the community demand so the pricing can be established.
EDIT: new thread for the wiring harness Feeler: Wiring harness kit
Info@JAOV2K.com
jaov2k is offline
Old 02-09-2012, 08:51 AM   #31
illest
1320drift's Avatar
I've been looking into a second caliper h-brake system and I have sourced all the parts except a rear caliper. I have the factory brembos but I have heard single piston calipers are better to use for this plus I think a single piston caliper would be cheaper. Do you have any suggestions on a single piston caliper that would fit the rear brembo rotors or do you think I should just go with a second set of brembo calipers?
Powered By MAX USA Pro Coilovers, Sub Frame Risers, Toe Rods, Traction Rods, Control Arms & other tasty treats
1320drift is offline
Old 02-17-2012, 04:50 AM   #32
if you can find out what are the offsets on the gencoupe drift car and what tire size do you run on it? thank you
shoeboy4 is offline
Old 02-17-2012, 04:55 AM   #33
sub
_________________
2012 2.0t base auto
Vibrant joiner - silencer delete
ISIS test pipe - second cat delete
waiting on warmer weather for more mods
replace down pipe
replace mid pipe
custom tune
replace sway bars
rickt is offline
Old 02-17-2012, 06:58 AM   #34
drj342's Avatar
I know this has been posted before in other sections and threads, but what is the "safe" HP limit of the 3.8 V6 with stock internals?
3.8 Track 6 Speed Tsukuba Red
TEXASGenCoupe #87
drj342 is online now
Old 02-17-2012, 07:46 AM   #35
shoeboy4- We run a 245/40/18 RS-3 Hankook front and a 285/35/18 RS-3 Hankook rear.
Eric RMR is offline
Old 02-18-2012, 10:50 AM   #36
illest
1320drift's Avatar
I asked rmr quite some time ago about this. They run a completely different suspension than stock. And so will I soon
Old 02-29-2012, 06:17 PM   #37
ZakRabbit's Avatar
Not necessarily a technical question, but any closer to releasing the license plate relocation trunk lid?
Sent from my SGH-T989 using AutoGuide.com App
ZakRabbit is offline
Old 03-12-2012, 02:52 AM   #38
Ibnzmonkey's Avatar
I am a mechanical engineer.
CAN I HAZ JOB DESIGNING AWESOME PARTS?!
3.8T build in the works....
It's kind of a big deal
Ibnzmonkey is offline
Old 03-16-2012, 04:29 PM   #39
Wanted a Maseratti Coupe
Jaguarlee27's Avatar
I'm the team engineer for RMR. If anyone has any questions about the cars, events from the past year, or any other technical questions, I'd be happy to answer.
Robert thanks for offering your help, I have two questions:
1.How did you address the understeer with the car?
2. What did you guys do to improve the suspension? ( Lapping / Racing setup)
Allways looking for an excuse to go driving! If you are up for it MSG me!
Jaguarlee27 is offline
Old 03-19-2012, 01:38 AM   #40
Midlife Crisis Consultant
charlie57's Avatar
Last response to question 11/28/11, is it safe to say that RMR is no longer active on this forum?
charlie57 is offline
Genesis Forum: GenCoupe Hyundai Genesis Forums > Motorsports Section > Rhys Millen Racing - Hyundai Motorsports Division
I made a whoopsie: technical expertise needed lollersk8tes Suspension 2008-2012 11 06-26-2011 08:28 PM
Toyota FT-86 Technical Details Confirmed AutoGuide.com AutoGuide.Com News 0 05-15-2011 03:50 AM
Technical Write Up Info WildBill Forum Feedback 4 04-07-2010 04:15 PM
first post! and a fw technical questions... johnzm General Discussion 6 03-29-2009 06:31 AM
Brembo Technical Data on the Gen Coupe FRCDAIR Wheels, Tires and Brakes 2008-2012 4 02-04-2009 05:45 PM
