Clutch Rod Adjuster Kit - Hyundai Genesis Forum
post #1 of 84 Old 01-30-2012, 06:17 PM Thread Starter
3.8kdmcoupe's Avatar
Quoted: 16 Post(s)
Hey I was going through jays web site and I came across this Clutch Rod Adjuster Kit and I was just looking for some feed back on this if anyone has this can you give me your review on this product. Thanks
Gallery
2010 Genesis Coupe 3.8 GT, 6MT, Nav
BTRcc tune
Injen cai
ARK headers
ARK dp's
ARK cbe
WOT BOX
Ksport kontrol pro
3.9 diff gears
3.8kdmcoupe is offline
post #2 of 84 Old 01-31-2012, 12:07 AM
Site Sponsor
Jay@SFR's Avatar
Quoted: 213 Post(s)
We haven't sold a set yet but it's one of the popular item to get in Korea.
It does make a difference on the feel of clutch and helps a lot controlling the clutch.
It's fully adjustable that you can set the rod the way you drive.
15YEARS IN KDM BUSINESS
Please PM for any questions...
TEL 215.300.3397
www.seoulfulracing.com
YOUTUBE CHANNEL
OEM/KDM/AFTERMARKET
INSTALL/DYNO/ECU TUNE
Jay@SFR is offline
post #3 of 84 Old 01-31-2012, 09:01 AM
Jedi Master
cris90's Avatar
hpw does this work?
Fav. JT Quote
cris90 is offline
post #4 of 84 Old 01-31-2012, 01:52 PM
Site Sponsor
Jay@SFR's Avatar
Quoted: 213 Post(s)
It's a simple replacement of OEM clutch rod but adjustable.
TEL 215.300.3397
YOUTUBE CHANNEL
OEM/KDM/AFTERMARKET
Jay@SFR is offline
post #5 of 84 Old 01-31-2012, 02:12 PM
SJ is the man
JewishThunder's Avatar
So it would effect the grabbing point? I wouldn't mind mine being a little lower to the floor.
Joe's milkshake brings all the boys to the yard...
I AM SPECIAL!
JewishThunder is offline
post #6 of 84 Old 02-01-2012, 06:02 AM
Jedi Master
cris90's Avatar
so i could adjust where the clutch sit normally? is so this would be pretty nice. i'd want it 1-2 inches lower then where it is right now.
Fav. JT Quote
cris90 is offline
post #7 of 84 Old 02-03-2012, 09:01 PM
bfx805's Avatar
Is this for the 2.0t or the 3.8? Or is it the same for both? I am interested in one for the 2.0t.
bfx805 is offline
post #8 of 84 Old 02-04-2012, 04:27 PM
Site Sponsor
Jay@SFR's Avatar
Quoted: 213 Post(s)
That is correct.
It's for both.
TEL 215.300.3397
YOUTUBE CHANNEL
OEM/KDM/AFTERMARKET
Jay@SFR is offline
post #9 of 84 Old 02-05-2012, 03:59 AM
Site Sponsor
Jay@SFR's Avatar
Quoted: 213 Post(s)
This is installed picture. Hope this helps.
TEL 215.300.3397
YOUTUBE CHANNEL
OEM/KDM/AFTERMARKET
Jay@SFR is offline
post #10 of 84 Old 02-05-2012, 05:54 AM
Jedi Master
cris90's Avatar
i'lll probably get this.... maybe in april during the meet.
Fav. JT Quote
cris90 is offline
post #11 of 84 Old 06-10-2012, 11:22 AM
I bought one from SFR (Clutch rod adjuster kit) but when I tried to install it, I couldn't get the old rod out. Like the new part, the old rod has a collar just below the tip of the rod...and this collar snags something up inside the hole and can't be pulled out. The area is extremely difficult to view, but I can see what appears to be a sliding spring clip (or something) that's installed within the large nut, that snags the tip of the old rod. No instructions came with the new rod, and my Hyundai service mgr. tried looking up the clutch pedal assembly online, but it doesn't show an exploded parts view, just a complete assembly view....so he had no idea how to remove the old rod. I had to post a question back to the manufacturer on their website....and am currently awaiting a response. I'll post it here if/when they respond.
JustaSomeGuy is offline
post #12 of 84 Old 06-10-2012, 04:45 PM
I should have clarified that the 'hole' where the clutch rod goes, is actually a nut that is part of the clutch master cylinder assembly, and that protrudes through the firewall and connects to the pedal assembly. The nut is partly covered by a rubber dust boot. Hopefully Jay at SFR will post some simple instructions here, or respond to my online query soon so I can pass it along to others. I've had several cars whose clutch rods were NOT captive and could be easily removed or adjusted via built-in threads. The way Hyundai engineered this for the Genesis Coupe is unusual, in my experience. However since it is a 'performance' vehicle I well appreciate the fact that the rod is engineered so it can't come out of its socket accidentally.
post #13 of 84 Old 06-10-2012, 05:46 PM
GT30Rspec
TVONE2's Avatar
PITA..
Yes the Hyundai design defies logic..
You have to remove the plastic clip inside the master cyl. to release the old rod..CAREFULL when you get the clip off and the rod comes out fluid/piston comes out with it..may have to bleed clutch to be safe..just put it back the way it comes out and you should be fine..had me scared at first for sure..Great Mod! well worth the time and effort.. Price????????
PowerAxel
TVONE2 is offline
post #14 of 84 Old 06-10-2012, 06:27 PM
can you make the cylinder push further in with this?? my engagement point is a bit too low so i would like to be able to correct it ..
davidp is offline
post #15 of 84 Old 06-10-2012, 06:30 PM
GT30Rspec
TVONE2's Avatar
Yep!
It works like a charm
PowerAxel
TVONE2 is offline
post #16 of 84 Old 06-10-2012, 06:32 PM
Site Sponsor
Jay@SFR's Avatar
Quoted: 213 Post(s)
^ Thank you TVONE2
TEL 215.300.3397
YOUTUBE CHANNEL
OEM/KDM/AFTERMARKET
Jay@SFR is offline
post #17 of 84 Old 06-10-2012, 06:34 PM
Site Sponsor
Jay@SFR's Avatar
Quoted: 213 Post(s)
Hello
I will see what I can do for instructions. We've installed about 15+ so far and our mechanic spent about 20min to do the install.
I shall post some instructions when I Can.
TEL 215.300.3397
YOUTUBE CHANNEL
OEM/KDM/AFTERMARKET
Jay@SFR is offline
post #18 of 84 Old 06-10-2012, 06:39 PM
Originally Posted by TVONE2 View Post
Yep!
im just at the point where sometimes the clutch is on the edge of not disengaging completely and while driving it makes the gears harder to shift so you really confirm that this can give me more clutch travel?
just to make sure .. if yes ill order this right away
davidp is offline
post #19 of 84 Old 06-10-2012, 06:45 PM
GT30Rspec
TVONE2's Avatar
I thought it was only me.. man this thing is awesome! get it and all the clutch feel it brings..
PowerAxel
TVONE2 is offline
post #20 of 84 Old 06-11-2012, 04:54 PM
PITA..
How does one remove that plastic clip? Remember we're talking lying sideways with our head and shoulders jammed up under the dash, trying to hold a flashlight, trying to see something black inside of something black....it's certainly not obvious that there's a plastic clip in there. Does it slide out? does it require snap ring pliers? More details please - thanks!
MAPerformance - Unbeatable Pricing on Spec Clutch, Competition Clutch, Clutchmaster! maperformance Vendor Drivetrain 191 02-14-2013 06:27 AM
To Clutch or Not To Clutch--Must Read For Manny Tranny Newbies BKED Drivetrain 25 01-23-2012 11:09 AM
Coilovers -equal spring adjuster height, shock length... different ride height? ClayMan Suspension 2008-2012 6 07-09-2011 05:35 PM
MMmmH!...Clutch master stage 3...3 month later..clutch cylinder is death... :S matcoupe Drivetrain 7 05-31-2011 09:18 AM
Worn stock clutch vs Twin clutch system (pics) Galbi Drivetrain 2 08-01-2009 08:51 AM
