Question regarding ride height amount - Genesis Forum: GenCoupe Hyundai Genesis Forums
Old 02-03-2012, 12:41 PM   #1
Lucid's Avatar
Default Question regarding ride height amount
I am looking to lower the ride height on the gencoupe and wanted to know what would be the maximum height that it can lowered before having to worry about scraping (mines a daily driver and streets in Toronto are not car friendly).
Genesis Coupe 2.0 T Bathurst Black/5spd Auto
AEM . GRIMMSPEED . MEGAN RACING . TURBOXS . HKS . GARAGELINE
Lucid is online now   Reply With Quote
Old 02-03-2012, 02:48 PM   #2
yimnvs's Avatar
Eibach pro-kit is for you if you don't want it to be too low.
Luxon Grill
Superlux Tails
DD 6K HID
Stance SC-5
Eibach Pro-Kit
Magnaflow CBE
BTRcc Canned Tune
yimnvs is offline   Reply With Quote
Old 02-03-2012, 03:44 PM   #3
Under Construction
jonjon72's Avatar
I'm running on Tein's which I believe is a 1.2" drop front and rear. Live in the GTA and have zero issues scraping. I could go a bit lower but past that stage in life of having my daily driver slammed to the ground.
jonjon72 is offline   Reply With Quote
Old 02-06-2012, 06:07 AM   #4
Lucid's Avatar
thanks for the info.
Old 02-15-2012, 05:58 AM   #5
Male Member
Slobes's Avatar
Pro-Kit or try the new ARK GT-f springs...they aren't as low as tein's or sportlines but are great products.
'10 Silverstone 3.8
- - CHECK OUT MY BAND - -
www.ScarlettDrive.com
Slobes is offline   Reply With Quote
Old 02-15-2012, 08:28 AM   #6
That's a really broad question. You're answer would like in bumper/under carriage to ground clearance, tranlated into fender to wheel clearance. If that makes sense. Only you will know how much clearance you want/need.
danslides is offline   Reply With Quote
Old 02-15-2012, 08:37 AM   #7
Lucid's Avatar
It wasnt a question about how much clearence i want but more along how much would be a safe distance before i have to worry about scraping, but thanks for your input.
Old 02-15-2012, 03:23 PM   #8
JK-DM!
nellyville41's Avatar
Pro Kit. Just got mine installed this past weekend. I was still able to go head on into most driveways. No need to angle it. Of course just go slower than before and you should be good.
My Current Build Thread
http://www.gencoupe.com/media/104664-nellyville41s-jk-dm-current-build-thread-pic-heavy.html
nellyville41 is offline   Reply With Quote
Old 02-15-2012, 06:24 PM   #9
Flip! What the zip?!
Hijinx's Avatar
[semi-rant] People always say, "Oh, I have bad roads, I have bad roads, blah blah blah..." You know what? It's not that serious. Drop your freaking car, and move on with life. I dropped my car darn near 2" and I've scraped maybe five times...with AGGRESSIVE driving. There are areas in my town with "bad roads"... I drive through them just fine. I don't even avoid them. Sure, there are a few dips and bumps I slow down for, but... "Bad roads" will never stop me from modding my car. [/semi-rant]
DEPO | BTRcc | MEGAN | SAMSUNG | MST | NGK | GrimmSpeed | Torque Solutions
Hijinx is offline   Reply With Quote
Old 02-15-2012, 08:47 PM   #10
College Student :(
tsukubarspec's Avatar
i slammed mine on coils and scraped on everything... so disregard above post. most speed bumps are about 2" so as long as you're above that you will be fine without angling. take it slow and angle if you can but any lowering spring will be fine without scraping.
2010 C0333/01 NGA-It went boom EDIT: Warrantied by Hyundai! Brand new motor.
Tenzo wheels for sale.
tsukubarspec is offline   Reply With Quote
Old 02-16-2012, 10:23 AM   #11
Ok just my 2 cents....... my previous car was a 09 rx8 and I slammed this thing soo low i couldn't even pass over any and i mean ANY speed bumps and this was my daily driver. Now i didnt want this issue with my genesis but i wanted to appear as low as coilovers so i got the Ksports that lower the car approximately 2 inches. I have had these on the car now for about 1.5 months now they seem to have settled beautifully and my handling is awesome. Now to the point of this post i have absolutely no issues over speed bumps, driveways, pretty much anything I have had 4 ppl in my car totaling well over 600lbs and i never scrapped anywhere.
I live in toronto as well and you should be pretty much good to go 2 inches no problem. Hope this helps.
regards,
4g63 is offline   Reply With Quote
Old 02-16-2012, 04:53 PM   #12
bad roads ie potholes hit at high speed can destroy OEM struts...just saying
chetman7 is online now   Reply With Quote
Old 02-16-2012, 04:58 PM   #13
Lucid's Avatar
regards,
Thanks for the input. I will most likely do springs for the time being and do coil overs later.
that's neither here nor there but thanks
Old 02-16-2012, 05:16 PM   #14
Old 02-16-2012, 05:23 PM   #15
Here to Party!
JewishThunder's Avatar
Any spring set keeps you safe of scraping. As far as coils any lower than 2" or so and you have to be careful of things. Especially if your exhaust hangs low or if you have any lips body kit etc...
Serena is home. As loud and black as ever.
JewishThunder is offline   Reply With Quote
Old 02-17-2012, 10:10 AM   #16
So ground clearance doesn't translate into scraping?
You're asking a loaded question. My response was to let you know only YOU know how low is low enough. Maybe you rarely encouter a large dip or speed bump, maybe where you drive is littered with pot holes and steep inclines.
People who generically answer this question without knowing YOU, YOUR car and YOUR driving routes/habits can't advise you to the best answer..
Personally, I just want to be slammed.
DSC00858 by dopepushers, on Flickr
Old 02-17-2012, 12:14 PM   #17
BLK N YLW
Merkles's Avatar
I drive on sportlines in New England all year long and don't scrape. Perfect height
35,000 miles on my sportlines, no complaints.
2010 Interlagos Yellow 3.8 Track
Merkles is offline   Reply With Quote
Old 02-17-2012, 03:49 PM   #18
College Student :(
Will scrape lips hide how high you really are
Coilovers -equal spring adjuster height, shock length... different ride height? ClayMan Suspension 2008-2012 6 07-09-2011 04:35 PM
Modified Suspension / Ride Height thread! ClayMan Suspension 2008-2012 13 06-23-2011 01:35 PM
Wow @ amount of potential DropTheGloves 2.0T Discussion 2008-2012 23 05-11-2010 05:49 AM
Amount of Oil GennyBK 2.0T Discussion 2008-2012 8 03-27-2010 10:33 AM
Amount of gas effecting performance? Madhockeyplaya7 3.8 V6 Discussion 2008-2012 22 03-10-2010 02:48 AM
