Strut mount top hat - Hyundai Genesis Forum
post #1 of 8 Old 02-08-2017, 04:30 PM Thread Starter
Dfwlly's Avatar
Quoted: 29 Post(s)
Question Strut mount top hat
Talk about a SOB. Been practicing removing the suspension components and I have to say, it's really easy to remove and replace the struts after a few times! Anyways, I have my Bilstein's delivered and when I removed the stock strut today, the top hat nut comes off easy enough, but the hat is stuck no matter how hard I hit it with my BFH. I'm wondering if the last time I tightened down the top hat nut if I damaged some component, causing the hat to jam onto something else.
Any tips for getting the hat off? I have new hats coming, but I need to get the Eibach springs moved over to the new struts. Thanks dudes!
2013 Ultimate AT, Tsukuba Red
BTR Canned Tune
Maxbore ported TB to 82MM, Coolant bypass mod
Injen SRI
Phenolic IM spacer
IAT shaved
Muffler delete with Depot Racing test pipes, replaced with 3" to stock tips (OH GOD THE DRONE)
Diode Dynamics interior LED kit
Dfwlly is offline
post #2 of 8 Old 02-09-2017, 04:12 AM
shorttrack
Quoted: 143 Post(s)
Use spring compressor ,might be just cocked to 1 side .
Nightmare On Any Street .
shorttrack is offline
post #3 of 8 Old 02-09-2017, 05:32 AM Thread Starter
Dfwlly's Avatar
Quoted: 29 Post(s)
Yeah I used a spring compressor, and compressed it enough to be able to spin the top hat.
BTR Canned Tune
Injen SRI
Phenolic IM spacer
IAT shaved
Dfwlly is offline
post #4 of 8 Old 02-09-2017, 05:53 AM
Korean Asswhoopin
Thumb5's Avatar
Quoted: 86 Post(s)
This will be scary but... use the spring to release the hat. Spin the nut a few threads onto the shock so that hat doesn't shoot off, then loosen your spring compressor to put tension on the hat. See if that will get it to let go. Obviously spray penetrate on it as well. Just BE CAREFUL!
2010 Grey Hyundai Genesis Coupe 2.0T Track - Beyond Redline - Haltech and BW EFR 7063 - 385 whp and 345 wtq - Crappy gas
2016 VW Tiguan S Daily
Thumb5 is offline
post #5 of 8 Old 02-09-2017, 06:02 AM Thread Starter
Dfwlly's Avatar
Quoted: 29 Post(s)
I'll give that a shot, and then if that fails I will sawzall the hat off. I may also try what I've tried in the past, use no spring compressor - lay the strut in the grass - use impact to loosen the nut and watch out! Hopefully the force and vibration will jiggle the hat free.
It looks like there is a small piece of metal that has the hat locked onto the threads.
BTR Canned Tune
Injen SRI
Phenolic IM spacer
IAT shaved
Dfwlly is offline
post #6 of 8 Old 02-09-2017, 10:44 AM Thread Starter
Dfwlly's Avatar
Quoted: 29 Post(s)
I posted to the Facebook Genesis Owners. Someone had a similar problem, said when you tighten down the top hat nut on to a lowering spring it can jam the bearing onto the shaft and you can either cut it off or beat the hell out of it with a hammer. I will try cutting it off as a last resort.
BTR Canned Tune
Injen SRI
Phenolic IM spacer
IAT shaved
Dfwlly is offline
post #7 of 8 Old 02-09-2017, 12:01 PM
Korean Asswhoopin
Thumb5's Avatar
Quoted: 86 Post(s)
Yea when fully extended on the eibach sportlines you don't even need a spring compressor to disassemble the fronts. Not much tension on them
Thumb5 is offline
post #8 of 8 Old 02-09-2017, 12:48 PM Thread Starter
Dfwlly's Avatar
Quoted: 29 Post(s)
They're the Pro springs so not as low, but I know what you mean.
BTR Canned Tune
Injen SRI
Phenolic IM spacer
IAT shaved
Dfwlly is offline
Replace just strut mount or struts too? fred2028 Suspension 2013 and up 4 08-29-2015 06:44 PM
T3 top mount whatever210 Engine 6 10-19-2011 08:43 AM
Top Mount vs Bottom Mount Manifolds Tyr 2.0T Discussion 2008-2012 5 06-27-2011 07:48 AM
Strut Mount subyhau Suspension 2008-2012 1 05-22-2011 10:47 PM
Front Strut Mount suttonschinook Suspension 2008-2012 1 03-22-2011 09:26 AM
