DIY: Fix Your Curb Rash - Hyundai Genesis Forum
post #1 of 72 Old 03-19-2010, 08:18 PM Thread Starter
Finesse Is Everything
CaptainSlow's Avatar
Lightbulb DIY: Fix Your Curb Rash
I followed the directions per the following link:
BMWTips wheel-scuff repair
I am happy with the results and would endorse this method. I have never done anything like this and managed to get through it. I did all of this with Aerosol cans. Those of you who have air brush equipment can make it look even better. Here is a photo synopsis of the job.
Prep work and preview of curb rash
First of many coats of Spot Bondo. Used 320 grit for first 2 layers. Then 600 to finish. Basically apply small amounts at a time to fill in slowly. End with fine grit (1000) to even out smoothness.
Taper primer from damage out.
Frist coat of 3. These coats are all tapered from damage source towards center of spokes.
After base coat but before the clear coat. Dry to touch paint still settling in. You can see the curb rash is gone.
After 3 light coats of clear applied. Color set in nicely.
I will be taking some outdoor photos soon with this reclaimed wheel. The total investment was about 30 US dollars .
1 Can of Primer
1 Can of Base Coat
1 Can of Clear
1 Pack of Sand Paper from 180 - 1500 Grit
1 Tube of Spot Bodo
1 Can of Paint Thinner for cleanup
Slowest Gencoupe Driver in The North East
"You know those dot matrix on the M5....I was in my mates kitchen drying my underpants in the microwave and when it had finished it said "enjoy your meal" -James May
CaptainSlow is offline
post #2 of 72 Old 03-19-2010, 08:25 PM
My other ride has 4000hp
whatnot's Avatar
nice find, and looks good.
whatnot is offline
post #3 of 72 Old 03-19-2010, 09:08 PM
dwpers's Avatar
Aww it looks so purty, glad you are taking good care of them and providing them a good home .
2010 Genesis Coupe Track, 380 GT V6
Road Race Motorsports Short Ram Intake/Lightweight Pulley
AXIS Super Penta's 19x8.5" / 19x9.5", Wrapped in Falken 452's 245/19 275/19
M&S/SFR Type D Grille, Super LUX LED Taillights
35% Tint, Diode Dynamics Stage 2 LED Kit
Ark Performance True-Dual Exhaust System...and other goodies
Sponsored By: Ark Performance, BC Racing, AXIS Wheels
Originally Posted by Ruinerofallfun View Post
Dear god man, use your search! lol
dwpers is offline
post #4 of 72 Old 03-20-2010, 04:17 PM
SixMT's Avatar
i'd like to see the outdoor pics, when you get them up. could just be the lighting, but the bottom of the wheel in that last pic looks way more matte than the rest of the wheel. is that the spot where you repaired?
Silver 2.0T Track
SixMT is offline
post #5 of 72 Old 03-20-2010, 04:21 PM
Use the F'n Search Button
mmrp81's Avatar
keep in mind that this method only works on certain colors and wheel material. The stock wheels on the GC are some of the easier wheels to fix.
They cost about $50 to have a company fix them. They grind the curb rash away, then they fill it and sand it, and paint. Not sure if they only paint a portion of the wheel or the entire thing.
mmrp81 is offline
post #6 of 72 Old 03-20-2010, 04:23 PM Thread Starter
Will do, I took those picture about and hour after the job as done. The clear coat really changed a lot overnight. You can tell when you go up close it was done. From a foot or so away looking down not so much. I will get those up soon. Be great if someone tried this who has better technique and make a follow up to this. I think the aerosol can is not exactly the best for doing any fine detail work.
post #7 of 72 Old 03-20-2010, 04:27 PM Thread Starter
I would advise if you arn't patient and don't have a steady hand to do this....
This did take me some time.....
post #8 of 72 Old 03-20-2010, 07:04 PM
vox
vox's Avatar
The problem with fixing curb rash on the track wheels is that there's no exact match for the paint. It's darker and shinier than any of the typical silver paints.
I know, because I'm repainting an entire set.
The OEM 18's are a different color than the 19's. The 18's match more of what's out there in terms of paint color.
To get it perfect you really have to repaint all the wheels.
GR WRX | S2000 CR
vox is offline
post #9 of 72 Old 03-21-2010, 09:52 AM
2.0T Track
taspankya's Avatar
costs about 150-200 to repaint a wheel around here, same as powder coating... i called many places to get quotes.. i have the same paint as mcjazzy i believe, and its supposed to be an exact match to the oem hyper silver. i tried the patch method that mcjazzy did and failed.
btw my curbrash was slightly worse, it hit the aluminum, not just paint.
so i took the tire off the wheel and am painting the whole thing. hopefully the finished product will match close enough to the other wheels. if not - not sure what i will do.
right now i am at a clean primer stage, ready for paint, hopefully before it gets dark today. plan to put some duplicolor clear wheel sealer on it as a clear coat.
will post pictures here, i dont think mcjazzy will mind
taspankya is offline
post #10 of 72 Old 03-21-2010, 10:43 AM Thread Starter
My damage was very minor and only dug into the aluminum slightly.
taspankya you don't need my blessings to post your DIY onto this.
More the merrier!
Here are two quick shots in the parking spot today of the finished wheel...
Do note that I tapered the paint into the center of the wheel to try and get the hyper silver paint to blend the best I could...
post #11 of 72 Old 03-21-2010, 10:59 AM
2.0T Track
taspankya's Avatar
looks good
i just put a coat on the wheel and i already can tell its not a match for me. it looks like grey with specs of glitter! .... i dont know what i;m going to do with this, im ready to give up and put the 19"s for sale in the private classifieds..
look at this crap!
supposed match:
oem:
post #12 of 72 Old 03-21-2010, 11:07 AM Thread Starter
Yeah, the hyper silver is not an exact match. At least from what I can tell. Wonder if you should do all of them? I can tell you that after a day of letting everything set in it got better.
post #13 of 72 Old 03-21-2010, 11:14 AM
2.0T Track
taspankya's Avatar
if i can find a local place that can sandblast all the paint off all these rims and paint them the color of my choice i will prob do that. its just so expensive, its almost cheaper to buy new rims!
post #14 of 72 Old 03-21-2010, 05:02 PM
vox
vox's Avatar
Do you have a link to that 'hyper silver' paint?
Are you sure the paint isn't an exact match to the OEM 18's? They have a brighter thicker finish to them.
Like I said, paint the whole set of wheels and you'll be fine. Paint isn't that expensive. It's all in the prep/cleaning. Pick any color you want if you'd like.
GR WRX | S2000 CR
vox is offline
post #15 of 72 Old 03-21-2010, 06:08 PM
2.0T Track
taspankya's Avatar
2008 Hyundai All Models, 12 oz Aerosol Spray Paint :Hyper Silver Met KM
from automotive touchup / microfinish
I am trying to match the OEM 19 paint. Everyone is telling me to just paint the others, but I don't have the time or patience to go through this same process w/ 3 more wheels.
i;ll call around tomorrow to see if someone can match the paint and do it for a reasonable price. if not then its going on there like it is. idc anymore
100 is reasonable to me, 200 is not.
post #16 of 72 Old 03-21-2010, 06:50 PM
vox
vox's Avatar
[QUOTE=taspankya;277721]^^
QUOTE]
Yeah unfortunately the wheels are different colors.
It's the same case with some G35 wheels. Nobody could find an exact match for the paint and getting custom matched paint was too expensive.
GR WRX | S2000 CR
vox is offline
post #17 of 72 Old 03-23-2010, 03:31 PM
JoelB's Avatar
Just to avoid to repaeat all my story about that... : http://www.gencoupe.com/wheels-tires...tml#post280469
Joel
Before: Genesis coupe 2.0T GT silverstone 2010
Now: Dodge Challenger R/T Classic 2011
JoelB is offline
post #18 of 72 Old 03-23-2010, 03:47 PM Thread Starter
Past few days comments from people who saw the work in person...
If anyone is interested....
I have had several people look at the job. These people who looked are car enthusiasts and do not have vision problems. Until I pointed it out which wheel it was never mind where the work was done and they they didn't notice. I got thee wheels at an unbelievable price and wanted them for the better performance over 18" OEM.
I can assure to anyone using this paint with the method I used will work if you aren't persnickety, have a steady hand, and are accepting of the result as I posted above. This who deal with the wheels only cost me 550 bucks and change. ;-)
post #19 of 72 Old 03-23-2010, 03:57 PM
2.0T Track
taspankya's Avatar
mine is at a wheel shop, with one of my perfect OEM rimsm hopefully they can match it to it.
the guy seemed confident he could match it and said $125 - it should be done in a week.
wish me luck on the match
i;ll let you know the results. but i fear the worst
post #20 of 72 Old 03-24-2010, 05:00 AM
Thanks for the info, great DIY
Cip500 is offline
