brembo pad replacement - Page 2 - Hyundai Genesis Forum
post #21 of 85 Old 02-12-2011, 07:20 PM
Binz's Avatar
Originally Posted by fazerG8R View Post
I've never changed Brembo pads before, but it sure looks like a novice might change the pads and take off without pumping the pedal to get the pistons back out. If you do this, pump your brakes, and make sure you've got a firm pedal before you take off. BTW, thanks for the link, this really seems simple. But when I do mine I'm going to pull the calipers a clean the dust from around the piston seals.
Childs play. Even I can do it
Takes at the most 60 minutes for all 4 wheels. Counting jaking and taking wheels in and out of bolts.
Silverstone Genesis 2010 380 GT Auto
Binz is offline
post #22 of 85 Old 04-02-2011, 06:20 AM
no bleeding brakes awesome
etown60 is offline
post #23 of 85 Old 04-02-2011, 06:36 AM
BlackTrackAna's Avatar
great links. thanks
BlackTrackAna is offline
post #24 of 85 Old 04-02-2011, 10:37 AM
And easy to bleed if you need to. Just crack open the bleeder valve and let gravity work for you.
post #25 of 85 Old 04-25-2011, 09:00 PM
Her Name is Elisabeth Jr.
babbitteb's Avatar
Any idea what grease the guy put on the pads in the evo video before putting the fresh set in is?
'11 3.8 Track Karussell White | 3M Medium All-Around Tint | Magnaflow #16507 | Ventureshield Clear Bra | Blacked-out OEM Badges | Hella Supertones Horns | AEM CAI
Previous Rides:
'11 Sonata Turbo SE
'10 V6 AT, Karussell White | 3M Medium All-Around Tint | Ventureshield Clear Bra | Magnaflow #16507 | DD Stage 3 LEDs | DD 6000k HIDs | DD 2 Way LED Signals
babbitteb is offline
post #26 of 85 Old 04-25-2011, 09:49 PM
Usually just silicone dielectric grease like what you put on spark plugs.
post #27 of 85 Old 04-26-2011, 04:22 AM
Craig@Invision's Avatar
http://i47.tinypic.com/fv8qhc.png
www.InvisionAutomotion.com
Find all your aftermarket products for your Hyundai Genesis Coupe!
Brakes, Cosmetics, Performance, ECU Management, Suspension, Wheels,
Lighting, and Car Care are all available through our online store!
Craig@Invision is offline
post #28 of 85 Old 05-27-2011, 06:26 AM
bruceoiii's Avatar
has anyone actually done this successfully on their car? the dealership told me that they would charge 700+ for the replacement of the front brake pads...
And how would you know if it is necessary to bleed the brakes or not?
bruceoiii is offline
post #29 of 85 Old 05-27-2011, 06:31 AM
Ummm, yea. Your new to cars, aren't you?
post #30 of 85 Old 05-27-2011, 02:13 PM
I drive a V6
2.0TGT's Avatar
Quoted: 29 Post(s)
i just did this last weekend, super easy.
One thing to note...
I used Hawk HPS and the rears would not fit. No matter how hard I tried, the rear pads were too wide to fit. In fact it wasnt the pads, it was the shim stuck to the back of the pad. Hawk has some fancy rubberized metal shim stuck to the back of the pad, it was just thick enough to interfere with the seals/pistons.
I ripped them off and they went in perfectly.
I thought Id hear squeeks and rattles without the shim but fortunately there was no ill effect.
2.0TGT is offline
post #31 of 85 Old 05-27-2011, 10:17 PM
bruceoiii's Avatar
this may be my first car...i didnt think it was that obvious hahaha my bad i just want to do this without effing anything up
post #32 of 85 Old 05-28-2011, 05:45 AM
You don't need to bleed the brakes. Pad replacement is really easy if you have Brembos.
http://www.gencoupe.com/diy-do-yours...placement.html
BrandonGS is offline
post #33 of 85 Old 05-28-2011, 11:30 AM
It is a good idea to bleed out all the old fluid every two years or so though.
post #34 of 85 Old 05-29-2011, 07:36 PM
Binz's Avatar
Pads up front non brembo should cost you no more that around 100$
Brembo's around 150$
Be careful Hyundai dealers sell the pads 300$ + for stock pads.
Ripoff !!
Take the time to do it yourself you will then know how to change pads for the rest of your life !
When you are used to it,it should take you no more than 1 hour for all 4 wheels.
Binz is offline
post #35 of 85 Old 05-30-2011, 09:14 AM
Ripoff !!
Front pads for the Brembo brakes should be a little bit less, about $125. Throwdown sells EBC red stuff for $126, which I think is hands down the best non-track pad on the market. I've used them before and the only reason I'd switch to a different brand is if EBC stopped making them.
post #36 of 85 Old 05-30-2011, 06:18 PM
Just ordered a full set of the Yellowstuffs for $250 shipped.
post #37 of 85 Old 05-30-2011, 10:15 PM
bruceoiii's Avatar
whats the difference between red and yellow stuff?
post #38 of 85 Old 05-31-2011, 05:24 AM
Read this chart: Easy to Use Brake Selector Chart | EBC Brakes
Read these too, since it's a bit hard to explain:
Red:http://www.ebcbrakes.com/automotive/...ake_pads.shtml
Yellow:http://www.ebcbrakes.com/automotive/...ads_4000.shtml
post #39 of 85 Old 06-02-2011, 04:39 AM
Binz's Avatar
Yellow for track use
Red for street use.
Yellow less dust and noise that the Hawks HP Plus.the Hawks sound like a bus is stopping.
Binz is offline
post #40 of 85 Old 08-30-2011, 06:15 PM
Here is the EBC Yellowstuff rear part number.
DP41140R
anyone have trouble to install the EBC yellowstuff rear pads into the brembo calipers? mine is difficult to fit in. the pads are bit wider than the stock pads.
youngtheking is offline
