#2 | ||
Site Sponsor
Are you intrested in Stoptech or Brembo Rotors.
Also Stoptech pads or Hawk Pads Last edited by 2uniq@UNIQPERFORMANCE; 01-02-2012 at 07:09 PM. |
#4 | ||
Site Sponsor
Pm sent
#5 | ||
PM me too, HawkPads BREMBO + BREMBO Rotors w/ drilled and without, I'm looking to buy great quality brakes and rotors so please recommend something else if you like.
Searching for: - DD HIDS for 2.0T - DD LEDS STAGE 2 or 3 & WHITE |
#6 | ||
Site Sponsor
Pm sent
#8 | |||
Site Sponsor
#9 | ||
just a question. why would you use ceramic pads? i thought ceramic pads were for racing because they work better when they are worked hard and heat up.
#10 | ||
Site Sponsor
![]() Join Date: Jan 2012
Ceramic pads are much quieter, don't wear down the rotor as quickly as well as the pads, can handle high temperature with less heat fade, and generate much less dust, and what it does generate isn't noticeable and is less likely to stick to the wheels.
All the different kinds of pads have their ups and downs, but ceramic is probably the best all around pad. |
#14 | ||
#15 | ||
Site Sponsor
The stock rims on my Tiburon weren't the best taken care of (in terms of cleaning) so the brake dust inside the rims is basically caked on. I tried to clean it once and after making ZERO progress, I gave up.
I try to keep my Tenzo's clean now. |
#17 | ||
Site Sponsor
Pm sent Sir
#19 | |||
Site Sponsor
yes we do but i wont have pricing for about a week because we are inputing new products in our system Please touch base with me then Thanks |
#20 | ||
Sorry for being a little off topic but do you know of a single piston caliper that will fit our rear brembo rotors?
No sorry i wouldnt know BTW why would you want to go single Last edited by 2uniq@UNIQPERFORMANCE; 02-07-2012 at 10:00 PM. |
| Need help buying new Brake Rotors and Pads please! | Canuck | Wheels, Tires and Brakes 2008-2012 | 7 | 04-18-2011 09:17 PM |
| Need suggestions on front pads and rotors replacement | masif | Wheels, Tires and Brakes 2008-2012 | 16 | 03-30-2011 05:38 PM |
| Just ordered Stillen rotors and pads | TRock | Wheels, Tires and Brakes 2008-2012 | 13 | 02-27-2011 05:25 PM |
| Help!! what are the best brake pads and rotors available for the 3.8 track? | Miami Beast | Wheels, Tires and Brakes 2008-2012 | 0 | 09-02-2010 02:47 PM |
