Is it ok to park your car w/ wheels turn-ed? - Hyundai Genesis Forum
post #1 of 16 Old 08-22-2010, 07:09 PM Thread Starter
yellowmp5's Avatar
Question Is it ok to park your car w/ wheels turn-ed?
As stated in the topic, is it ok to park your car w/ wheels turned? or
should i alwayz keep the wheels straight, facin' front only?
reason is that i see that our car is like the european cars,
that it angles (camber?) when you turn ur wheels...
please advise~
2010 Karussell White Genesis Coupe
yellowmp5 is offline
post #2 of 16 Old 08-22-2010, 07:48 PM
///H Power
djhaose's Avatar
I don't see a problem if you dont turn the wheels when the car is in a stand still.
Karussell White :: 3.8 V6 :: Manual :: Navigation
BBM Spoiler \ M&S Type-D Grille \ Osram 8000K HID \ Sylvania 4000K Fog and High Beam \ AEM Cold Air Intake \ Stance GR+ Coilovers \ GT Spec Strut Bar \ KPR Shift Knob \ Falken FK-452 245-275 \ Forgestar F14 19" Wheels \ SFR 3.8 ECU Reflash \ Magnaflow Cat-Back Exhaust \ Diode Dynamics Kit and Switchback LEDs \ SuperLux LED Tail Lights \ Brembo Retrofit \ Slotted Rotors \ Hawk Pads \ Techna-Fit SS Brake Lines \ SS Track Pedals
djhaose is offline
post #3 of 16 Old 08-22-2010, 07:50 PM
KWC2.0T's Avatar
pros and cons to both but since your car is not moving... not too much of a difference
if your car is parked for a day or 2 with the wheels turned you wont do any damage but if you were storing the car for a while... i would keep the straight and flat on the road...
the pros come to parking on the street... it was taught in drivers ed to turn your wheels right when parking on a down hill and to the left when parking on an up hill... what this will do is block off the tire IF the car tried to roll away and would steer it out of traffic causing an accident.
KWC2.0T is offline
post #4 of 16 Old 08-23-2010, 01:18 PM
GET OFF MY LAWN!
Boozysmurf's Avatar
+1^^
This. When parking on a hill, especially if you drive a stick, you should always turn your wheels so that the car angles into the curb first as it rolls (if both the brakes and gears don't lock it in place).
So, if you're driving up hill, and park, you should turn the wheel so that the front of the drivers side wheel points out into traffic. If your brake and gear (you left it in gear, RIGHT?) let go, the car rolls backwards, and the inside/passenger front wheel will roll INTO the curb, stopping the car. This only works if you've parked properly (ie. close enough to the curb).
Does Driver's Ed still teach this? Do they even teach manual trans anymore? (it's been a while. I feel old!)
Boozysmurf is offline
post #5 of 16 Old 08-23-2010, 02:44 PM
Performance parking for the win. Just make sure the car is angled and taking up two spots. Bonus points if you're using three.
In all seriousness though, yes you do want to park with the wheels turned on a hill as stated above. Yup, we learned that in Driver's Ed. Learned stick too, conceptually, all of the practice cars were automatic Plymouth Breezes.
Mitch Hedberg
N2OInferno is offline
post #6 of 16 Old 08-23-2010, 03:07 PM
willyolio's Avatar
did you pass your driver's test yet? because on any kind of incline, you're supposed to park with wheels angled.
willyolio is offline
post #7 of 16 Old 08-23-2010, 05:17 PM
Former GTO hater/ owner
heymccall's Avatar
And, if you park on a hill in San Francisco with the wheels straight ahead, you WILL get a ticket.
No, it will NEVER harm your car.
Now
2013 Genesis Coupe
Shoreline Handshaker
Then
2010 Genesis Coupe
Interlagos Handshaker
heymccall is offline
post #8 of 16 Old 08-23-2010, 06:38 PM Thread Starter
yellowmp5's Avatar
great! thx for all the replies!
post #9 of 16 Old 08-23-2010, 06:46 PM
Retired Staff
I Drive Naked's Avatar
Quoted: 20 Post(s)
Park with the wheels upside down, so all the air is on the top
2011 Tsukuba Red 2.0T RSpec
Enkei / KDM-Racing / Eibach / GTSpec / TurboXS / StopTech / ISC Suspension / TrackKing Racing / HPS
SCCA Autocrosser. Slow car, fast driver
I Drive Naked is offline
post #10 of 16 Old 08-23-2010, 06:56 PM
This is terrible advice. The car will float away.
Mitch Hedberg
post #11 of 16 Old 08-24-2010, 01:18 AM
GET OFF MY LAWN!
Boozysmurf's Avatar
No,no, no! It's fine as long as you're nitrogen filled.
post #12 of 16 Old 08-24-2010, 06:12 AM
Administrator
qwaszx's Avatar
how about filling your tires with helium?
Originally Posted by Stevejohns29 View Post
Im learning JB! lol
qwaszx is offline
post #13 of 16 Old 08-24-2010, 06:19 AM
Use the F'n Search Button
mmrp81's Avatar
Just get wheels like this:
mmrp81 is offline
post #14 of 16 Old 08-24-2010, 06:25 AM
If u don't kno, now u kno
DPaik's Avatar
if you park on the right side of the road with your wheels turned to the left and there's no curb then ur car is gonna be in middle of the street....this is only done when there is a decent height curb to stop ur car for rolling out....but if there's no curb you have to turn the wheel towards the sidewalk regardless of if you're going uphill or not...so then the car will roll towards the sideway out of the street and avoid the middle of the road
50/50
'10 NoGrey 3.8 ZF-Track/Nav
Diagnosis:
Snow Boots: Enkei RS6 18" 7.5" wide +38 offset
DIY Intake Filter(cone)/Stock Tube
HiPro Power 5900K Fogs
SilverStar 4100K Halogen Hi Beam
Red LED Taglights
Plasti-dipped E&G upper/lower Grill
Prognosis:
n/a
DPaik is offline
post #15 of 16 Old 08-24-2010, 06:29 AM
1-2-3-4-GRRRIIIINNND-5-6
daniel1pist's Avatar
Nevermind.
daniel1pist is offline
post #16 of 16 Old 08-24-2010, 05:40 PM
GET OFF MY LAWN!
Boozysmurf's Avatar
Nice ride, but they'll squeak like crazy!
