Bleeding brakes - Hyundai Genesis Forum
post #1 of 19 Old 03-28-2011, 07:35 PM Thread Starter
clouter's Avatar
Bleeding brakes
So im in the process of changing my brake lines for stainless steel... and at the same time putting motul rbf600 oil...
now its not the first time i bleed brakes
but its the first car I have with ABS
i just wanted to know if there is anything special i need to know or do the brakes bleed the same way as non-abs cars ?
thanks !
2010 6spd Tsukuba Red Premium
- Technafit stainless brake lines, Hawk HP+, Motul RBF600, R-Spec camber bolts
- Black housing lights with 4500k/3000k HIDs, Superlux tails
- Gloss vinyl roof wrap, matt black wheels
clouter is offline
post #2 of 19 Old 03-28-2011, 07:58 PM
Bobaguy's Avatar
*i reached up and did it*
NO SHAME!
-Remember it's mind over matter, I don't mind, and you don't matter.
Mods in Order - Red&Black Carbon Fiber Interior Trim; Lamin-x Gunsmoked Headlights, Smoked Taillights, Yellow Foglights w/ 2.5k Bulbs; 6k Hi Beams; HKS SQV 3 BOV with Hardpipe; Diode Dynamics' LEDs 3; Eibach Sportlines; RRM Pulley; PA Module; SuperDrift wheel spacers; Gunmetal Wing Badge; Injen CAI; DW 550ccs; BR Tune; Unavi Type A; Greddy Informeter; Luxon Grill; Prodigy Lip
Bobaguy is offline
post #3 of 19 Old 03-28-2011, 08:45 PM
I drive a V6
2.0TGT's Avatar
Quoted: 29 Post(s)
nothing special required.
not sure what exact Hyundai procedure calls for...when I did it I just started with furthest caliper from master cylinder and worked my way back.
2.0TGT is offline
post #4 of 19 Old 03-28-2011, 09:10 PM
Sex Machine
Spool2Go's Avatar
Start with...
1)Rear Right, 2)Front Left, 3)Rear Left and last 4)Front Right
Genesis Coupe 2.0T GT MIRABEAU BLUE
BR Reflash w/custom tune|DW 550cc Injectors|CP-E Downpipe w/Hi-Flow Cat & 3" Mid-Pipe|Depo Racing FMIC|G&M SRI|HKS BOV w/Block-off plate|NRG Ground Wire Kit|PTP Turbo Blanket|Eibach Sportlines|R1 Drilled/Slotted Rotors|SS Brake/Clutch Lines|Frixa Brake Pads|19" Bronze 5Axis S5:F Rims|Meaty Continental Tires|ACT Clutch w/ Fidanza Flywheel|
Dynoed 262whp & 282wtq @ 17psi on the Mustang Dyno
Spool2Go is offline
post #5 of 19 Old 03-28-2011, 09:58 PM
슈퍼 쿠페 ^_^
Snoopy0812's Avatar
Quoted: 90 Post(s)
Originally Posted by Spool2Go View Post
Start with...
thats an odd combo.. any particular reason why?
I've got some SS lines that I need to install so this interests me too.
Snoopy0812 is offline
post #6 of 19 Old 03-29-2011, 03:27 AM Thread Starter
clouter's Avatar
Start with...
isnt it rear right, rear left, front right, front left ? as to start farthest from the master cyl and work your way closer to it ?
clouter is offline
post #7 of 19 Old 03-29-2011, 06:51 AM
Sex Machine
Spool2Go's Avatar
u gotta go in a crisscross to bleed the brake system, stating from the rear right. (rear right is on the passenger side)
Spool2Go is offline
post #8 of 19 Old 03-29-2011, 07:02 AM
FUNCTION OVER FORM
Tufast's Avatar
This ^^^ +1...
Here is some good brake bleeding info I found a wihle back.
Brake System Bleeding
Steps for bleeding GenCoupe brakes or any production based vehicle with single master cylinder
retrieved from MBS & here's the link: Brake System Bleeding
Supplies needed:
- 2 people
- Supply of high quality brake fluid from an unopened container
- Bleed bottle (I used suction from flush machine)
- 10mm hex box end or line wrench for bleed screws on calipers (2 per caliper)
With the car on jack stands and a person sitting in the driver seat:
(There are enough threads on jacking & supporting a car with jack stands etc..)
- Place the wrench over the bleed screw on the caliper furthest from the driver
- Place the bleed hose attached to the bleed bottle over the bleed nipple with the wrench. If the caliper has two bleed screws, start at the inboard bleeder first (ours do)
- Open the bleeder
- With the bleed screw open, have the "driver" slowly depress the brake pedal to the floor. With the driver holding the pedal down, gently close the bleed screw.With the bleeder closed, the driver can release the brake pedal
- Repeat this process until the fluid coming from the caliper is clear and free of air bubbles
- For calipers with 2 bleeders, repeat this process for the outboard bleeder
- Monitor the fluid level in the reservoir and refill as necessary during the process
- When finished torque bleeders to factory recommended settings
Repeat these steps for each caliper, working towards the caliper closest to the driver. At times it is helpful to tap the caliper body with a soft mallet to release any small air bubbles trapped inside the caliper. At this point, the brake pedal should be checked for firmness and consistency. If the fluid is free of air bubbles and the pedal is still soft or spongy, there may be further issues that need to be addressed with the brake system. When finished, fill the fluid reservoir to the "full" line, but not over
Sponsored By:
Tufast is offline
post #9 of 19 Old 04-14-2011, 07:15 PM Thread Starter
clouter's Avatar
so all said and done, ive been driving on the new lines and fluid for two weeks now
i did rear passenger
rear driver
front passenger
front driver
i repeated the cycle two times to make sure no more air bubbles were there
works like a charm !
and tonight i just installed my hawk hp+ pads in the front..... DAMN this thing brakes !!!!
clouter is offline
post #10 of 19 Old 04-14-2011, 07:23 PM
My other ride has 4000hp
whatnot's Avatar
I thought it was up up down down left right left right B A start?
whatnot is offline
post #11 of 19 Old 04-14-2011, 10:39 PM
Badcompany235's Avatar
close, but it's B X R not B A Start.
Badcompany235 is offline
post #12 of 19 Old 04-15-2011, 03:46 AM Thread Starter
clouter's Avatar
Bahahahaha
Damn ! You guys are right ! Im gonna have to learn2mechanic again
clouter is offline
post #13 of 19 Old 04-14-2014, 06:26 PM
I suppose the engine should be running, otherwise the brake would eventually lock up?
2011 3.8 R-Spec White
Tangent is offline
post #14 of 19 Old 06-08-2016, 01:00 PM
so does the car have to be running to bleed the brakes? like the other guy asked? I mean I would assume no since once the bleeder valve/screw is open the brake pedal will not lock up right? can someone help me? im planning on bleeding my brakes this weekend thanks
Martin is offline
post #15 of 19 Old 06-13-2016, 11:32 AM
socrbob's Avatar
No, there is no reason to have the engine running when you bleed your brakes.
2010 R-Spec|Tsukuba Red|Some mods
socrbob is offline
post #16 of 19 Old 06-13-2016, 12:10 PM
So the pedal won't lock up? It'll be able to be pressed down while the valve is open?
Martin is offline
post #17 of 19 Old 06-13-2016, 03:59 PM
Golfinglenn's Avatar
Quoted: 77 Post(s)
Do you have the dreaded squeel at low speeds? Had to take mine off and save them for track days, just too damn embarrassing every time I stopped and they squeeled like a pig.
2016 3.8 Ultimate M/T
CNT catback racing exhaust
Test pipes
Carbon fiber dash kit
ATQ shifter, bushings, collars
Megan transmission mount
Whiteline front swaybar
R2C w/o stupid shield
Hawk HP+ pads and RBF600 fluid
Braided lines (brakes and clutch)
Future mods:
PNP Intake manifiold
Bore and polish TB
Tuned ECU (leaning toward BTR)
Golfinglenn is offline
post #18 of 19 Old 06-14-2016, 08:20 AM
nomoreammo's Avatar
Quoted: 123 Post(s)
Low speed as in going from 15mph to full stop?
I have Stoptech pads and my front driver side squeals like a mofo when slow stopping.
2012 Tsukuba Red 2.0T A/T
Beyond Redline Stage 1 tune
CP-E Intake
CP-E Catback Exhaust
AGP FMIC w/ SSQV BOV.
Turbo XS Downpipe
Forge BOV
nomoreammo is offline
post #19 of 19 Old 06-14-2016, 08:28 AM
I sometimes use the engine running when bleeding the brakes. But only the rears as the have the flow are restricted compared to the front. The newest Gen Coupes this is electrically controlled so I would assume it is fully open when the key is off?
DIY - Bleeding Brakes Tufast Suspension and Wheels 6 07-24-2016 08:50 PM
Brakes by itself? BlackonBlack General Discussion 16 04-27-2010 10:55 AM
Bleeding the Bembros Red Raspberry Wheels, Tires and Brakes 2008-2012 5 09-23-2009 11:39 AM
brakes k H young Wheels, Tires and Brakes 2008-2012 15 11-23-2008 02:59 PM
