![]() Join Date: Jul 2010
Gathered this information form several posts, and thought it would help some people looking to do the swap....
For the fronts, you'll need the rotors, calipers, and crush washers for the brake line. You can re-use the existing brake line and fittings. For the rear, you'll need the rotors, calipers, crush washers, and splash/dust guard (if you want to replace it). The rear splash guard covers the edge of the rotor whereas the front guard only covers the side area of it. You can simply cut the rear guard off with some metal snips or you can remove the hub and replace it outright with the larger one from the track model. Dust Sheild/Splash Guard/Backing Plate Part Numbers: L 58250 2M700 R 58270 2M700 FAQ: 2.0 and 3.8 share all the same brake componets. Everything is a direct fit. (Base brakes vs Brembo brakes) All the internals (ABS, master cylinder, reservoir) are all the same, as well as mounting location and brake lines. The bleeder nut on the Brembo calipers is 11mm. People who have done a Brembo Swap: qwaszx 2.0TGT vox Kleindl Last edited by qwaszx; 10-31-2011 at 07:29 AM. |
#3 | ||
tadam!
thanks
was thinking about doing this if i find a good deal... but waiting for the equus brake outcome
Check out the ONLY canadian vendor: UNIQ PERFORMANCE 2010 Genesis coupe 3.8 M&S Type D grill - E&G front lip - AEM CAI - Ark True Dual exhaust - E&G custom wrapped diffuser- Gram Lights 57 Xtreme 19x9.5 +25 _ 19x10.5 +25- HSD coilovers - custom tails -Hella Supertones horn - Blox knob - tablet gps/media center - added Brembos - M&S side skirts - SF-X CF hood - custom headlight - VIS cf fog surrounds |
#5 | ||
mine are in the mail, will be installing shortly
#6 | |||
Jedi Master
i have a question: where did you get the brembos and for how much? thanks
I am not a list of mods but what i know and share: http://www.gencoupe.com/2-0t/94778-fuel-system-what-you-need-know.html http://www.gencoupe.com/2-0t/86146-wastegate-101-a.html http://www.gencoupe.com/2-0t/91199-compressor-maps-how-read-them.html Fav. JT Quote Quote:
#8 | ||
Not sure exactly, but one thing to keep in mind is that the brembo rear rotor is thicker than the base rotor due to its venting veins (the stock rotor is solid non-vented.) There may not be enough clearance with the brembo rotor and the stock dustshield.
GR WRX | S2000 CR |
#9 | |||
Nerd
Seems they are $160-300 just for those shields alone. :O
#11 | ||
Uses Search Button
Yes, you can cut the lip off and still have a functional cover. You will also need to make a small cut so the covers will clear the caliper brackets. There is also still plenty of room between the Brembo rotors and base model dust shields.
#12 | ||
Nerd
Thanks for the heads up. Hope to make it through the weekend with all my fingers attached.
#13 | ||
how thin is the dust shield? Can you cut it with tin snips, or do you need a dremel?
#14 | ||
Uses Search Button
#15 | |||
Nerd
Tons of metal shavings all over from using the dremel... did a onceover with a wire brush to clear everything out. ![]() Also need to trim the bottom side of the shield for the mounting bracket. ![]() Annnnd, the finished product. I went back and aligned the dust shield after taking this picture since I had pulled too much on certain sections. It's easier to gauge how much clearance you need when the rotor and caliper are mounted. ![]() Gonna get some brush on black caliper paint from the store and go over the exposed metal from the bending/dremel and clean it up. Test drive went smooth and perfect, no issues at all.
#17 | ||
I would have left out the dust shields in the back altogether. If you intend for this to be a performance upgrade for the track there's no reason to keep the dust shield on. It just serves to trap heat.
GR WRX | S2000 CR |
#18 | |||
Nerd
I checked around at all the discount oem part vendors, including NCZ here on the boards and the lowest price I could find was $310 for both plates. The way I see it, if you plan to go back to the base brakes to sell your car, then remove the shield and replace with the R-Spec/Track shields. If you still want a functional dust shield without having to buy a second set, modify the OEM one in whatever way you want. (Cut the rim or bend the rim.) I daily drive my car and I'm of the thought that the factory put the dust shield here for a reason. My rear shield no longer covers the vented portion of the rotors, so I'm not too concerned with rear brake heat whatsoever, but I'll find out once I get more seat time at the track and toss in the Quaife LSD.
#20 | |||
Type any OEM parts on eBay, gather your list of sellers on eBay from Korea selling ANY OEM parts, PM all of them about the paking plates instead with the parts number... I guarantee it'll be cheaper shipped than anywhere else. Plus, EMS is quick as hell, I get my stuff in a couple of days.
Mirabeau Blue 2.0T Manual, I liiiike my Brembos |
| Brembo Brake Retrofit | djhaose | Wheels, Tires and Brakes 2008-2012 | 14 | 04-22-2011 10:06 AM |
| 2010 NAV retrofit for stock radio? | ross6200 | Interior 2008-2012 | 13 | 04-08-2011 09:26 AM |
| Stanced & Brembo Swap?!?! | Kleindl | Media | 11 | 10-29-2010 05:24 PM |
| FS: Brembo brake kits.. Yes, I said Brembo. | shoota | Wheels & Tires | 28 | 07-23-2010 10:03 AM |
| Retrofit Nav in 2.0T Track? | davedave1234 | Interior 2008-2012 | 10 | 02-26-2010 03:59 PM |
