What size, width, and offset? (Looking for offsets in the 30s-40s at least)
Trying to determine whether a 18x9 ET38 will fit up front - my calculations indicate that it'll be tight with the strut, but looking for some real world testing. |
#4 | ||
Im actually interested too in this question. i want to buy rpf1s but the offsets they offer are either +15 or +38 in rear and +15 is a little too much poke in my opinion.
Say no to Vega... Say no to wing emblems... |
#5 | ||
Won't fit. Even my 18x8.5 +38 winter wheels don't fit in the front since it rubs the strut. I needed 5mm spacers up front.
2010 Hyundai Genesis Coupe 2.0t GT Tsukuba Red |
#6 | ||
Don't fake the funk
I knew Slider would be in here. And I agree, why would you want them to be tucked in? All the cool kids get low offsets.
2010 Genesis Coupe (Sold) 2013 Subaru STI Sedan (Current) |
#7 | |||
![]() Join Date: Jul 2010
Outer Position: EXTEND an extra 8mm will be close |
#9 | ||
My factory wheel is a 19 X 8 +35mm. When I measured my car, I had 6 3/4" from the mounting pad to the strut and 3 1/2 inches to the inside of my fender. Assuming about 3/8" from the tire bead to the actual edges of the rim, I calculated out a 9.5" wide wheel with a 50mm offset. I haven't had my car on an alignment rack so I'm not sure what the camber is, I can only assume since it's a track model, it's got the bolts installed (they weren't in the glove box).
#10 | |||||
Breast Examiner
![]() Quote:
You will need a camber of +4 to make that fit. Quote:
18x9 E38 will move the wheel in 18.4mm. >>> NFG![]() .
![]() Ship High In Transit
#11 | |||
Sent from my Nexus One |
| Front and rear not same offset ? | Binz | Wheels, Tires and Brakes 2008-2012 | 32 | 11-10-2011 03:05 PM |
| Yes, another wheel offset question... | JayinMI | Wheels, Tires and Brakes 2008-2012 | 2 | 12-09-2010 06:21 PM |
| wheel offset question | hfd7c | Wheels, Tires and Brakes 2008-2012 | 2 | 04-06-2010 10:25 AM |
| Wheel offset help | Kamkaze | Wheels, Tires and Brakes 2008-2012 | 8 | 12-16-2009 08:12 PM |
| Biggest wheel offset possible on this car? | Prosista | Wheels, Tires and Brakes 2008-2012 | 66 | 08-26-2009 08:27 PM |
