#1 | |||
Flip! What the zip?!
I did a quick and dirty search, and didn't see this topic. Anywhoo, I'm currently deployed with a few months left. One of the first things I plan on buying when I get back are spacers, among other things (BC coilovers, Ark exhaust maybe). I wanna see your spacers! Uhh...no homo?
![]() Post 'em up. Brand & size(s). If you're riding low, what's your drop and camber? And IF for some reason you've aftermarket wheels, post size and offset! Lets do this! Good info here people! Quote:
try to shed some light on it for the people who aren't familiar with spacers. There are two types of "spacers" that people need to pay attention to, everything else does not matter. Most spacers are purchase for our cars to make OEM 18's & 19's "flush" with the fender. Hub Centric Spacers Example: Ichiba V2 As you can tell from the image above, these spacers are actually two-pieces. The spacer itself with the built in extended studs are not bored to 67.1. Instead, the two centric rings you see on the left are 67.1 and are placed in the middle of the actual spacer. As far as vibration/balancing issues, this is a big "uh oh" for me. If you're already increasing the number of parts from 1 to 2 (wheel to spacer + wheel), you should try to minimize the number of parts sitting in between your wheel. This may not bother others but it's so easily avoidable, I don't see why you wouldn't. Spacer + centric ring + wheel just does not sound very efficient to me. Hub & Wheel Centric Spacers Example: Motorsports Tech, H&R, Eibach, SYUN Project Unlike the Ichiba V2's, you can see in the picture that the "centric ring" is built into the spacer. This means one less separate piece in between your wheels. Just make sure that the spacers that have built in "centric rings" are bored to 67.1 (stock wheel C/B size). Motorsport Tech spacers are built in house (Made in the USA) so they are a great option. They also offer custom "adapters" which we'll talk about below... but your spacers can be customized down to the millimeter if you order from them. That being said, 20mm (front) and 25mm (rear) is flush on our cars while maintaining factory alignment specs. This is great if you are OCD about your toe and camber settings like I am. Get yourself a lifetime Firestone Alignment plan for around $175 and you can treat yourself to factory alignment specs every single day! Hub & Wheel Centric Adapters* Example: Motorsports Tech If you are purchasing a set of wheels that are NOT bored to 67.1, but would like to mount them on your car anyways, you will first have to make sure (for the most part) that the offsets are somewhat high (depending on the wheel width). This is because adapters, can only be built from Motorsport Tech from sizes 15mm and up. These include built in extended studs as shown above as well as the built in "centric rings," also shown above. Take into consideration the added 15mm then go wheel hunting. It's also great if you want to run a very aggressive setup on our cars (10"+ up front or 11"+ in the rear). Anyways... hope this was helpful. Hijinx if you want to update the original post and replace the old quote of me that'd be great. I think this is easier to digest. I remember when I bought my first set of spacers, I had no idea what to expect haha. -Harry Last edited by JewishThunder; 12-06-2012 at 08:34 PM. |
#2 | ||
GCMafia
where u deployed to? im in iraq go home by the end of the year
PERFORMANCE ARK - Tomei Ti - P2R - Grimmspeed - NST - TWM - TiC - AEM - BC RACING - QUAIFE - WHITELINE - CP-E - MEGAN RACING - MISHIMOTO - KHAR LOOKS Flossy - ARK - Sequence - Fly Ride - FIVE:AD S5:F - Enkei RPF1 19x9.5+25f-245/35 19x10.5+22r-275/35 18x9.5 +15 265/35 All Around NSFW! |
#4 | ||
GCMafia
aaa nice i been to three bases in kuwait recently just decided to drive down there lol
#6 | ||
I have 20mm spacers front and 25 rear I believe they're ichiba received them from jay at gctuner and dropped on megan coils
![]() My front wheels are turned on this one ![]() And sorry for crappy phone pics. And this last one is the rear
kw track model 6s Sponsor myself -SFR TUNE = OMG!! -k&n intake -Strk o2 housing catted thru custom 3" tbe with hks muffler -Cxracing fmic/hks bov -agp oil cc and breather -prodigy front lip -cpe gauge pod with boost, a/f, and volt gauges -yellow laminx on fogs with 3k hids -m&s type d grill -sarona exhaust cover -superlux tails -Megan coils |
#7 | ||
Sponsored by Mastercard
Once it's lowered, if you purchase aftermarket rims with the right offset, etc you won't even need spacers. That's the route I'm taking next summer. In the meantime, stay safe in Kuwait!
2002 Honda s2000 - Championship White paint job - Extreme Stop drilled & slotted rotors - Hawk high performance brake pads - Megan track series coilovers - Megan strut bar + x frame |
#9 | ||
GCMafia
check out elementrider87's ride he has 17mm f and 20 r **** looks sick and its pretty much slammed on BC coils i believe
#10 | ||
Screw, Nut, & Bolt
I've got 20mm's all the way around. Lowered on Pro-Kit Springs
For Sale: BTRcc Tuned ECU for 2010-2012 3.8 Auto Genesis Coupe http://www.gencoupe.com/private-classifieds-engine/126348-fs-btrcc-tuned-ecu-3-8-auto.html
#12 | ||
Screw, Nut, & Bolt
thanks! one more for ya...
#14 | ||
The one the only
20mm all around
[IMG] [/IMG][IMG] [/IMG]
GenSport Carolina's Founding Member http://thenewgensport.wix.com/gensport#!home/mainPage JERSEY CITY MODS way to many to list for here 2010 NORD 2.0T TRACK Notable cars: 1985 Toyota Corrola GTS Silver RWD Drift |
#15 | ||
Site Sponsor
![]() Join Date: Nov 2010
![]() Eibach Sportlines 20mm F & 25mm R (along with the pictures that Hijinx) posted. ![]() How I sit right now. 19x9.5 +22 19x10.5 +22 -3 camber in the rear, 0 camber in the front. Will add 5-10mm spacer to the rear this month with no change in camber so I will use this thread to show yall the difference. Blumagic is running +12 offset which is what I will be at also, just not as low. ![]() Front shot from tonight.
www.InvisionAutomotion.com Find all your aftermarket products for your Hyundai Genesis Coupe! Brakes, Cosmetics, Performance, ECU Management, Suspension, Wheels, Lighting, and Car Care are all available through our online store! |
#18 | ||
Site Sponsor
Yeah I'll be getting extended studs + wheel/hub centric so I don't need the hub-centric rings for the Varrstoens. Would be one less thing to have to remove when I'm unmounting the wheels.
Question, did you roll the fenders for the fronts? Same story as rears I assume if you did? Plastic lining pushed back? I removed almost all of my rear plastic liner because honestly we don't need it, I'm wondering if I could do the same for the fronts.
#19 | ||
U wot M8
yeah... used some soft wood and rolled em. liners are still in though... didn't do anything but use those metal tabs to push them back as far as possible.
let me know how the stud install goes. i'm curious. |
#20 | |||
Hands down best spacer/adapters you can buy with your money. |
| Will these spacers fit? | Moley | Wheels, Tires and Brakes 2008-2012 | 54 | 02-11-2012 07:58 PM |
| Miscellaneous facts that dont deserve their own thread Thread | Havoc Inc | Off-Topic | 0 | 02-05-2011 07:53 PM |
| Spacers | LEETHL | Wheels, Tires and Brakes 2008-2012 | 14 | 04-27-2010 08:52 PM |
| Friday work thread, the only work thread of the week... | Lstorm9 | Off-Topic | 22 | 08-28-2009 10:45 AM |
