Enkei 20 inch wheels and sportlines - Genesis Forum: GenCoupe Hyundai Genesis Forums
Old 02-15-2012, 08:57 PM   #1
Default Enkei 20 inch wheels and sportlines
I have eibach sportline springs and I want to get enkei 20 inch wheels. The sizes are 20x8.5 in the front and 20x9.5 in the back. The only thing I don't understand is the offsets. Everyone on this forum recommends low offsets, but tire rack reccomends these wheels in a +40 offset all around. Also I would be running a 245 35 tire in the front and a 255 35 in the rear. I just want to make sure these will fit before I buy them. I've searched an cant find anyone running that size and offset.
hugo51 is offline   Reply With Quote
Old 02-15-2012, 09:06 PM   #2
Gen CP 21's Avatar
Wow those offsets are high.. Yes it will fit with plenty of room to spare.. You might need a spacer
Gen CP 21 is offline   Reply With Quote
Old 02-15-2012, 09:11 PM   #3
I knew they were really high. Would tire rack recommend a wheel that wouldn't clear the brakes. I don't understand the way offsets work.
Old 02-15-2012, 09:15 PM   #4
Gen CP 21's Avatar
Lower offsets mean wheel moves further away from your car
Old 02-15-2012, 09:29 PM   #5
So the offsets are terrible. But.. It's what I like and I don't track the car so performance loss isn't a big deal. What size front and rear spacer would you reccomend to make them fit good with the sportlines. I don't want to have to stretch tires too much or rediculous camber
Old 02-15-2012, 09:50 PM   #6
yimnvs's Avatar
Just get some wheels with lower offset(E20 -15). High offset wheels that are lowered look stupid. Spacers are for people who accidentally buy high offset wheels and for people with OEM wheels.
Luxon Grill
Superlux Tails
DD 6K HID
Stance SC-5
Eibach Pro-Kit
Magnaflow CBE
BTRcc Canned Tune
yimnvs is online now   Reply With Quote
Old 02-16-2012, 04:54 AM   #7
FUNDAI's Avatar
Tire rack suggests those offsets because it's comparing them to the OEM wheels, but if you want it to be flush and look good, not all sunken in like the OEM wheels, you're going to want an offset of about +15 on those wheels, front and rear. This number changes though depending on the widths of your wheels.
Originally Posted by qwaszx
Dude... I just drove by Dunkin Donuts because I was too busy thinking about what kind of donut I wanted!
FUNDAI is offline   Reply With Quote
Old 02-16-2012, 05:30 AM   #8
Ex-DSMer
LandoAWD's Avatar
Please don't band-aid a wheel purchase with spacers. yimnvs is dead-nuts on.
2012 Genesis 2.0T Nord Gray A/T
Ark Grip v.2, K&N Intake, TurboXS DP
Some visual mods and Ricer horns
Avantgarde M368s, H&R Springs
LandoAWD is offline   Reply With Quote
Old 02-16-2012, 06:19 AM   #9
synnyster's Avatar
This is what happens when you buy wheels with offset too high. This is a bit exaggerated because 350z can handle a really wide and low offset wheel. If you plan on lowering your car the high offset will even be more pronounced because your wheels will naturally camber in when lowered.
2010 Genesis Coupe 380GT | Marcello SFT-012 | BC Racing BR Coilovers | Injen Cold Air Intake | Magnaflow Catback
synnyster is offline   Reply With Quote
Old 02-16-2012, 07:16 AM   #10
The Reputation Killer
evo9ray's Avatar
To the OP.
The offset you are recommended will most likely NOT clear your brakes, especially if you have brembos.
The stock offset on an r-spec (and most likely stock) Is a +35. So going to anything HIGHER than that is a big NO NO.
You have to do your homework on wheels. Getting a +20 offset doesnt necesarily mean it's going to stick out more than say a +30. This is because you also have to take into account wheel width. (If wheel A is 9.5 +20 and wheel B is 10.5 +30 the way they stick out will more than likely be about the same)
Also, I would not recommend running 245's in the front. You might have some rubbing issues, especially if you're lowered. Stick with 235's in the front, and run 255+ in the rear.
Good luck!
evo9ray is offline   Reply With Quote
Old 02-16-2012, 07:35 AM   #11
MBJ
MBJ's Avatar
This worked wonders for my understanding. Custom rims, wheel tire packages for your ride - RIMSnTIRES.com
MBJ is offline   Reply With Quote
Old 02-16-2012, 04:42 PM   #12
grapefruitdaddy's Avatar
LOL! That car looks like a turtle hiding in it's shell!
grapefruitdaddy is offline   Reply With Quote
Old 02-16-2012, 04:45 PM   #13
evo9ray's Avatar
That pic HAS to be photoshopped..
There's a chick out here in my area that drives a 350z with super high offset wheels (look like they should be on a scion tc) and it looks HORRIBLE, but in no way does it look like the picture above.
"Enemies stay Enemies, but friends, they change."
Old 02-16-2012, 05:59 PM   #14
Originally Posted by evo9ray View Post
To the OP.
Good luck!
you can run a 245 on the front. It may or may not rub depending on wall height, rim width, offset and how low you are. There are guys on here with 255 and even 265 on the front.
quickstang1 is offline   Reply With Quote
20 inch wheels? Red23 Wheels, Tires and Brakes 2008-2012 24 12-30-2012 07:01 PM
What kind of wheels are you guys running on eibach sportlines? firefighter82 Wheels, Tires and Brakes 2008-2012 0 11-13-2011 03:33 PM
New wheels from Enkei! Enkei PF01 Cal@GPP Wheels, Tires and Brakes 2008-2012 2 10-20-2009 03:09 PM
[GenRacer] Enkei Wheels Now Available! GenRacer Andrew Wheels & Tires 11 10-19-2009 06:53 AM
KPR -- Enkei - RPF-1 | RP-03 | GTC-01 wheels! KPR Sales Wheels & Tires 5 06-19-2009 10:16 PM
