More Vibration Issues - Page 2 - Genesis Forum: GenCoupe Hyundai Genesis Forums
Old 04-11-2012, 10:22 AM   #21
Herm's Avatar
Like jay said, balancing wwont change aan out of round tire. That happens sometimes and the fix is replacing the tires. Should be able to swap out with a warranty where ever you bought them.
2011 3.8 R-spec M/T | AEM CAI | Custom Single Exit CBE | TWM STS | PowerAXEL | Enkei Raijins | Eibach Pro Kit | P2R
Herm is offline   Reply With Quote
Old 04-12-2012, 08:36 PM   #22
Keval N's Avatar
So I was at Cambridge Hyundai today and turns out they have a hunter road force balancer. They had a good long look, and it turns out that my left rear rim is bent. 57 lbs of road force whereas the maximum is 22 lbs I believe. The vibration from the rear is probably throwing out my fronts at highway speed. They made some adjustments to the fronts and the vibration is now less noticeable. The tires all passed the road force tests. It's a good thing I didn't buy new tires . . . time to go order a 19x9.5 TSW Croft.
2010 Genesis Coupe 3.8 A/T Navi
Keval N is online now   Reply With Quote
Old 04-27-2012, 05:16 PM   #23
Keval N's Avatar
So I had my new rim installed today. $460 later (new rim plus hunter road force balance) and my vibration issue is now finally gone!
Lesson learned: Hunter road force balancing is expensive but worth it.
Vibration at 65+MPH Cen-Tex Coupe Suspension 2008-2012 83 05-21-2013 02:14 AM
Vibration at 70mph WilliamKart General Discussion 15 04-06-2012 09:48 PM
Rearview Mirror Vibration geokots Interior 2008-2012 31 02-03-2012 01:28 PM
Engine/exhaust vibration ControlFreak 2.0T Discussion 2008-2012 10 04-05-2011 07:04 AM
Vibration Stock Suspension Jason@ImportShark Suspension 2008-2012 10 02-26-2011 07:14 PM
