steelies wheels and snow tires - Hyundai Genesis Forum
post #1 of 10 Old 10-29-2015, 09:43 AM Thread Starter
HiLandR's Avatar
Guys, I did a search and didn't net much. I am looking to see what would be an inexpensive way to get my 2015 spec outfitted with winter shoes. I would really like a smaller steelies wheel maybe a 15 or 16 inch with a taller snow tire, like what we used to run in the old days. Has anyone done this, if so, where and what combo should I look for. Specifically keeping in mind center bore (67.1) and a bolt pattern of (5x 114.3) and a thread of (M12 x 1.5) and available wheel gap.
Anybody?
2015 Genesis Coupe R-Spec - Empire State Gray
HiLandR is offline
post #2 of 10 Old 10-30-2015, 12:33 PM
Quoted: 12 Post(s)
Hopefully the last winter tire thread
has some good info. Not sure, but 16's might not fit. Most seem to stick with 17's
choboy9242 is offline
post #3 of 10 Old 10-30-2015, 01:47 PM
karbonkoncepts's Avatar
Quoted: 405 Post(s)
I don't think you can fit much smaller than an 17" wheel due to the Brembo brakes. You MAY be able to fit a 16 but I honestly have zero clue if anyone has done it.
karbonkoncepts is offline
post #4 of 10 Old 11-04-2015, 05:23 PM
andbudzi's Avatar
Quoted: 283 Post(s)
Get your self used 17" rims from mustang. 16 will have way too much sidewall.
andbudzi is offline
post #5 of 10 Old 11-09-2015, 06:25 AM Thread Starter
HiLandR's Avatar
So do they have the same bolt pattern and center bore?
HiLandR is offline
post #6 of 10 Old 11-09-2015, 07:40 AM
Quoted: 14 Post(s)
16's will not fit.
I had 16's with Xi3's from my old ms3, bolt pattern is the same 5x114.3 but it does not even get close to clearing the Brembo break callipers.
Even 17's might be tight depending on the shape of the steelies so make sure you are positive they will fit before buying them.
I'm having to put my Rays 18s for winter. I had just restored them for the ms3 but have no choice as the car came with 19s. People will look at me like im an idiot for having Rays on for winter.
“There are only two ways to live your life. One is as though nothing is a miracle. The other is as though everything is a miracle.”
ecbehrens is offline
post #7 of 10 Old 11-09-2015, 01:01 PM
Same bolt pattern but the mustang wheels have a larger center bore so you'll want hubcentric rings if you go that route.
Soldier-B is offline
post #8 of 10 Old 11-09-2015, 01:24 PM
 ლ(ಠ益ಠლ)
rw78o's Avatar
i had 17" steelies on my car for 1 winter and the just BARELY cleared the NON brembo calipers
Originally Posted by RKBK2.0 View Post
Yes, keep it classy ...... Just speed if you need to sh*t or piss!
2010 Genesis Coupe 2.0T-LOOK FAST
2003 Suzuki GSX-R 600-GO FAST
rw78o is offline
post #9 of 10 Old 11-10-2015, 12:21 PM
'13 2.0T R-Spec Noobus
BRBGC13's Avatar
I have Evo 9 17" Enkeis and they clear with 20/25mm spacers. Its a VERY VERY tight fit on the ball joint in the front but they have room as long as you watch your wheel weight placement.
BRBGC13 is offline
post #10 of 10 Old 11-18-2015, 07:18 AM Thread Starter
HiLandR's Avatar
By happenstance I stumbled on to these. I am setup! I got a solid deal as well. The guy traded his Gen Coupe for a Camaro and had these left after the deal.
HiLandR is offline
Wanted: Snow tires and wheels bballer123 Wheels & Tires 0 01-02-2014 06:11 AM
17" snow tires and wheels on R-Spec?? Icebladexi Wheels, Tires and Brakes 2008-2012 3 10-11-2011 09:33 AM
Snow tires on all 4 wheels? waz Wheels, Tires and Brakes 2008-2012 12 04-23-2011 01:12 AM
MI Snow tires and wheels $400 (x-post) Hudnut Mid-West / Great Lakes 3 02-10-2011 07:25 AM
