gencoupe.com gencoupe.com
Go Back   GenCoupe.com Forums - Your Hyundai Genesis Coupe Community > Genesis Coupe Tech > Wheels, Tires and Brakes
Old 11-11-2009, 03:19 PM   #1
Default Well, I'm gonna try 19x10 front
I just ordered a set of ame circlar spec-r in
19x10 22 offset front
19x10 15 offset rear..
I know there will be fitment issues in front but I will make them work..
I just pm'ed slydfx to ask what type of clearance he has up front since he is pretty close to my specs.. He's running 9.5 fronts with a 17 offset so I will be a 1/2 inch wider but 7 millimeters further in. I'm kinda tempted to get the complete set in 15 offset but that would be too tough to make fit. My concern is what it will make contact with on the inner side, not really concerned about the fender, because I can do some "massaging" to that. Wish me luck and I will be sure to post some pics. I'm not sure if anyone has tried to put a 19x10 with a 22 offset in front... If so, please post..
OR, if anyone has a 19x10 22 offset in rear, can you try putting one of them up front to see if there are any issues.. That would be great... Again, not concerned about the outer wheel, just the inner.. I plan on running a pretty aggressive stretch on all four..
raffi is offline   Reply With Quote
Old 11-11-2009, 03:22 PM   #2
Medsport's Avatar
Why would you want such huge wheels in the front?
2010 Silverstone 2.0T track - Lathewerks knob, PowerAxel reflash
Medsport is offline   Reply With Quote
Old 11-11-2009, 04:40 PM   #3
stock car modified driver
project jayden's Avatar
^ +1
project jayden is offline   Reply With Quote
Old 11-11-2009, 04:43 PM   #4
ARKperformance's Avatar
Hella flush!!!
ARK GENESIS COUPE 3.8 / ARK TRUE DUAL Exhaust / ARK R-SPEC HEADERS / ARK RSPEC DOWNPIPE / ARK TEST PIPE / ARK Carbon FX Front Lip / ARK Carbon FX Side Skirts / ARK Carbon FX rear Diffuser / ARK CFX Hood / ARK CFX FRONT GRILL / ARK DTP COILOVER SYSTEM /
Current Projects : 3.8GT ETD , 2.0T Single/dual exhausts, and many more.
Sponsors : XXR Wheels / Blox / Aero designs / Works Bell / Import Shark / Aspec / JSdesigns
ARK PERFORMANCE INC
5490 Brooks Street
Montclair CA 91763
ARKperformance is offline   Reply With Quote
Old 11-11-2009, 04:47 PM   #5
Team Sun*Works
Kamkaze's Avatar
As long as he runs a 30 series in the front and a 35 in the rear he should be fine or run 275 in the rear and 255 in the front both in 30 or 35 series. As long as the circum. of the rear tire is slightly bigger it will be ok. The difference between the front and rear circum. of the stock tires is 2" for the 19's
Sponsored by Custom Performance Engineering, GenRacer, 5vPhoto, PowerAXEL, GrimmSpeed
cp-e αIntake, cp-e catback, cp-e catless downpipe, PowerAXEL Flash, PowerAXEL strutbar and pedals, Stance GR+ coilovers, LoveFab Turbo Manifold, ATP BOV adapter pipe and block off plate with HKS bov, HKS radiator cap, HKS oil cap, GReddy Infometer Touch, SuperDrift wheel spacers, M&S Type D Grille and M&S fog surrounds,Chrome Wing Badge
Kamkaze is offline   Reply With Quote
Old 11-11-2009, 05:02 PM   #6
O, not zero. ;)
N2OInferno's Avatar
can't wait
Mitch Hedberg
N2OInferno is offline   Reply With Quote
Old 11-11-2009, 06:19 PM   #7
Lord Stig
El_STiG's Avatar
Originally Posted by ARKperformance View Post
Hella flush!!!
That's waht I was thinkin.
"Some say he disappears months at a time, and when he comes back, a new record for driving to and from a taco truck has been set. all we know is, he's called el_stig" -ESPTuning
Rally Innovations, Eibach Springs, GReddy, PowerAxel
2008 Genesis Coupe 2.0T
-PowerAxel tune
-Greddy FMIC
-Megan Racing Exhaust System
-Eibach Springs Front & Rear Sway-Bars
-****** Coilovers
In need of a LSD.
Used Megan Racing Coilovers up for sale. $650.
I <3 Rally Innovations.
El_STiG is offline   Reply With Quote
Old 11-11-2009, 06:33 PM   #8
the fixer upper
dennis_david's Avatar
That's what I call tight!!
dennis_david is offline   Reply With Quote
Old 11-11-2009, 06:52 PM   #9
Site Sponsor
Seoulfulracing's Avatar
it will not fit.
we tried 18x10 +25 and we could not even tuck half of the wheel there unless you go with 25+ mm spacers.
I would say if you go with 19x10 you need at least 0 offset or -5 offset or something..and it will make it stupid hella flush!
Speaking of hellaflush
HELLAFLUSH? X OFFSET KINGS. seoulful
#1 KDM originator and source
INJEN|Sequence-X|Luxon|7ism|M&S|Neotech|System|Roadruns|More
TEL: 213.596.8959 AIM:sfrkdmguy
www.seoulfulracing.com
Seoulfulracing is online now   Reply With Quote
Old 11-11-2009, 06:53 PM   #10
if its not tight... its not right
rims can be square just as long as you change the width or aspect or both...
i just got 17's for winters that are 9 width and just changed the with and aspect
Fr3bB is offline   Reply With Quote
Old 11-11-2009, 10:18 PM   #11
it will not fit.<br>
we tried 18x10 +25 and we could not even tuck half of the wheel there unless you go with 25+ mm spacers.<br>
I would say if you go with 19x10 you need at least 0 offset or -5 offset or something..and it will make it stupid hella flush!<br>
<br>
Speaking of hellaflush <img src="http://www.GenCoupe.com/images/smilies/smile.gif" border="0" alt="" title="" class="inlineimg"><br>
<a href="http://fatlace.com/hellaflush/theflushness/seoulful.html" target="_blank">HELLAFLUSH? X OFFSET KINGS. seoulful</a>
so from what you wrote, I would have to use a 25mm spacer, wouldn't that mean the wheel would stick out like crazy?
I originally posted a 22 offset front and 15 rear, but after emailing slydfx, I need to get the 15 fronts aswell because clearance on the inside part where it clears the suspension. So the new setup would be 19x10 15 offset all corners.. Which should clear the inner parts. I'm more worried about how much stretching I'm gonna have to do with the front fenders to clear. I do want the hellaflush look and love the square setup.. Slydfx has a 9.5 with 17 offset, so a 10 with 15 offset should be able to clear since it essentially is a quarter inch on both the inner and outer part of the wheel and 2mm more aggressive. My main fear is how much negative camber I would need to run..
Old 11-11-2009, 10:37 PM   #12
F19x9.5 +17 R19x10.5 +18
sLydFX's Avatar
Anywhere from -3 to -3.5...MAYBE...-4.
HELLAFLUSH FTW!
i'll be going to the hella flush carshow this weekend up here in norcal. check out they're website (just google hellaflush)...there's PLENTY of pictures!
Tsukuba Red Genesis Coupe 3.8 Track
Originally Posted by Mike Garrett from speedhunter.com
Out of the corner of my eye I thought this was another G35 rolling in, but as you can see it's actually a Hyundai Genesis Coupe. And at that one of the nicest privately-owned examples I've seen yet.
sLydFX is offline   Reply With Quote
Old 11-12-2009, 03:34 PM   #13
After some thought, I decided to purchase a set of ame tm02 in 19x9.5 and 19x10.5 in charcoal and stay safe rather than dealing with all of the brain damage..they should arrive by next wednesday
Old 11-12-2009, 04:37 PM   #14
www.KPRace.com
GenCoupe.com Vendor
KPR Sales's Avatar
Nice choice on wheels. The TM02's will definitely give your Gen the track look.
KP Race.com
"Working hard to bring the hotness to your Genesis"
____________________________________________
Victor Moore - Sales, Marketing, Drifting and then some
sales@kprace.com | T: 206.575.2161 | AIM: KPR Sales | KPRace.com
KPR Sales is offline   Reply With Quote
Old 11-12-2009, 05:02 PM   #15
Team Sun*Works
Kamkaze's Avatar
I almost got the same sizes of the circular spec R in the metallic blue.
Old 11-12-2009, 05:16 PM   #16
It's too bad they didn't have the circular spec-r in our size.. But I think the tm02s are just like the rpf1 but on steroids.. I really hate copying someone but it was waaaay to good of a deal to pass up..
Old 11-12-2009, 07:02 PM   #17
I was going to say for the fronts it will lose clearance on both sides with the specs you mentioned compared to his. Although it wouldn't be much I'm not sure how close he is on his setup. What offsets did you go with?
onelowr is offline   Reply With Quote
Old 11-12-2009, 07:09 PM   #18
sLydFX's Avatar
those wheels look hella sick! what offset will you be running? i cant wait to see them on your car!
Old 11-12-2009, 08:04 PM   #19
thanks brother. Also, I appreciate you talking me off of the ledge! I got them in a 22 offset and i also attached the link to the zilvia thread where I found them. It currently has the tpms sensors for a g35 and I'm curious if the Infiniti sensors will register with our car... We will see soon enough!!
MI FS (MI): AME TM-02 19X9.5/10.5 +22 245/275 tires - Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum
Old 11-12-2009, 08:07 PM   #20
Btw, I ended up getting them for 1900 shipped!! I couldn't pass them up.. But I was a cunt hair away from getting the ssr ms1s that someone posted for 2000 shipped but 17 offsets but it didn't have tires.. So basically, I spent 100 less than I was for the ssr and got tires aswell.
