Will not shift out of Park!!!!! - Hyundai Genesis Forum
 3Likes
  • 2 Post By Mazukou
  • 1 Post By GenCoupeBoricua
post #1 of 19 Old 01-06-2015 Thread Starter
I am new to Gencoupe so please bear with me. I have read every form I can find and no one else has had my problem. 2010 Bone stock 2.0t with AT ESC Off light stays on will not shift from park unless you over ride the switch and then it is in fail safe mode. replaced brake light switch that was bad. I seen the same thing in the 3.8 forum and it was a mechatronic in the tranny but I question my local service guy and he informed me that my tranny did not show that particular part in in so any help here would greatly be appreciated.
ssawyer1911 is offline
post #2 of 19 Old 01-06-2015
Mazukou's Avatar
Quoted: 251 Post(s)
step on the brake pedal before trying to shift out of park..
Conbreezy and Matt_ like this.
2013 Gran Premio 3.8 Track M/T
Stoptech SS Brake Lines, Agency Power Clutch Line, R2C SRI, Agency Power Catback, ARK DP/TP, PBM Coilovers, BTR Tune, EBC Redstuff, UR L/W Pulleys, Ported Throttle Body, Competition Clutch, Gram Lights
Mazukou is offline
post #3 of 19 Old 01-06-2015
KDM > All
Hyundave's Avatar
Quoted: 28 Post(s)
You blew a fuse. It happened in my 2008 elantra. I had extra current going into my tail light from some wiring and it kept blowing a fuse. Turns out that fuse controlled the brake light switch along with the ESC. Go in and replace that fuse.
In the mean time, use the shift release with a pen or a key that's next to your shift knob. Push down on the shift release and then shift out of park. Hope this helps!
2011 2.0T Premium A/T Current
- Exceladyne CBE
- 6000k Lows
- Wing Badges
- Switchback Turns/Fogs
- Superlux Tails
- Nexus 7 Tablet
2008 Gray Elantra SE Incus Kit Sold
Hyundave is offline
post #4 of 19 Old 01-07-2015 Thread Starter
I also get a U 0101 code that states lost connection to the ESC. Thanks for the replies but so far still stuck in failsafe when I shift over ride.
post #5 of 19 Old 01-07-2015
Korean Asswhoopin
Thumb5's Avatar
Quoted: 130 Post(s)
Get your brake switch replaced, it was recalled. The brake switch isn't sending signal to the shift lock release, also you won't have brake lights. Pump the brakes in the meantime
2017 VW Golf R "Daily"
Thumb5 is offline
post #6 of 19 Old 01-07-2015 Thread Starter
Thumb if you will read the whole post you will see that I have already replaced the switch twice is a matter of fact
post #7 of 19 Old 01-07-2015
Why so serious, Bro?
GenCoupeGeek's Avatar
Quoted: 1226 Post(s)
This may seem like a silly question... but have you checked the fuses?
BTRcc Custom Tuned
"The difference between stupidity and genius is that genius has its limits.
~Albert Einstein
GenCoupeGeek is offline
post #8 of 19 Old 01-07-2015
KDM > All
Hyundave's Avatar
Quoted: 28 Post(s)
Haha I suggested this earlier... I'm hoping he did
- Exceladyne CBE
- 6000k Lows
- Wing Badges
- Superlux Tails
- Nexus 7 Tablet
Hyundave is offline
post #9 of 19 Old 01-07-2015 Thread Starter
They have been checked and double checked. Thanks but still no solution.
post #10 of 19 Old 01-08-2015 Thread Starter
Update it is the TCM according to my local service shop but the service manager said that it was possible that if they order this part it may not fix it they stayed on the phone for a hour with tech service and they said that was the problem. Any input.
post #11 of 19 Unread 3 Days Ago
I have this same problem on my 14 genesis coupe 2.0t and can't find solution. Fuses are good. Havent replaced the Brake switch tho tryin gthat next. SSawyer what was the solution? Thanks sir
mautmastro is online now
post #12 of 19 Unread 3 Days Ago
Dropping Knowledge
GenCoupeBoricua's Avatar
Quoted: 22 Post(s)
Test the brake switch. It is really simple. A continuity/resistance test would show you if the switch is functional and bypassing the switch will tell you if it is truly the switch or not.
2011 Hyundai Genesis Coupe
Mods
A shitload
GenCoupeBoricua is online now
post #13 of 19 Unread 3 Days Ago
Quoted: 669 Post(s)
Or.... have someone stand behind the car, and check if the brake lights work
post #14 of 19 Unread 3 Days Ago
thanks guys. Yeah so I installed the new brake switch and still same issue. Yes the brakes go on when you press the pedal. Only way to shift car out of park is the emergency pin and then the car drives in third gear only. Car is auto. scratching my head. this **** is a nightmare. Any help from anyone that leads directly to me fixing this issue and I will send you $50 asap for the tech support advice. Once the car is back to normal with your solution. PLEASE HELP.......
Ive contacted Jay Kim at SFR and no help, his response was go find a local shop. anyway I am local to Fort Lauderdale area and can bring it in to a Hyundai specialist but just not the dealer. They tried to sell me a new pcm and tcm $1,100 each only to get to what the real problem is. LIKE WTF
post #15 of 19 Unread 3 Days Ago
Dropping Knowledge
Quoted: 22 Post(s)
Had another car do something similar. There is a solenoid that normally engages and disengages to shift the lever out of park. Has that solenoid been verified?
Red Raspberry likes this.
Mods
A shitload
post #16 of 19 Unread 3 Days Ago
What is it called or where is it located and I will search and check.... Thank you
post #17 of 19 Unread 2 Days Ago
Quoted: 669 Post(s)
if it works with bypass and you are able to drive fine, then I would assume that the shifting gate assembly is the issue.
https://www.ebay.com/itm/2010-GENESI...oAAOSwUn9Z7oEp
If it's just the solenoid... it should be part of the shift assembly.
https://www.hyundaioemparts.com/oem-...ItMGwtbDQtZ2Fz
I rather use fourgreen.com, but they seem to be out of the interlock solenoid or the shifter assembly.
post #18 of 19 Unread 23 Hours Ago
Dropping Knowledge
Quoted: 22 Post(s)
If you want to know where to solenoid might be. It is inside the shifter assembly.
https://www.hyundaipartsdeal.com/gen...840-2m000.html
Has the diagram as mentioned.
Mods
A shitload
post #19 of 19 Unread 59 Minutes Ago
Hey Brother thanks for the help. I haven't forgotten about you. I had to special order the solenoid, I removed the shifter assembly and its easy to get to. As soon as I get it and hopefully confirm that was the prob I will paypal you as promised and I will also confirm on here what my fix was for the next people who need it.
Thanks Boricua!
Hyundai Genesis Short Shift Boot --- TWM Performance Shift Boots --- CHECK IT OUT! TWM Performance Interior 63 05-20-2014 05:11 PM
MINI Hyde Park and Green Park Special Editions Announced AutoGuide.com AutoGuide.Com News 0 04-19-2012 10:50 AM
TWM A6 Leopard Shift Knob w/ Shift Boot Retainer Review cowcow Media 10 03-30-2012 05:43 AM
