Synapse Synchronic BOV issues - Page 2 - Hyundai Genesis Forum
 7Likes
post #21 of 58 Old 07-29-2015 Thread Starter
Donate to my Mod Fund
steena_k's Avatar
Quoted: 234 Post(s)
Originally Posted by TallyGEN View Post
If it's fluttering it's not opening enough to let all the pressure out in one 'whoosh'. It seems that you have it hooked up properly, I would try connecting it to the intake manifold and bypass the solenoid and see if that helps. The only other item I could think it might be would be the preload spring which you said you removed. If not, have you tried contacting synapse?
I'm unsure how to hook it up to the intake manifold (note: I have an injen CAI, would it be the port that is currently capped off?). But I can try that. I've also emailed synapse and am awaiting a reply.
Instagram: @steena_ _k
steena_k is offline
post #22 of 58 Old 07-29-2015 Thread Starter
steena_k's Avatar
Quoted: 234 Post(s)
here's a slightly crappy video of the sound I took on the way to work. you can hear it in headphones.
sorry for the bad quality and recording, there was some traffic lol
What is this flutter?!: https://youtu.be/4bgpg68eQ8w
steena_k is offline
post #23 of 58 Old 07-29-2015
TallyGEN's Avatar
Quoted: 38 Post(s)
it's hard to hear any flutter, but I'm also watching on a phone. is this happening when you let off the gas or when you're under boost? when you change the stock intake you lose the silencer. our cars have a flutter noise under boost between 2-3k that is normal
steena_k likes this.
2013 2.0T Tskuba Red
SFR Custom Tune - K&N SRI - Synapse BOV - GrimmSpeed PnP Intake Manifold w/ Phenolic Spacer - ISIS TBE
308whp/ 321wtq
TallyGEN is offline
post #24 of 58 Old 07-29-2015
TallyGEN's Avatar
Quoted: 38 Post(s)
You would cap off the solenoid with a vacuum cap / nipple. Instead of running the vacuum line from the BOV to solenoid, you'd run it to a T a the black / white check valve on your IM. I can take a picture of mine tomorrow.
308whp/ 321wtq
TallyGEN is offline
post #25 of 58 Old 07-29-2015
PeanutButter's Avatar
Quoted: 135 Post(s)
Ya I can hear the flutter and it does not sound like the synapse is opening quick enough and that's why your getting flutter. Mine sounded very different than yours does. https://www.youtube.com/watch?v=hvnLnKhuH9g
I don't know if different intakes would have anything to do with it or not. I wouldn't think so though.
PeanutButter is offline
post #26 of 58 Old 07-30-2015 Thread Starter
steena_k's Avatar
Quoted: 234 Post(s)
CEL came back on and code is P2261
steena_k is offline
post #27 of 58 Old 07-30-2015
Quoted: 135 Post(s)
Do you still have it routed to your solenoid? Usually that's what people got from capping the solenoid.
https://www.gencoupe.com/engine-drive...10-2012-a.html
Seems 2012BlackGen had the same problem as you, Quote her and ask how she resolved it. Your solenoid may be crapping out in that case you may need to route the bov to the intake manifold and do the T on the solenoid like they did tto fix the problem. Either that or you have the line pinched which is blocking the vacuum flow to the bov. Either way the ecu thinks the bov is stuck closed.
post #28 of 58 Old 07-30-2015 Thread Starter
steena_k's Avatar
Quoted: 234 Post(s)
have you had any luck? @2012 blackgen
I'll take it to my performance shop to see what's up.
steena_k is offline
post #29 of 58 Old 07-30-2015 Thread Starter
steena_k's Avatar
Quoted: 234 Post(s)
@2012 BlackGen
idk why it won't let me tag her.. someone help lol
steena_k is offline
post #30 of 58 Old 07-30-2015
Quoted: 135 Post(s)
Quote her in the thread I linked above. That will get her attention.
2010 2.0T Track Bathurst Black Sold
BTR stage 2 / Treadstone / Tanabe / Prosport / R2C / Synapse / CP-E
2013 Camaro LS Silver Ice Metalic Sold
Injen intake, MRT exhaust
2015 Veloster Turbo Blue Totaled
Stock
2013 2.0T Premium AT Catalina Copper Current
Stock for now...
Fund my mods here... https://tinyurl.com/y2rgaw2o
post #31 of 58 Old 07-30-2015
TallyGEN's Avatar
Quoted: 38 Post(s)
Here's the way to bypass solenoid..
the "T"
Solenoid
whole thing
308whp/ 321wtq
TallyGEN is offline
post #32 of 58 Old 07-30-2015 Thread Starter
steena_k's Avatar
Quoted: 234 Post(s)
the "T"
Solenoid
whole thing
for some reason I can't see the pictures
edit: I can see them on my phone.
is it the same for a 2011?
steena_k is offline
post #33 of 58 Old 07-30-2015
Quoted: 135 Post(s)
Your solenoid setup is going to be a little different though, you are going to want to t your solenoid like Dirtyloud did in the thread I linked above. Just use the thread I linked to help you set it up, there are pictures there too.
post #34 of 58 Old 07-30-2015
2012BlackGen2.0's Avatar
Quoted: 82 Post(s)
I just responded in the P2261 thread, basically like already mentioned just follow Dirtyloud's setup. Hope it works, I've had mine running without issue for over a year now. The only complaint I have is that it sometimes acts up in the winter - I'm guessing condensation possibly freezes in the lines, and it'll flutter but (fingers crossed ) I havent gotten any codes or CELs
(I'd post pics but I cant from my phone)
K&N Typhoon Series Short-ram intake
Synapse synchronic blowoff valve
Eibach Sportline lowering springs
OEM Strut tower bar
Superlux taillights
AEM axleback with quad tips
Diode Dynamics SMD Angel Eye Kit (blue led's)
Blacked-out headlight housings
Diode Dynamics acrylic cupholder accent
RMX carbon fiber grille
2012BlackGen2.0 is offline
post #35 of 58 Old 07-30-2015 Thread Starter
steena_k's Avatar
Quoted: 234 Post(s)
Thank you both so much! I'll give it a shot when I'm off of work! Holding my breath lol
2012BlackGen2.0 likes this.
steena_k is offline
post #36 of 58 Old 07-30-2015 Thread Starter
steena_k's Avatar
Quoted: 234 Post(s)
am I capping both nipples off the stock solenoid or just the top one that is supposed to connect to the BOV? Also, can't find 3/8th Inch hose any where
steena_k is offline
post #37 of 58 Old 07-30-2015
TallyGEN's Avatar
Quoted: 38 Post(s)
On my setup, you would just cap the port that connected to the BOV. On the other setup, you're gonna run the line b/w the two ports, and also T into the IC pipe port, I believe. The pics in the other thread show it nicely.
I've bought the correct size fuel line at just about any name auto store, shouldn't have too much of an issue. You can use fuel line if they don't have specific vacuum lines.
308whp/ 321wtq
TallyGEN is offline
post #38 of 58 Old 07-30-2015 Thread Starter
steena_k's Avatar
Quoted: 234 Post(s)
thank you! I was scared to get fuel line just in case it was missing some specification necessary to be used but now I feel better lol
TallyGEN likes this.
steena_k is offline
post #39 of 58 Old 07-31-2015
Quoted: 135 Post(s)
No do not cap either of them.....this is why dirty loud was getting the code. He he just T'd the two lines off the solenoid back together. look at how he did his solenoid, you need to do it like he did not avoid getting the code again....not like tallygen but like dirty did in the other threads. If you cap those I will bet you will get the code again sooner or later.
Reread dirty's first post and look at the pictures
post #40 of 58 Old 07-31-2015 Thread Starter
steena_k's Avatar
Quoted: 234 Post(s)
so... tried going directly to intake mani and still flutters. I give up.
steena_k is offline
Synapse Synchronic BOV+HKS adapter StylinGC 2.0T Discussion 2013 and up 10 08-29-2014 06:12 PM
HKS SSQV III BOV or Synapse Synchronic BOV uni 2.0T Discussion 2008-2012 38 07-24-2013 01:46 PM
Synapse Synchronic BOV!!! FBHYUNDAI Engine 43 04-16-2012 06:57 PM
synapse synchronic bov fittings ItsGenesisTime 2.0T Discussion 2008-2012 1 02-15-2012 06:55 PM
