Finally the REAL fuel injector FACTS! - Page 5 - Hyundai Genesis Forum
 4Likes
post #81 of 110 Old 02-13-2015
lightthemup's Avatar
Quoted: 74 Post(s)
sorry about the immature response.
the truth is the cold does affect, even with the heat back on the throttle body the afr still all over the place until the engine reaches operating temperature, before it would be all over the place until i shut the ignition of and back on.
OK now for the record, i replaced the DW550 (blue) injectors with new Bosch 550cc, i'm not making any reviews yet cause it's too soon but so far it's as perfect as it was stock even the fuel trims????...go figure
2011 base Auto. BK2 engine, Elite Evo 9 kit with TD06SL2R-20G 7+7 billet compressor wheel and anti surge cover, BTR stage 3 tune, 550cc injectors, fuel return line, AEM Methanol injection,CXR intercooler, full exhaust with ARK, LSD...ported heads and intake manifold...bla.bla.bla
lightthemup is offline
post #82 of 110 Old 03-11-2016
Midnight Mechanic
VAGenCoupe13's Avatar
Quoted: 14 Post(s)
What are the most affordable and yet best for the money injectors for the 2013 Bk2 2.0t when looking to go Stage 3 custom but not with methanol or nitro? And are an AEM fuel pump and an AEM clutch 100% necessary? Thanks in advance.
2013 Genesis Coupe 2.0T R-Spec
Gran Premio Grey
Modfied R2C CAI
Depo Test/DP (with CAT delete)
ISR Street TBE
ISC Coilovers
20" STR 607 Titanium
DD 8K HID's
DD Switchbacks
Seibon CF Hood
M&S Carat Hyper G front bumper
Beta Midnight Flip Dipped from Fuel SLut Garage
Synapse BOV
SECo Plug-n-play(Snoopy) Blow-Off Valve Solenoid
ATP Garrett GT3076R Turbo
ATP o2 Housing
MXP Exhaust Manifold
GFB Boost Controller
Stage 3 BTR Tune
VAGenCoupe13 is offline
post #83 of 110 Old 03-11-2016
Midnight Mechanic
Quoted: 14 Post(s)
Oh this is for the Garrett 3076 turbo
Gran Premio Grey
Modfied R2C CAI
ISR Street TBE
ISC Coilovers
DD 8K HID's
DD Switchbacks
Seibon CF Hood
Synapse BOV
ATP o2 Housing
Stage 3 BTR Tune
post #84 of 110 Old 03-11-2016
Quoted: 749 Post(s)
RC racing 750cc are decent.
They don't state that they have any for the genesis, but the one's they state for the evox work. they don't have the extended injector nozzle like on the oem evox injectors
They don't have 550cc for the evox, because the evox injectors are already 550cc.
Might have to get denzo to bosche injector adaptors if you get these... or they might already include them. There's been people (other forums) that got the adaptors, and some not.
I believe the ones for the neon str4 work as well.
VAGenCoupe13 likes this.
post #85 of 110 Old 03-11-2016
Midnight Mechanic
Quoted: 14 Post(s)
Yeah I just read that for being only at about 400rwhp that the 750 cc's should work just fine. Unfortunately my money is short thanks to buying a used BTR3 setup.
Gran Premio Grey
Modfied R2C CAI
ISR Street TBE
ISC Coilovers
DD 8K HID's
DD Switchbacks
Seibon CF Hood
Synapse BOV
ATP o2 Housing
Stage 3 BTR Tune
post #86 of 110 Old 03-11-2016
Midnight Mechanic
Quoted: 14 Post(s)
RC Fuel Injectors (Evo X) ? Modern Automotive Performance
These are still showing for $419, does anybody have these for somewhere in the 300's?
Gran Premio Grey
Modfied R2C CAI
ISR Street TBE
ISC Coilovers
DD 8K HID's
DD Switchbacks
Seibon CF Hood
Synapse BOV
ATP o2 Housing
Stage 3 BTR Tune
post #87 of 110 Old 03-12-2016
lokiinlove's Avatar
Quoted: 106 Post(s)
Look at ev14 from prw store
EFR7163 2.0T BK1 A/T build - fast spooling 400whp+ 5speed auto <- let's pray it'll last a while -> https://www.gencoupe.com/gencoupe-build-projects/582313-lokiinlove-s-2-0t-t-build-thread.html
lokiinlove is offline
post #88 of 110 Old 03-12-2016
Quoted: 749 Post(s)
To add what I posted earlier.
The only time I used RC injectors are when I had my 280z with the stock L28E engine and then with a KA24de-t swap.
Ran quieter than the stock injectors on both. L28 injectors cost me about $300, and the KA24 injectors cost me about $260.
Don't remember what CC they were rated at, it was a long while ago.
Try looking up prices for the SRT4 versions of the injectors if you're still looking at RC injectors. Might be cheaper.
post #89 of 110 Old 03-12-2016
Midnight Mechanic
Quoted: 14 Post(s)
Thanks so much do they fit our cars or is an adapter needed? I'm new to researching injectors for the turbo swap I'm doing. and what size injectors are they 60mm or 48mm? Standard/Long/Compact? Thanks for the help in advance, I want to make sure I'm doing this right!
Gran Premio Grey
Modfied R2C CAI
ISR Street TBE
ISC Coilovers
DD 8K HID's
DD Switchbacks
Seibon CF Hood
Synapse BOV
ATP o2 Housing
Stage 3 BTR Tune
post #90 of 110 Old 03-14-2016
Quoted: 749 Post(s)
Looks like the srt4 injectors might be shorter than ours.
I have an extra set of oem injectors in the trunk. I'll get measurements and post them.
post #91 of 110 Old 03-14-2016
Quoted: 749 Post(s)
I was going to draw up a CAD rendering of the injectors, but solidworks keeps crashing on me.
Anyways, length is about 61mm from end to end (nozzle it recessed)
diameter is about 13.5mm
you can get away with injectors being within about 5mm longer.
post #92 of 110 Old 03-14-2016
Clutch Burner
huntken's Avatar
Quoted: 187 Post(s)
There are NO aftermarket injectors that'll work on BK2 with the stock ECU. You have to have the stock injectors modified. Otherwise you have no choice but to go Haltech.
huntken is offline
post #93 of 110 Old 03-14-2016
Quoted: 749 Post(s)
Who said anything about running larger injectors without a retune?
This is the BK1 section. BK2 ecu can be retuned to run larger injectors.
You can run larger injectors on a stock tune.... but it's going to either bog down, or flood the engine.
Injectors aren't sensors that can see how much fuel it's putting in, it can only see if it's completing a circuit when the ecu wants it to fire.
post #94 of 110 Old 03-14-2016
Clutch Burner
huntken's Avatar
Quoted: 187 Post(s)
The person you're talking with lately has a BK2, only reason I mentioned it. I know it's the BK1 section, doesn't make a difference to me since he came here for help. Just don't want to see him waste his money. And trust me, no aftermarket injector will work on BK2 on the stock ECU, it simply will not even work, I know, I tried. I drove 8 hours one way to a dyno event and was going to be the first BK2 with aftermarket injectors, but they simply didn't work at all due to impedance. So yes, they're not sensors, that's pretty obvious but they also will not work.
kepone likes this.
huntken is offline
post #95 of 110 Old 03-14-2016
Quoted: 749 Post(s)
You know, they make high impedance injectors.
You would have to find ones with the right dimensions.
diameter wouldn't be that hard to find, but matching length would be the issues. Most are a cm too long, but pretty sure you can just put spacers on the fuel rail bolts.
Sounds like someone didn't do their homework, before buying stuff. It says they're high impedance in the Fuel System - Engine Control System section of the shop manual
post #96 of 110 Old 03-14-2016
Clutch Burner
huntken's Avatar
Quoted: 187 Post(s)
I absolutely know they make high impedance injectors, that's what BK1 injectors are... (12 ohm)
Size is 14mm in diameter and 60mm long for stock BK2, but doesn't matter since high impedance doesn't work.
Stock BK2 injectors are 6 ohm, no one makes them that I found. And the person that didn't do their homework? Yeah, we just assumed that BK2 used the same impedance injectors that 99% of other fuel injector cars used, you know, since I was the first one trying to do it after all, no one had done the work already... Anyways, only trying to help but apparently this has turned into a knowledge pissing match that I didn't sign up for. Good luck to the guy asking for larger injectors for his BK2 Stage 3 kit, only option is Haltech or modified stock.
kepone likes this.
huntken is offline
post #97 of 110 Old 03-14-2016
Quoted: 749 Post(s)
Actually a majority of the cars made today run high impedance.
Reason it takes less amperage to run and runs the injectors cooler because of it.
post #98 of 110 Old 03-14-2016
Clutch Burner
huntken's Avatar
Quoted: 187 Post(s)
Meaning high impedance....
Exactly what I said. Just Sadly not the case with BK2.
kepone likes this.
huntken is offline
post #99 of 110 Old 03-15-2016
that guy
kepone's Avatar
Quoted: 82 Post(s)
@huntken is correct. To date, nobody has figured out how to use aftermarket injectors with the OEM bk2 ecu. You have to switch to a Haltech to upgrade injectors on a BK2, period. I believe one of the vendors had drilled out stock BK2 injectors for sale, maybe BTR, and those flow a bit more than stock. To my knowledge that's your only option for the Bk2 at this time, but that's not good enough to run e85 if you want that. If you go Haltech then your BK2 will not have working air conditioning, so most people will not choose that option either.
'12 2.0T 6SP - ???whp
USRT Genesis II 1200cc
Tuned by Dardan Tuning
Grimmspeed Ported Intake Mani
Haltech
GarageLine STS
ACT Fidanza Clutch/FW
Saikou Michi Catch Cans
Whiteline FSB
Bilstein B8
Progress Springs
#KHARTUNERZ
#ITSNEVERFINISHED
kepone is offline
post #100 of 110 Old 03-15-2016
Midnight Mechanic
Quoted: 14 Post(s)
Ok yeah guys that was me with the bk2... So that means that the only aem injectors I could use would be going Haltech or having BTR modify a set correct?
DIY Fuel Injector Install Murcus Engine and Drivetrain 81 04-11-2016 02:41 PM
Beyond Redline Presents: E-85...Is it right for your car? [email protected] 2.0T Discussion 2008-2012 9 02-03-2014 11:32 AM
E85 ballerstatus 2.0T Discussion 2008-2012 41 04-29-2009 03:35 PM
Hyundai Genesis FULL Review Translated(from http://bkmania.com/bbs/zboard.ph) part 1 James519 General Discussion 7 04-13-2009 08:30 AM
