Engine build - Hyundai Genesis Forum
 3Likes
  • 1 Post By KC2pointSLO
  • 1 Post By MZ777
  • 1 Post By AKGC
post #1 of 15 Old 06-20-2016 Thread Starter
Engine build
I'd like to build my 2010 2.0 engine. I went to get it tuned today at a local dyno and they were going to charge me $600 and only getting 15 hp out of it. What is the best way to gaining hp ? I'd like to be around 350hp
Cookie is offline
post #2 of 15 Old 06-21-2016
Quoted: 749 Post(s)
Is this a joke?
350 wheel hp from an engine that that gets about 210hp at the crank?
That's about double the hp at the crank
new internals
intercooler and piping
turbo
manifold
injectors
ecu reflash
bov
wastegate (if turbo doesn't come with one, and turbos to make 350 whp usually don't)
exhaust
replacement timing chain
head studs
head gasket
bottom end fastener kit
upgraded radiator
clutch kit
ect....
post #3 of 15 Old 06-21-2016
Quoted: 10 Post(s)
you can make 350 on the 2010 coupes with stock internals with out a full build, but you will need injectors,FMIC, clutch and bigger turbo
Engine:
custom short ram intake
custom hard piping synapse BOV
custom 3in intercooler core
3in custom exhaust
comp clutch stage 4 6puck sprung
ISR evo 8 manifold
325whp 347twq at 19psi
10sub stock radio
AEM afr and Boost guages
Greddy profec b specII
8000k HIDs
35% tint
tinted tail lights
struck1481 is offline
post #4 of 15 Old 06-21-2016
Quoted: 749 Post(s)
how many are actually running 350 whp with a stock bottom end, as opposed how many aren't?
Even hyundai changed the internals on the 2013+
Anyways...
The cost of a used motor is about the same as rebuilding it with better internals.
cheaping out and risk blowing your motor and buying a used one later, or rebuilding it for the start. You choose.
post #5 of 15 Old 06-21-2016
Quoted: 10 Post(s)
Anyways...
lol i ran for over 2 years on stock internals before i did broke into the motor. i'm not telling them not to build the block but you can do 350 on a stock block and be good
Engine:
3in custom exhaust
ISR evo 8 manifold
10sub stock radio
8000k HIDs
35% tint
tinted tail lights
post #6 of 15 Old 06-21-2016
Quoted: 749 Post(s)
9.5:1 compression with over 20psi of boost.
Think about that for a moment.
post #7 of 15 Old 06-21-2016
n00b
KC2pointSLO's Avatar
Location: Kansas City, MO (Home of the World Champion Royals)
Quoted: 65 Post(s)
Sorry. Couldn't resist.
AKGC likes this.
2013 Base 2.SLO Turbo - Tsukuba Red
SFR Stage 1 Canned Tune, Depo Racing down pipe & test pipe
18" XXR-551 Gold Rims, +22 offset and 8.75" front and 9.75" rear wrapped with BFG Sport 2 A/S - 245/40F and 275/40R
PSM Competition Coilovers - 8kg F, 6kg R, lowered with 1 inch wheel gaps all around.
Gold Genesis Wing Badges, Color-matched Rear Window Spoiler
Opt-7 6000k low-beam HIDs, 3000k LED Fog Lights, Diode Dynamics Switchback Turn-signal
257 rwhp, 273 rwtq
KC2pointSLO is offline
post #8 of 15 Old 06-22-2016
nyangineer's Avatar
Quoted: 175 Post(s)
SteveJohns29 used to have that power with stock internals but his build list now includes built engine components and more hp. It can be done but if you read his thread you will see where parts start to break down.
nyangineer is offline
post #9 of 15 Old 06-22-2016
SUN★WORKS
SteveJohns29's Avatar
Quoted: 153 Post(s)
Lasted 3 years- 30k miles at 475whp on the stock bottom end before showing signs that it should be rebuilt.
Building just the bottom end cost me about 5k. Buying a used 2013 engine would have been much cheaper (also not as strong).
I'm still making the same power after having the bottom end rebuilt.
Sponsored by:
475WHP/363wtq
SteveJohns29 is offline
post #10 of 15 Old 06-22-2016
MZ777's Avatar
Quoted: 181 Post(s)
Well, I am not going to argue but my $.02 are - I believe that most reliability depends on the tune. Of course, it also depends on the driver including his or her aggressiveness. I am the owner of TXS400 (one of the bolt on turbos TurboXS sells) and this turbo is capable of making 400 horses. From talking to @[email protected] and other guys at TurboXS - I can safely produce your wanted numbers on stock engine with full bolt ons. I don't even need to port/polish the manifolds which a lot of people do believing this would help. I will be ordering their can tune soon and once it's all together - I will let the dyno show the result. Also, I would suggest you be the judge of your own car - if you are not afraid of trying things out - I'd say do what you think is right. Luckily, our motors don't cost as much as S85B50, so if anything - look at it as an opportunity to buy a bk2
struck1481 likes this.
MZ777 is offline
post #11 of 15 Old 06-22-2016
Quoted: 749 Post(s)
rebuilding a block isn't hard. Balancing and weight matching conrods and pistons isn't hard either.
having someone else rebuild it for you is were things get expensive.
Cookie likes this.
post #12 of 15 Old 06-22-2016 Thread Starter
My plan is to rebuild the motor
Cookie is offline
post #13 of 15 Old 06-23-2016
nyangineer's Avatar
Quoted: 175 Post(s)
Everyone plans to do something, does it always happen? No.
post #14 of 15 Old 06-27-2016
SUN★WORKS
Quoted: 153 Post(s)
I had it professionally built by a local shop called PRL.
The machinist spent something like 4-5 hours just properly line boring it.
Sponsored by:
475WHP/363wtq
post #15 of 15 Old 02-13-2018
I know this thread is old as hell and I didn't read it to the end, but I used to work for the Hyundai dealership owned by the CYCC Hyundai Canada racing team. They used to run upwards of around 500-600hp on stock bottom end. Those 2.0T's are EVO X engines. You can go so far with them. Just do it right.
mbs6817 is offline
Engine Build? thecolem General Discussion 6 03-06-2015 07:52 PM
Build-Your-Own Z06 Engine Program Revived AutoGuide.com AutoGuide.Com News 0 01-07-2015 08:10 AM
interior engine build Daniel Smolyuk General Discussion 29 11-01-2014 06:38 AM
Hyundai Genesis coupe engine build Pavel! 2.0T Discussion 2008-2012 149 07-10-2012 04:26 PM
N7 Engine Build: Stock Block Data Quartermaster 2.0T Discussion 2008-2012 73 04-24-2012 05:16 PM
