No power? - Page 3 - Hyundai Genesis Forum
post #41 of 48 Old 04-25-2019
CRC
Originally Posted by Jasperxxl View Post
My apologies if this has been answered, I have searched some forums and google a bunch and not sure where I should start.
So the other day I was coming home from work being tired and 11:30 at night I wasn't in any mood to "handle" my car like I would on any other day. Everything seemed fine heard the turbo spool when I started the car and when I was on the freeway trying to get up to speed my car was extremely sluggish, wouldn't go past about 5k RPM and wasn't able to hear the turbo. I stopped, got gas thinking I had low fuel as my gas gauge isn't working properly right now, start rolling out, heard no turbo spool and had no power still. I got home that night started looking at my motor, everything seemed fine, no smoke, no weird noise or smell. Finally got all the piping and stuff off the turbo and made sure the turbo itself still spun by hand and made sure the blades were not damaged. I checked all inter-cooler piping and I did have what I think is a vacuum line was cracked so I had replaced to no difference. Also, there is no CEL or anything on the dash. So, as of now I have three theories.
1. The turbo pressure sensor is bad
2. The waste gate is stuck open
3. The turbo is just bad.
What do you mean by this statement? If your ecu thinks you're low on fuel it will limit boost.
2010 2.0T Track M/T Tsukuba Red
BR Stage 1 Tune
BR Cat-back Exhaust
CNT Test Pipe
AGP Catch Can and Breather
CRC is offline
post #42 of 48 Old 04-25-2019 Thread Starter
Quoted: 13 Post(s)
My gauge is just reading wrong like +/- a couple gallons or it will float back up just past half if im just under half just random ****. Like it shows I have more than half a tank of gas which is true as i just filled up but it doesn't think im empty or anything. I know if you are low on fuel your turbo doesn't kick in. I have been running this for a couple months now with no issue.
Jasperxxl is offline
post #43 of 48 Old 04-25-2019
Love the corners
barfoboy's Avatar
The timing code may be solved by replacing the sensor. Erratic timing is a bad thing.
Test the new sensor by disconnecting the battery, connect the battery then drive the car.
After that are soooo many possibilities.
barfoboy is offline
post #44 of 48 Old 04-25-2019 Thread Starter
Quoted: 13 Post(s)
Originally Posted by Pchelka View Post
it wont...
AKGC is right on the sensors... try cylinder leak test
So new discoveries, I added oil to the car and cleared the codes. I ran the car around the block with same results as before with no power. I came in and ran the codes. P0014 cleared, but P0299 persisted. Interesting.... I did a small vacuum test on the WG and the BOV. The BOV opened and then closed once I released the vacuum. When I did the same for the WG, uhh the vacuum held pressure. I pulled the rod on the WG and nothing happened, I'm not sure what I'm expecting it to do. With no vacuum pressure, I pulled the rod to the WG and it didnt create a vacuum.
Not sure if this helps with anything, I have a WG on its way.
post #45 of 48 Old 04-26-2019
lightthemup's Avatar
Quoted: 73 Post(s)
The WG works off boost not vacuum, if you have no boost the wastegate is naturally closed by spring pressure, you have to pull hard on the arm to open it.
My guess is the flap that closes the WG on the turbine broke off, but it's just my guess.
Sent from my SM-G935V using Tapatalk
2011 base Auto. BK2 engine, Elite Evo 9 kit with TD06SL2R-20G 7+7 billet compressor wheel and anti surge cover, BTR stage 3 tune, 550cc injectors, fuel return line, AEM Methanol injection,CXR intercooler, full exhaust with ARK, LSD...ported heads and intake manifold...bla.bla.bla
lightthemup is offline
post #46 of 48 Old 04-26-2019
You should still get about 5 lbs of boost even with low fuel.
post #47 of 48 Old 04-26-2019
Quoted: 26 Post(s)
That can be checked - just grab the rod (Do NOT twist it) push and pull on it, you should hear the flapper actually making a sound when it closes / hits the exhaust port
Pchelka is offline
post #48 of 48 Old 05-13-2019 Thread Starter
Quoted: 13 Post(s)
Good morning, afternoon, evening.
The not so epic conclusion to the story, It was the turbo. The exhaust turbine shaft was bent, went out on a limb and bought a used turbo and put it in last night. Back to normal. Little leaky cause old gaskets but they have been ordered.
Thanks to everyone for your inputs, I have learned a lot about my car.
Agency Power Exhausts Clearance sale!!!! TuscaniCustoms Engine 44 09-20-2014 05:05 PM
░░▒▒▓▌Agency Power Cat-Back for 2.0T & 3.8 V6! [CLEARANCE PRICE!] ║ GenRacer GenRacer Support Engine 1 10-07-2013 07:29 AM
Power Axel Power x 2 With br tune 150+shipping shawnt321 Engine 15 08-01-2011 10:51 AM
Another RRM Next State Power Pro Review brandon1987 3.8 V6 Discussion 2008-2012 111 01-28-2010 01:41 PM
Official ROAD/RACE- Next Stage Power Pro Challenge ROCK 2.0T Discussion 2008-2012 337 01-23-2010 08:52 PM
