Different way of hooking up a Synapse BOV (It works) - Hyundai Genesis Forum
post #1 of 110 Old 04-23-2013 Thread Starter
Gas.Clutch.Shift.Repeat
Killersingh's Avatar
Hooking up your BOV to use the stock solenoid
Okay so I ordered the Weirtech intercooler piping with the synapse BOV. I was having issues with the BOV.
If i was in neutral revving my car i could hear my BOV venting the air but the moment i started driving and under any amount of load the air would VENT out of the Intake (compression surge?). I had my BOV hooked upto the intake manifold line and had the stock solenoid capped off. The setup was fine as checked by a couple of people. The problem persisted though so this is how i found the solution...
I went to Canadian Tire and bought extra rubber hose incase i needed it. What I did was I connected the Intake manifold line to one end of the STOCK solenoid ( the one that goes into the intercooler pipe) then i took another length of rubber hose and connected that from the other connection (the one the stock BOV is connected to) and took that and connected it to PORT A ONLY.
Then i went for a run. Car was already nice and warm since i had tried bunch of other methods before hand. Car boosted fine. Held High boost fine and vented thru the BOV!! (FINALLY!!)
I came back and connected the line going to THE BOV to both PORT A AND PORT B.. I started having issues (venting thru intake)... and i tried whole bunch of methods none of them worked this is the only one that works for me...
Ill post pics. My only concern is that is this a safe method? Can I screw anything up?? I'm a total car noob everything i've learnt about cars has been from this forum.
BELOW IS BASICALLY A HOW TO:
Ok so here you go!...
RED is INTAKE MANIFOLD
BLUE is TO BOV PORT A
I hope the pictures help!! To me it looks simple because i did it myself but i know how it could look confusing to others i tried my best with paint. Let me know if you guys need further clarification! Late for hockey now!
This is the picture thats the easiest to see wth is going on! Remember RED and BLUE!
Second overview
Intake manifold/BOV pic:
And finally.. Solenoid pic... REMEBER RED and BLUE!:
2013 Genesis Coupe 2.0T Premium - Manual Becketts Black
-WeirTech Intake
-Weirtech Intercooler piping+Synapse BOV
-SFR Stage 1
-HSD coilovers
-ISIS catback exhaust + Downpipe + Test Pipe
-Brembo Brakes
-Forgestar F14 Semi Concave/SDC Matte Black w/ limited edition Red Center Caps
-Uniq Performance Strut Bar
-Chrome Wing Emblems
-28% tint on back 3
-6000k HIDs high/low beams and fogs
Try this method to hook up your BOV:
http://tinyurl.com/bqjwfk4
Killersingh is offline
post #2 of 110 Old 04-23-2013
I don't understand why people use the stock BOV solenoid with the aftermarket BOVs.
post #3 of 110 Old 04-23-2013
슈퍼 쿠페 ^_^
Snoopy0812's Avatar
Quoted: 91 Post(s)
Snoopy0812 is offline
post #4 of 110 Old 04-23-2013
Why so serious, Bro?
GenCoupeGeek's Avatar
Quoted: 1226 Post(s)
In the case of the Synapse, it was designed to work with the stock BPV Solenoid. In fact, Synapse highly recommends that you use the stock BPV solenoid because you are going to get the fastest response from it than you would using just a vacuum source.
With that said, when I installed my Synapse, I discovered that my BPV solenoid valve wasn't working. I ordered a new one on EBay for about $35.00 and haven't had a problem since.
BTRcc Custom Tuned
~Albert Einstein
GenCoupeGeek is offline
post #5 of 110 Old 04-23-2013
Yes I guess it's my fault for reading all the "My BOV is fluttering" or "Where should I hook up the BOV" threads.
post #6 of 110 Old 04-23-2013
I don't understand how it can act faster on a restricted flow solenoid compared to 1/4" hose straight off the intake.
post #7 of 110 Old 04-23-2013
슈퍼 쿠페 ^_^
Snoopy0812's Avatar
Quoted: 91 Post(s)
to be fair, some people are just f*cking stupid. I don't see why some people have difficulties with a lot of things, remove old part, put new part in old parts spot, done. Some people just don't get that, they seem intent that things have to be more difficult than what they really are.
post #8 of 110 Old 04-23-2013
슈퍼 쿠페 ^_^
Snoopy0812's Avatar
Quoted: 91 Post(s)
The solenoid has access to a tank of vacuum, the intake manifold actually has to develop vacuum before the valve starts to move, where as the solenoid can use the stored vacuum in the tank to open the valve the instant the DBW system receives the signal to close the throttle plate.
post #9 of 110 Old 04-23-2013
슈퍼 쿠페 ^_^
Snoopy0812's Avatar
Quoted: 91 Post(s)
btw OP, yes we've gone off topic, no our comments are not directed at you.
post #10 of 110 Old 04-23-2013 Thread Starter
Yeah its okay but like i said i tried the "normal" way but for reasons unknown to me that was venting 80% thru intake and 20% thru BOV. I tried other methods. I think i probably tried like 5-6 different combinations... Like i said people who saw my setup said it SHOULD work but it didnt! Anyways yeah i never planned on using yhe stock solenoid in the first place
-WeirTech Intake
-SFR Stage 1
-HSD coilovers
-Brembo Brakes
-28% tint on back 3
post #11 of 110 Old 04-23-2013
cowcow's Avatar
Quoted: 41 Post(s)
Port b is the fastest port FYI
cowcow is offline
post #12 of 110 Old 04-23-2013
So we really need a bigger solenoid and plumbing?
post #13 of 110 Old 04-23-2013
Solenoid and plumbing work fine as long as it's working. Provided the BPV solenoid valve is working properly.
BTRcc Custom Tuned
~Albert Einstein
post #14 of 110 Old 04-23-2013
That wasn't my experience with my Tial. Haven't used it since.
post #15 of 110 Old 04-23-2013
I can't answer for Tial... but for the OP's Synapse, it works perfectly with the stock solenoid and plumbing.
BTRcc Custom Tuned
~Albert Einstein
post #16 of 110 Old 04-23-2013
슈퍼 쿠페 ^_^
Snoopy0812's Avatar
Quoted: 91 Post(s)
You can actually ream your OE solenoid and gain about 10-15% more flow from it if you've got the patience Red. You could also replace the solenoid with GrimmSpeeds EBC unit since it'd direct plug and play and just tune to compensate for it. You use CMD anyways right?
post #17 of 110 Old 04-23-2013
Boost Addicted
Xell's Avatar
After driving with my synapse for a month on the solenoid and far longer off the manifold...I will never go back to solenoid. It would pop the BOV at about 17 psi for no reason at all (Yes I was well above oil temp, and normally I run about 22/23 psi with my mods...got lucky with a monster from the factory I guess?) and sometimes would even pop it off while accelerating and then close and pop off etc...very annoying.
I also hit overboost limp mode 4 times while on stock solenoid due to the bov not releasing quickly after I let off the throttle after a hard acceleration...like it couldn't open the synapse fast enough or something. Ever since I switched to the manifold I've had zero problems.
I have mine hooked up with only the B tab...synapse confirmed in an email to me that you can hook up A and B but B is what they recommended for fastest release with my setup (Off the manifold). Tho they mentioned that they recommend that for the solenoid setup too.
2013 Tsukuba Red Auto 2.0T
Evolve Charge Piping
Evolve Race O2 Housing
Evolve Downpipe
Evolve Quad back Catback
Evolve Intake w/Vibrant Filter
Synapse BOV
Kahtec Brake Light Mod
Saikou Michi Dual Catch Can
Jcs gauge pod
Prosport Evo Gauges (Wideband, boost, oil temp)
Headlight LEDs
Near Future
Tune
Wheels
Meth Injection
Aluminum manifold with grimmspeed love
Xell is offline
post #18 of 110 Old 04-23-2013 Thread Starter
Mine isnt just off the solenoid i have the intake manifold line going to the stock solenoid! It doesnt vent at any boost until i let off the gas. I'll hook it up to port B and see if its better or worse
Looks at my "while testing" picture its pretty easy to follow the lines in that pic and see wth im doing
-WeirTech Intake
-SFR Stage 1
-HSD coilovers
-Brembo Brakes
-28% tint on back 3
post #19 of 110 Old 04-23-2013
Boost Addicted
Xell's Avatar
Does the solenoid not already feed off the manifolds vaccuum?
Evolve Downpipe
Synapse BOV
Jcs gauge pod
Headlight LEDs
Near Future
Tune
Wheels
Meth Injection
Xell is offline
post #20 of 110 Old 04-23-2013 Thread Starter
It does but when i tried to hook it up just the solenoid the BOV didnt work properly. I guess hooking up the other line gives it that extra "vaccum" idk wth it does im not a expert all i know it works this way
-WeirTech Intake
-SFR Stage 1
-HSD coilovers
-Brembo Brakes
-28% tint on back 3
HKS SSQV III BOV or Synapse Synchronic BOV uni 2.0T Discussion 2008-2012 38 07-24-2013 01:46 PM
(fs) Synapse BOV Durant Québec 0 07-22-2012 12:38 PM
**F/S Synapse BOV** 2K11G3N Engine 11 06-26-2012 04:16 PM
New Synapse BOV Genesis2012 Engine 4 03-04-2012 04:52 PM
HELP!! synapse bov zero313 2.0T Discussion 2008-2012 10 08-30-2011 07:03 PM
