2013+ 2.0T Dyno Sheets - Page 15 - Hyundai Genesis Forum
 10Likes
post #281 of 356 Old 08-07-2014
Quoted: 215 Post(s)
If it's under what Dynojet software gives you as standard format, whp and torque lines must cross each other at 5252RPM as numbers are based off of Horsepower = Torque * RPM / 5252.
If it's not manually or forced to be scaled, it will give the graphs like our print outs.
However, looks some companies do play with dyno graphs (see some dynosheets posted on the page 12) neatly on the same graph to making it look like it's smoother or using 3 different individual graphs sizing the each graph as I've posted above (Hence why our graph may looked like it's loosing a lot of torque but that's the nature of small displacement motor/turbo).
Something I've posted in the past
https://www.youtube.com/watch?v=woONQePQNA8 (it starts around 11:20)
post #282 of 356 Old 08-08-2014
ElDominio's Avatar
Quoted: 32 Post(s)
While thankfully, you were not referring to mine, I still have to question this:
In that image, I took my client's graph and laid it out as yours, shrinking the AFR curve and putting both torque and HP on the same graph
Why does my client hold +280hp after 7k?????
Mods;
93 octane
full exhaust
intake
2013
... "Big name" shops live off of kids like this. Enough money to buy super sweet marked up name brand parts at MSRP and then pay outrageous labor rates all day long to have a car that could have made the exact same power for significantly cheaper that will run ten times better... ... That's when people just pay out the ass 24/7 for the rest of their lives.
-Chapter 11, Section 51
- Self-proclaimed tuner
-I tune remotely!
My Facebook page at: https://www.facebook.com/AlphaSpeedPR
ElDominio is offline
post #283 of 356 Old 08-08-2014
Quoted: 215 Post(s)
This is typical results we get from the cars with intake/exhaust/91 octane (Same day/dyno that Dancewithturbo got his done)
As Dancewithturbo mentioned his car still had stock end back muffler which was very restricted to start with yet his car is still making over 270whp at 7k.
Not sure what your argument here is
post #284 of 356 Old 08-08-2014
Genesis OG
J Long's Avatar
Quoted: 190 Post(s)
Everyone really needs to chill. WE ALL know you cant compare 2 different cars on 2 different dynos with 2 different mods on 2 different days. Both GC tuners are professionals so y'all really need to quit questioning their every move. If you think you can do it better than by all means tune it yourself...
Cordawg17 likes this.
2013 3.8 Track M/T
BC Racing Coilovers
R2C Intake
ARK Downpipes
ARK Test Pipes
Custom CNT V3 w/ X pipe
SFR Custom Tuned
19x11 +18 265/30
Xenon Depot 6500K D1S HIDs
6000K Switchbacks
6000K LED Fogs
Full Time DRL's
RGB Halos
Custom Interior LED Kit
6W Reverse LEDs
20% Tint
J Long is offline
post #285 of 356 Old 08-08-2014
ElDominio's Avatar
Quoted: 32 Post(s)
I can barely see the numbers in that sheet, but if it is then
https://www.gencoupe.com/2-0t-discuss...2013-2-0t.html
And that is why that ^ thread exists.
-I tune remotely!
post #286 of 356 Old 08-08-2014
WOW! If you people think that a dyno graph like this is an actual representation of power, you need to read up on sensor baud rate/ sample rate/ ect. I would start by asking questions like, How where you sampling engine RPM? Inductive? Optical? OBD port? Also, Is this an Inertia dyno? or have a brake? A graph like this is very common (with bouncy lines) only because of the fact that the sensors are not rated at that high of a sampling rate. All dyno software has a "smoothing" feature that will average the data. Read up on sampling rates. Dynojet is possibly the cheapest hardware/software available. This is why it is so common.
The ONLY numbers that mean anything are the AFR's. I am not going to do the chemistry here because no one will understand. An engine will make the most power when volumetric efficiency is the highest.
Please stop comparing anything on this thread.
Skunkworks85 is offline
post #287 of 356 Old 08-19-2014
I am Interested in having u guys custom tune my car. Will you guys be having any dyno events in the south this year..? I live in Georgia but willing to drive to get my genesis tuned.
hhgreen is offline
post #288 of 356 Old 08-25-2014
justimac's Avatar
Quoted: 32 Post(s)
Runs were done in 4th gear and the weather conditions were accounted for in the results. Dyno was a mustang dyno so assuming a 15% lower result when compared to a DynoJet, I'm at 230whp and 300wtq.
My AFR's show that I'm running pretty rich right now, where it drops to 10.1 I lose a bit of power. Mods are listed in my sig. Time for a tune!
2013 2.0t R-Spec, White Satin Pearl
Performance
K&N typhoon SRI
TurboXS H-RFL BOV
TurboXS RSD TBE
BC Coilovers
BTR Stage 2
Competition Clutch Stage 3
RX350 bi-xenon projectors with Osram CBI 5000k
Varrstoen ES2 19x9.5 +22, 19x10.5 +22
6 point roll cage by The Little Speed Shop
Bride Zeta III w/ Sparco 4 point harnesses
SQ HDC3 10" sub w/ SQ 2200w amp (140dB SPL)
Upcoming
DBA Rotors
Hawk HPS pads
SS lines
ISR Suspension links
PBM Coilovers
justimac is offline
post #289 of 356 Old 08-26-2014
justimac's Avatar
Quoted: 32 Post(s)
Here's the video of the dyno run.
Performance
K&N typhoon SRI
TurboXS H-RFL BOV
TurboXS RSD TBE
BC Coilovers
BTR Stage 2
Upcoming
DBA Rotors
Hawk HPS pads
SS lines
PBM Coilovers
justimac is offline
post #290 of 356 Old 09-02-2014
Quoted: 43 Post(s)
I have a question (yes im a noob) is this with or w/o a tune? (i think im gunna answer my own question but...) cause i think the 13' redlines just under 7k right?
Devirus69 is offline
post #291 of 356 Old 09-08-2014
davidlee92's Avatar
Back story:
I was tuned last year with a magnaflow catback that actually goes down to 2.5" piping in the midpipe, I had a secondary cat, I had problems with my BOV at times, and I was on Shell 91 octane.
Last year Stage 1 result: 248whp/293wtq.
This Year:
I went back yesterday and I recently noticed my car was being sluggish, so I decided to put in Petro 94 octane (I ended up getting tuned on 94 octane).
Exhaust switched to DC sports full 3" catback, 10fintec testpipe to remove second cat, BOV repaired, colder spark plugs, and 94 octane as mentioned.
Baseline run: 266whp/319wtq.
So... i gained 18whp/26wtq just from removing the second cat and better gas effectively - FYI for those of you looking to get tuned in the future!!!
If I'm honest... I didn't expect to get too much more from the tune today since I had apparently already gained so much from these minor changes (also considering dyno error and stuff of course)
TUNE RESULTS:
Well... let's just say I was wrong. Tuner got to work and I actually asked him to max it out (not to dial it back for safety buffer as he usually does). I am sure that my results are a reflection of the 94 octane (definitely recommend it for those of you that have easy access to it) and I am happy that I decided to go with it for today.
And the final numbers:
298whp and 334wtq
Needless to say... I am very happy with my tune and a huge thank you to both the tuner and 10Fintec for getting this done
davidlee92 is offline
post #292 of 356 Old 09-08-2014
+MM+'s Avatar
Quoted: 12 Post(s)
Nice results, David. Is yours the most powerful auto on the board now? Wonder what kind of numbers you'd see with an O2 housing. I'd like to do a 94 octane tune as well, but would rather not run fuel with ethanol in it...hence why I stuck with Shell 91
2013 2.0T R Spec - totalled
+MM+ is offline
post #293 of 356 Old 09-08-2014
mdelement88's Avatar
Quoted: 126 Post(s)
Dang, nice numbers..congrats!
2013 rspec * 6 speedo * ATP GT3076R *
mdelement88 is offline
post #294 of 356 Old 09-08-2014
davidlee92's Avatar
Thanks guy - I think I am the highest hp stock turbo AT at the moment, but I have seen better torque numbers with the 02 housing. Would like to see what the results would be... but I don't think I would retune unless I went bigger turbo haha.
post #295 of 356 Old 09-08-2014
Turbo noob
SketchedOut's Avatar
Quoted: 33 Post(s)
I'm plenty happy with my tune
PLT_Kev likes this.
2013 Tsukuba Red 2.0T R-Spec
Chapter11 Section 62
BTRcc Custom Tune 297hp 350tq
SketchedOut is offline
post #296 of 356 Old 09-08-2014
Quoted: 59 Post(s)
Originally Posted by SketchedOut View Post
[IMG]https://www.gencoupe.com/picture.php?albumid=4521&pictureid=24985[/I
Is the stock clutch holding up with that power?
relyt92 is offline
post #297 of 356 Old 09-08-2014
Turbo noob
Quoted: 33 Post(s)
Like a champ. The '13's and up have a beefier clutch than the '10-'12's.
Hasn't slipped or anything. Holds the torque just fine.
post #298 of 356 Old 09-12-2014
Hi guys, writing from Argentina. I intruced myself to the forum about 2 months ago when i bought my '13 GC willing to get some info from all u experienced with this car (as here in my country there's almost no tuning/mod for it yet). After talking with Btr to get a pre-tuned ecu from the usa , i decided to start locally as the car inmobilizer was a bad point to make the ecu swap an easy thing as I needed the ecu security codes to flash the new one (I dont know how to get them and hyundai here did not help me either). Finally I chose one of the most regarded tuners in vw/audi here and ask him to help me (was a good project for him to know the car and maybe start considering a GC development as it the car was introduced with great feedback here).
Going to the point, this is our first dyno after working/learning the ecu. Was made last wednesday with 72F temp and mid humidity. It compares 3 tests:
1 white line 100% stock
2 blue line with k&n sri + turbo back exhaust (both cats removed) + ngk 1step cold spark plugs but stock ecu
3 red line same bolts on as in 2 but with improved boost and ingnition tables
Although the image displays spanish I can translate for u so 2nd column shows the flywheel hp, 3rd shows wheel hp and pre-last the torque in Kgm (multiply by 7.2 to get lb-ft). Tq curve is in a 2nd pict i didnt upload but at least u can see the peak and rpms.
About boost, we are running 18psi peak (think 15 is the stock so we are 3 above) and the major gains were achieved improving the ignition tables more than the boost as we are not confident on how far we can go with the boost having bone stock engine and here is were u guys can help us due to ur lot more experience with ur cars and local tuners (i mean i dont know how much boost btr/sfr/others uses for their stages 0.5/1.0/1.5 or even 2 but as an example if they run 20psi with no fails, then we can try 19 confident in our next test and see how it goes... then 20 and so on...)
Well now it is time to collect suggestions!!! Let me say I am really happy about being part of this great GC forum having you as our mentors for our novice personal project. Thank u all and hope u can help us. Have all of u a nice day! Regards from Buenos Aires and ur welcome to visit us whenever u want.
piuselli is offline
post #299 of 356 Old 09-22-2014
hoho's Avatar
Quoted: 66 Post(s)
i wonder what my auto dynos at compared to sketched's, i mean how much less power would i have without the IM and just a canned tune
2013 Candy Amethyst Widebody 2.0T 8spd A/T
BTR Stage-AT // Injen Intake
845 Motorsport IC Pipes // Synapse Diverter Valve
Isis o2 Housing // TurboXS Racepipe // Exceladyne Cat-back
Saikou Michi OCC
Burnt Copper Brembos
Full Godspeed Project Suspension
F1R F28 wheels 20x8.5/11 255/285
'14 R-Spec Seats // Suede Interior // Nexus 7 Tablet
Ixion Rear Diffuser // CF Side Extensions // OEM Lip Spoiler
CC DriTech TS-1 CF Hood // KT CF Fog Bezels // Boostec 3-Piece CF Front Lip
hoho is offline
post #300 of 356 Old 09-22-2014
RedGen13's Avatar
Quoted: 147 Post(s)
1)Grab a $100
2)Go to your local performance shop
3)Find out your cars whp/wtq
hoho likes this.
'13 2.0T R-Spec
  • BTR Stage 3 GTX3076 @ 24psi
  • MXP exhaust manifold
  • 3" Custom turbo back
  • Synapse BOV
  • Injen Intake
  • BK1 Intake Manifold
  • 4.18 final drive w/ LSD
  • Slotted and dimpled rotors
  • Wing Badges
  • CF "functional" hood vents
'99 Eclipse Fully Built
RedGen13 is online now
2.0T Dyno sheets CrookedH 2.0T Discussion 2008-2012 820 05-11-2019 11:19 PM
NEW Poweraxel Type B bezel + relocation kit + plexiglass sheets tapan Ontario Classifieds 9 05-28-2013 09:17 PM
KPR Dyno Sheets Fam0us 2.0T Discussion 2008-2012 7 10-29-2009 04:59 PM
