exhaust flow? - Hyundai Genesis Forum
 2Likes
post #1 of 22 Old 10-27-2014 Thread Starter
Quoted: 43 Post(s)
exhaust flow?
hey guys, got the isis street exhaust, and after about 500 miles this still hasent changed...my driver side exhaust has one side thats pure black, and one side thats not
my passenger side is just fine
what could be causing this, there isent anything blocking the other pipe..i guess the pipe could be bent to much on the diver side. or is this because well its a I4 and only puts out so much gas lol. i have the 2nd cat removed, o2 housing is still stock. its the catback isis street exhaust.
Devirus69 is offline
post #2 of 22 Old 10-27-2014
Useless in 1st
ahsfba's Avatar
Mine is the exact same way. Just that one tip that stayed silver.
SPONSORED BY VMR | WHEELS
2013 Gran Premio Gray 2.0t R-spec M/T
| SFR Stage 1.5 | BC Racing BR Coilovers | TURBOXS Racepipe |
| ISR Street CBE |R2C SRI | Forge BOV | Rebadged |
| Depo Racing O2 Housing | VIS CF AMS Hood | VIS CF OEM Trunk |
| DD Interior, Exterior LED and HID lighting |
ahsfba is offline
post #3 of 22 Old 10-27-2014 Thread Starter
Quoted: 43 Post(s)
huh weird, i wonder if running a full TBE would fix it, seeing as how more gas would be let out faster. alright well atleast im not the only one.
post #4 of 22 Old 10-27-2014
LeesEvoGenX's Avatar
Quoted: 342 Post(s)
even if there was minimal flow through the other tip it should still go black from all the soot and carbons.. That tip is still silver, like when you first get it from the supplier.
OP, do you feel any exhaust gas from that tip? to me it looks like no exhaust is going through there whatsoever.
2013 Evo X GSR: Built 2.0l with Wiseco pistons, Manly turbo tuff rods, titanium valve springs, Kelford 214-B cams. Stock sleeves. Custom Fuel Rail. Custom Surge Tank.
On Kozmic's Mustang Dyno: 425AWHP 330AWTQ(Break in tune)
Final Tune on E85: 505AWHP 357AWTQ
LeesEvoGenX is offline
post #5 of 22 Old 10-27-2014 Thread Starter
Quoted: 43 Post(s)
i do, i put my hand down over the hole and i do feel exhaust, warm even. im wondering if its a defect in the oval muffler they have, but even then the one pipe is super black on the driver side. the exhaust was crooked a little after installing (the driver stuck out more then passenger) and i fixed that by bending the hanger. but i just drove from Morrisville, NC. to Norfolk, VA. after i fixed it and still looks the same...maybe a little darker. like 2 inches into the exhaust its pure black.
i went outside just now with a piece of paper and put it over the hole, at idle it sucks air in, on both side (driver and passenger side) ill have to wait for my GF to get home to rev it and see if it shoots exhaust out both pipes on driver side.
post #6 of 22 Old 10-27-2014
Quoted: 342 Post(s)
that is pretty perplexing...... I looked up the ISIS exhaust and it basically has 1 pipe coming out of each side of the muffler into 2 tips on each side.
So I don't see where there could be a problem with flow, unless, like you said, it is something to do with the oval muffler.
post #7 of 22 Old 10-27-2014 Thread Starter
Quoted: 43 Post(s)
that's y i cant figure it out LOL, i mean if others are having the issue, then its either related to the oval muffler, or i mean its just a I4, like i said it only shoots out so much exhaust. now with a full TBE i assume it should be fixed but....time will tell.
post #8 of 22 Old 10-27-2014
Quoted: 342 Post(s)
yeah man. you should be proud. for once someone has come up with a good question! hahaha
next step.... cut the muffler open lol
Devirus69 likes this.
post #9 of 22 Old 10-27-2014
Znagle28's Avatar
Quoted: 13 Post(s)
I have the same issue with my tsudo exhaust. I'm running TB with isis o2 housing and ever since I got the exhaust the passenger side inner pipe has been silver while the others are black
2013 Tsukuba red 2.0t
Tsudo catback
Tsudo downpipe
Tsudo test pipe
ISIS o2 housing
Injen SRI
SFR stage 1.5 tune
Debadged-winged
15% tint all around
Paint protected and undercoated
Lower grill delete
Znagle28 is offline
post #10 of 22 Old 10-27-2014
Quoted: 342 Post(s)
this is strange but I don't think it has to do with the car only being a 4 banger. I had the Greddy SE exhaust which has 4 tips, 2 on each side. and they ALL got equally dirty as **** lol.
post #11 of 22 Old 10-27-2014 Thread Starter
Quoted: 43 Post(s)
I have thought about cutting open the muffler, i have a guy who can do it its a matter of timing. i guess my TBE idea got shot out since Znagle is running TBE just with the tsudo exhaust....i keep comming back to it maybe being a mandrel bend on the exhaust exit...or they really did just eff up the oval muffler.....
.....i guess the next question is....are we losing any HP or none at all i mean if we are its probably not noticeable.
post #12 of 22 Old 10-27-2014
Znagle28's Avatar
Quoted: 13 Post(s)
Yeah mine hasn't changed at all. When it was CB it was silver, TB still silver. I can feel the exhaust coming out of it and can see it when it's cold as well. It gets a few specks here and there on it but I have no clue why it doesn't change. Someone else on here with the tsudo had the same problem as well and I've seen it a few times around the forums on multiple brands
Tsudo catback
Tsudo downpipe
Tsudo test pipe
ISIS o2 housing
Injen SRI
SFR stage 1.5 tune
Debadged-winged
15% tint all around
Lower grill delete
Znagle28 is offline
post #13 of 22 Old 10-27-2014 Thread Starter
Quoted: 43 Post(s)
bad R&D on the exhaust i guess then, either way sounds good, probably still getting a power jump due to 3" piping.
post #14 of 22 Old 11-23-2014 Thread Starter
Quoted: 43 Post(s)
So, it’s been bugging me again lately…I’m curious if all the other people had a dent or anything on the driver side exhaust exit (mine came with one, I just hammered it out with a ball hammer)….if this is the case would anyone agree that possibly there was enough weight to maybe bend the mandrel bend on the exhaust to make it so inside exit is out of the flow channel? Because at idle I will see exhaust (when cold out) however sometime it’s sucking air in the inside exhaust pipe.
2013 Tsukuba red 2.0T Base
ISIS Street CBE
ISIS Test pipe
ISIS Downpipe
TXS 02 Housing
TXS FMIC
TXS RFL BOV - H
Injen SP Series Short Ram Air Intake
SFR Stage 1
NGK Spark Plugs 1-Step Colder
OEM Limited Slip
Diode Dynamics 6000K HIDs
Diode Dynamics Switchbacks
Diode Dynamics Multicolored fog lights
OEM fog lights w/ Switch
Soon to have:
BTR stage 2 custom tune.
post #15 of 22 Old 11-23-2014
Desert Rat
B-Spec's Avatar
Quoted: 131 Post(s)
This sounds like a serious design issue here to me.
2013 2.0T Stage 2 BTR-Spec
B-Spec is offline
post #16 of 22 Old 11-23-2014 Thread Starter
Quoted: 43 Post(s)
yea like the metal being to thin? but who knows how these things were shipped over. i contacted ISIS going see what they say. i mean the car sounds great, and i dont notice any problems...its just annoying seeing black-silver-black-black lol
ISIS Street CBE
ISIS Test pipe
ISIS Downpipe
TXS 02 Housing
TXS FMIC
TXS RFL BOV - H
SFR Stage 1
OEM Limited Slip
Soon to have:
post #17 of 22 Old 11-23-2014
TurboTerror's Avatar
I have the Tsudo as well and like yours my passenger inner pipe is silver as well. I have had the exhaust for almost 2 years.
TurboTerror is offline
post #18 of 22 Old 11-25-2014
Desert Rat
B-Spec's Avatar
Quoted: 131 Post(s)
I have the Magnaflow and all mine are black. Haven't had that issue honestly on any car I have owned. I am wondering if there is a block in the muffler on that pipe??
B-Spec is offline
post #19 of 22 Old 11-25-2014
Lazy
fireworks's Avatar
Quoted: 28 Post(s)
I have the CNT V3 cat back and have the same thing. Only thing reason I can see is there is a slightly straighter path out the one pipe.
velocityhead likes this.
Black 2013 Base 2.0T M/T
[SIGPIC][/SIGPIC]
fireworks is offline
post #20 of 22 Old 11-26-2014 Thread Starter
Quoted: 43 Post(s)
When i head over to my parents for thanksgiving, they have some jack stands hopefully i wont have to take off the exhaust again but...i agree with you on this, my driver side seems to be bent in to far. ill see if i can jack it up and while still hot take a towel or something and bend it out a little bit.
ISIS Street CBE
ISIS Test pipe
ISIS Downpipe
TXS 02 Housing
TXS FMIC
TXS RFL BOV - H
SFR Stage 1
OEM Limited Slip
Soon to have:
exhaust flow question jaboo008 2.0T Discussion 2008-2012 22 12-04-2015 01:33 AM
Magna Flow Cat Back Exhaust xGuMB1x 2.0T Discussion 2013 and up 8 06-22-2013 12:05 PM
Flow Master? falcon26 General Discussion 0 07-22-2012 05:13 PM
Full exhaust system with high flow cat? Kunkemonster 3.8 V6 Discussion 2008-2012 6 12-23-2009 03:01 PM
