2013 haltech AC fix DIY - Page 2 - Hyundai Genesis Forum
 12Likes
post #21 of 72 Old 08-31-2015 Thread Starter
Quoted: 137 Post(s)
go crazy a do a testing harness lol
i had my first harness so i cut it in half and did some testing with it lol...not neccessary for only one
glue everything in the case..or use some tape and make sure no part will touch
now time to program the chip
download arduino software here
https://www.arduino.cc/en/Main/Software
install it
download library for the board download the zip file
https://github.com/reeedstudio/CAN_BUS_Shield
extract and insert into the arduino library folder
document/arduino/librairies and
document/arduino/arduino/librairies
you only need one but i gorgot wich one ...doh
in tools select
board:arduino leonardo
com: select the right one
and com
here is the program
Sebastien Moreau at [email protected]
used
Hobbytronics Leonardo CAN-BUS board
Receive Test Data and set filters on ID
Send output data via serial port
Leonardo CAN BUS product page Leonardo CAN BUS board | L-CANBUS | HobbyTronics
Hobbytronics.co.uk
For mcp_can use this library https://github.com/reeedstudio/CAN_BUS_Shield
download the ZIP at the right of the screen
and insert what IN the zip folder into the library
rebbot arduino software
#include <mcp_can.h>
#include <mcp_can_dfs.h>
#include <SPI.h>
unsigned int rxId;
unsigned char rxLen = 0;
unsigned char rxBuf[8];
volatile unsigned char canData = 0;
int AcReq = LOW;
int AcInputValue = LOW;
int Pulse=0;
int AcMem = LOW;
long CommCheck1 = 0; //check if communication is working if not do a reset
long CommCheck2 = 0;
MCP_CAN CAN0(17); // Set CS to pin 17
void setup() {
// put your setup code here, to run once:
delay (250); // wait a bit
Serial.begin(9600);
CAN0.begin(CAN_500KBPS); // init can bus : baudrate = 500k
attachInterrupt(4, can_receive, FALLING); // Pin D7 is Interrupt4 on Leonardo
pinMode(6, OUTPUT); // AC request status to send to haltech
pinMode(8, INPUT_PULLUP); // AC status input to read haltech AC confirmation
pinMode(9, OUTPUT); // Variable output for AC solenoid
analogWrite(9,0);// AC solenoid to 0V
pinMode(23, OUTPUT); // Led output activation mimic AC request
delay (250); //wait a bit
// Basic Filtering on ID
// Bytes 1 and 2 of mask/filter apply to ID
// So the Mask and filter below will only allow ID 0x350 through
// ---- ID -----
CAN0.init_Mask(0, 0, 0xFFFF); // 1111 1111 1111 1111
CAN0.init_Filt(0, 0, 0x0001); // 0000 0000 0000 0001 - FAIL
CAN0.init_Filt(1, 0, 0x0001); // 0000 0000 0000 0001 - FAIL
CAN0.init_Mask(1, 0, 0xFFFF); // 1111 1111 1111 1111
CAN0.init_Filt(2, 0, 0x0001); // 0000 0000 0000 0001 - FAIL
CAN0.init_Filt(3, 0, 0x0001); // 0000 0000 0000 0001 - FAIL
CAN0.init_Filt(4, 0, 0x0350); // 0000 0011 0101 0000 - ACCEPT
CAN0.init_Filt(5, 0, 0x0001); // 0000 0000 0000 0001 - FAIL
void loop() {
// put your main code here, to run repeatedly:
//*****************Check if comm is operational if not do a reset***************************
++CommCheck1; //increase loop counter and check for comm fault if no comm then reset comm port
if (CommCheck1 == 200000) {
CommCheck1 = 0 ;
//if we didn't receive any message reset the port
if (CommCheck2 == 0) {
CAN0.begin(CAN_500KBPS); // reset comm port
// ---- ID -----
Serial.println("Had to reset comm port, no communication!!");
//if we received to many message ...the filter didn't work...reset the port
else if (CommCheck2 > 1000) {
// ---- ID -----
Serial.print("Had to reset comm port, filter didn't work : ");Serial.println(CommCheck2);
CommCheck2 = 0 ;
else {
Serial.print("Comm port is OK received X amount of data: "); Serial.println(CommCheck2);
CommCheck2 = 0 ;
//*************************End of comm check*****************************************
//************************If data is received treat it********************************
if(canData)
canData=0;
++CommCheck2; // increase if data is receive
CAN0.readMsgBuf(&rxLen, rxBuf); // Read data: len = data length, buf = data byte(s)
rxId = CAN0.getCanId(); // Get message ID
Serial.print("ID: ");
Serial.print(rxId, HEX);
Serial.print(" Data: ");
for(int i = 0; i < rxLen; i++) // Print each byte of the data
if(rxBuf[i] < 0x10) // If data byte is less than 0x10, add a leading zero
Serial.print("0");
Serial.print(rxBuf[i], HEX);
Serial.print(" ");
Serial.println();
//Evaluate AC request status ON or OFF
switch (rxBuf[1]) {
case 0x10:
AcReq = LOW;
break;
case 0x18:
AcReq = LOW;
break;
case 0x58:
AcReq = LOW;
break;
case 0x1B:
AcReq = HIGH;
break;
case 0x5B:
AcReq = HIGH;
break;
if (AcReq != AcMem) {
AcMem = AcReq;
Serial.print("AC demand from car 0 NO, 1 YES: ");Serial.println(AcReq);
digitalWrite(6, AcReq);
digitalWrite(23, AcReq);
} // end if
//************************END of received data treatment***********************
//************* Read Haltech output and put AC ON or OFF accordingly************************
//*** max pulse is at 200 that give around 10V that is what i have seen on stock system***
if (AcInputValue != digitalRead(8)) {
AcInputValue = digitalRead(8);
Serial.print("AC confirmation from haltech 0 GO, 1 take a brake: ");Serial.println(AcInputValue);
if (AcInputValue == HIGH) {
for (Pulse=200 ; Pulse >=0; Pulse--){
analogWrite(9,Pulse);
delay (3);
else {
for (Pulse=0 ; Pulse <=200; Pulse++){
delay (10);
//************End of input and AC driving******************************************* ***
void can_receive()
// CAN Receive Interrupt
canData = 1;
upload it to the device...click the arrow saying upload
do a quick check
and open the serial monitor window
tool / serial monitor
you will only see that there is no comm and port is reset
this is a normal exemple when connected to car
uncheck factory a/c input and program DPI1 as follow
and programs DSO1 as follow
genspec13 is offline
post #22 of 72 Old 08-31-2015 Thread Starter
Quoted: 137 Post(s)
air con setting
i just used stock setting
some need pulsed output but i hated the idle so i remove it
post #23 of 72 Old 09-16-2015
Great Stuff!!!
JDAMONSTA is offline
post #24 of 72 Old 09-17-2015
Jonnmad's Avatar
Genius!!!
2014 Genesis 2.0T MT
SFR Stage 1.5
ISIS O2 Housing
ISIS DOWNPIPE
Magnaflow 3" Catback
K&N Intake
Torque Solutios Throttle Spacer
HKS SSQV
AEM Methanol Kit
StopTech BBk 6p 14"
Amsoil Oil Engine
Redline Oil Gearbox
DiodeDinamics HID
296whp 340lb-tq without Meth
Comming soon: Rear Brembo brakes, Rad and oilcooler
Jonnmad is offline
post #25 of 72 Old 09-18-2015
RedGen13's Avatar
Quoted: 147 Post(s)
Way to go, would it make more sense to put the code into a file and have it hosted somewhere too so you don't have to copy an past off of the thread? Appreciate all of the hard work on this and then giving it to the community for free!
'13 2.0T R-Spec
  • BTR Stage 3 GTX3076 @ 24psi
  • MXP exhaust manifold
  • 3" Custom turbo back
  • Synapse BOV
  • Injen Intake
  • BK1 Intake Manifold
  • 4.18 final drive w/ LSD
  • Slotted and dimpled rotors
  • Wing Badges
  • CF "functional" hood vents
'99 Eclipse Fully Built
RedGen13 is online now
post #26 of 72 Old 09-18-2015 Thread Starter
Quoted: 137 Post(s)
yeah tough of that too, just wasn't sure where to host it
and was thinking if it's in text...that will ensure that the program is not lost because of a broken link or something
post #27 of 72 Old 09-19-2015
Clutch Burner
huntken's Avatar
Quoted: 187 Post(s)
Github
huntken is offline
post #28 of 72 Old 11-07-2015 Thread Starter
Quoted: 137 Post(s)
i just did a different version for a swap using the triples gages connector he just needed the AC demand signal
Youtube video
https://youtu.be/7NgsFnjnUFE
darkvader0 likes this.
post #29 of 72 Old 01-04-2016
Zac
Where did you get the triple gauge connector?
Zac is offline
post #30 of 72 Old 01-04-2016 Thread Starter
Quoted: 137 Post(s)
mouser or element 14 i forgot
you also need the pin for it
i may still have the part number somewhere if you need it
post #31 of 72 Old 01-04-2016 Thread Starter
Quoted: 137 Post(s)
i`m not 100% sure
look like these
1473793-1 TE Connectivity | Mouser
1376109-1 TE Connectivity / AMP | Mouser
i you need it for yourself i can recheck to confirm the number
post #32 of 72 Old 01-05-2016
Drakkcoil's Avatar
Awesome work so far man. I've been dying without A/C...
2013 BB 2.0T Premium M6
PTE 6152 56-trim | PRW Cast T3 Top Mount Manifold | TiAL 38mm Wastegate | DeatschWerks 1000cc Injectors | DeatschWerks DW200 255lph FP | FabZilla SRI | FabZilla Custom Catless O2 Housing |
WeirTech CBE | Synapse BOV | FabZilla ICP | RTM 3x12x30" FMIC | Eibach Pro-Kit | AEM Digital Boost, WB AFR & Oil Pressure | ATQ Short Shifter | OEM LSD | Haltech Tuned by APH | AEM Electronic Boost Controller @ 30psi
425whp, 351tq
Drakkcoil is offline
post #33 of 72 Old 01-05-2016 Thread Starter
Quoted: 137 Post(s)
If i could find the AC compressor connector it would be way more easy
it would prevent from building the 40 pin extension
post #34 of 72 Old 01-05-2016
Zac
i`m not 100% sure
look like these
I need the correct part number this is for a slightly different project working with ac.
Zac is offline
post #35 of 72 Old 01-05-2016 Thread Starter
Quoted: 137 Post(s)
yep i verified, these are the right part to hook in the car side of the triple gage
what kind of project if i can ask ??
post #36 of 72 Old 01-05-2016
Zac
I'm doing a blue screen delete. I am using an aurdino to send the ac information to a tablet that I'm putting in place of the blue screen.
Do you know the connector the blue screen uses? I have been trying to find out but I haven't been having any luck
Zac is offline
post #37 of 72 Old 01-05-2016
Zac
Zac is offline
post #38 of 72 Old 01-05-2016 Thread Starter
Quoted: 137 Post(s)
why do you need the connector if you remove the gage ...
i just checked ... gage and blue screen are not on the same can bus ....probably why
it's a KET connector KET_090III_10F_W if i look into the gds
KET and AMP number seem to be equal 090 III for type and 10f for pin and gender
936092-1 TE Connectivity | Mouser
check the spec the initial image on the page is not good
936129-1 TE Connectivity | Mouser
post #39 of 72 Old 01-05-2016
Zac
I don't use the stock gauges and need the CAN L and CAN H hookup.
I have one of these:
https://canb.us/
I am taking some of the data from the low speed can bus and all of the data on the high speed can bus and sending it as an output on the third channel which I have one of those OBD2 Bluetooth devices listening on. The tablet communicates with the OBD2 Bluetooth device showing current AC Settings. I needed the other connector because it has the low speed can bus on it. Now that you have provided this information I can make it plug and play without cutting any wires
I'm not an expert at this but so far everything seems to work.
Zac is offline
post #40 of 72 Old 01-05-2016 Thread Starter
Quoted: 137 Post(s)
Each time i check they are always out of stock lol
i was thinking of using this at first with the haltech...
cut the can to bus to AC and put the device in the middle...and just change the adress that need to be change to start ac....
maybe one day...
DIY: Fix Your Curb Rash CaptainSlow Suspension and Wheels 71 07-24-2016 09:51 PM
DIY: Rear deck rattle fix! tapan Interior 31 02-02-2016 11:40 AM
DIY permanent fix for sunroof rattle Havoc2011 Exterior 40 08-07-2012 05:49 AM
DIY TPMS light fix Hudnut Interior 2008-2012 14 12-14-2009 08:10 AM
